Question about Longines Watches
Adjust bracelet rotary ladies watch - Longines Watches
VOTIT
  • 2071 Answers
SOURCE: watch
You better prepare a plain cloth to avoid scratch a piece of jewelry screw and ponson pinch ,if you cannot secure a ponson, find a big needle or sharp nail,take your watch put a piece of cloth to protect from scratch,hold your watch firmly that cannot slipt.In the side of links,there is a screw marks, or pinch marks lock,if you see screw marks you should use the screw ,if pinch mark ,use the needle or the nail to punch out the lock and detach it ..Again punch it in so it locks or screw it in.That s all you do patswan...
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Jul 25, 2008
escapement
  • 2334 Answers
SOURCE: Can not figure out how to remove links from Casio watch band
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Apr 01, 2009
escapement
  • 2334 Answers
SOURCE: how to adjust metal bracelet on casio A168 watch
Job done!
Posted on Apr 05, 2009
escapement
  • 2334 Answers
SOURCE: how can you get into a sovereign ladies watch to
You have to pull stem out of watch movement completely and then remove watch glass. Sovereign watch cases are monoblock, so, the only way to get into it is to remove the glass. Rate me, plz.
Posted on Feb 10, 2010
Testimonial: "thanks, the watch seems to be made to look like the back is separate, does the stem just pull out. it only seems to come out about 3mm.thanks"
gemineye61
  • 831 Answers
SOURCE: I bought the self adjustable bracelet watch but do
Self-adjusting bands usually feature easy to remove links that simply snap out. They usually look just like the main clasp or blend in with the band. Simply locate these links and undo the closures to remove or add them.
Posted on Aug 20, 2010
Adjust jubilee bracelet
You bend it , literally take hold of the inside arch and bend it with your hands in not out this shortens the , the length and helps it close .
Oct 02, 2014 | Rolex Lady Datejust 179173SRJ Watch for...
I want to ask whether it is possible for this model GUESS WOMEN'S WATCH W14033L3 PYTHON GREEN LEATHER MUSE to order through which site this same leather bracelet, because I already have this model of a...
Beautiful watch. Very classy. Easy to adjust band with two links that can be removed from the bracket. Large round face with easy to read dial. The bracket construction is especially unique with the two different types of finish. GUESS Women Stainless Steel Leather Casual Watch Color Red Model U0627L5
Feb 12, 2018 | Watches
Just replaced the battery on the Bulova Ladies bracelet watch. watch keeps stopping still.
If you have had your watch awhile, it probably needs a clean/oil/adjustment. FIne watches need regular mainentance just like a car. Take to a local watchmaker or send to following:
http://www.bulova.com/service/servicecenter.aspx#inside.aspx
Aug 19, 2010 | Bulova Crystal 96T63 Watch for Women
I need instructions to operate a Ladies Rotary Chronograph Dolphin Standard Watch
Rotary do not seem to list instructions for individual watches but do offer general instructions.
To see these go to http://www.rotarywatches.com/en/service/rotary-watch-care#instructions .
\i hope his helps.
Jul 27, 2010 | Bulova Watch
How do i get extra links for a concord veneto
Go to watchbands.com, enter your model number and bracelet size and problem solved!
Feb 10, 2010 | Movado Concord Saratoga Chronograph Watch...
Watches Logo
11 people viewed this question
Top Longines Watches Experts
michaelrt616
Andrew Taylor
Andrew Taylor
Are you a Longines Watch Expert? Answer questions, earn points and help others
