Question about BaByliss 8667BU
Replacing foil heads - BaByliss 8667BU
I need a dual foil for dual foil 30
This part can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/heads-foils-and-cutters/remington/remington-sp61-df-da-series-foil-screen-p-231.html
Jan 17, 2014 | Remington Health & Beauty
Trimmer of my Panasonic EX3833S is not working
panasonic es3833 replacement foil and blades
panasonic WES9979P combo set for electric shaver panasonic es3833 replacement heads.
panasonic WES9941P outer foil for electric shaver panasonic es3833 replacement parts.
panasonic es3833 replacement blades
panasonic WES9942P replacement blade for electric shaver part panasonic es3833 replacement parts.
Aug 25, 2013 | Panasonic ES3833 Electric Shaver
The foil of my 5790 razor is damaged. How to I remove the damaged foil?
remington SP390 replacment blades and screen foil for remington f5790 heads replacement parts.
Aug 22, 2011 | Remington Health & Beauty
I dropped my 8985 braun and it will no longer shave with the foil head on. It does work if you remove the foil. Did I loose a part?
You probably dented the foil head enough to stop the vibratory action of the blades, thus the working when the foil is removed. Braun has a replacement foil and blade kit sold at Walmart.
Dec 04, 2010 | Braun 8585 Electric Shaver
New head
Hello Brian, You can give the folks at www.electricshaver.com a try. They typically stock all the replacement and repair parts for most brands of electric shavers.
Here's a link to their site where you'll find part #5646768 for about $38 for a new set of the cutter head and foil (screen). It's always best to replace BOTH the foil and cutter block (head) at the same time, as any mircro burrs or nicks in the cutter blades will quickly ruin any new foil screen.
http://www.electricshaverstore.com/get_item_5646768_braun-foil-cutter-kit-360-complete-8000-series.htm
As you know, this is the simplest and easiest way to get an electric shaver back to a "like-new" shaving experience.
I hope you find this Very Helpful and best regards!
Nov 11, 2009 | Health & Beauty
Shaver started making a much louder buzzing sound, no longer shaves as well and now hurts a bit to use. Can this be fixed?
Hello Robert, It sounds like the foil screen might have been damaged and is causing poor shaving performance. Typically, a screen will get small holes or tears in it after providing good service for some years, however, these very thin screen foils, can get damaged other ways too.
The best way to restore the best shaving performance is to replace both the foil screen AND the cutter head block (cutter head) as it could be possible that the cutter blades have become damaged or nicked and have caused the foil screen to become damaged, as a result.
I would contact www.electricshaver.com and see if you can purchase a new set of the cutter block head and the screen foil for your particular Braun shaver model. As the Braun 360 is a tradename used on a couple of different model numbers, you really need the four (4) digit model number in order to locate the correct replacement parts.
Here's a link to their page with the various Braun replacement cutter blocks and foil screens. You might find your model number amoung them, otherwise, you can also give them a call at 1-888-476-1785 and ask them to assist you with selecting the proper replacement parts.
http://www.electricshaverstore.com/get_list_125.htm
As you are no doubt aware, replacing the cutter head and foil screen is the best and simplest way to restore an electric shaver to a like new shaving condition and much less expensive than replacing the entire shaver.
Nov 11, 2009 | Braun 360° Complete Electric Shaver
The blades on my Braun complete 8975 are not sharp anymore.
You replace foil cutter, that braun complete 8975 replacement foil and cutter blades is braun series 3 combi 30B foil and cutter replacement pack.
Jan 30, 2009 | Braun 360° Complete 8985 Electric Shaver
BaByliss 8667BU Logo
61 people viewed this question
Top BaByliss Health & Beauty Experts
NOEL
NOEL
ray gallant
Tom Chichester
Are you a BaByliss Health and Beauty Expert? Answer questions, earn points and help others
