Question about Home Security
Sentry safe factory code
I changed my battery and my code does not work. what is the default code
SOURCE: Changing the code on my Sentry Safe S3877
how to change the on sentry safe s3877
Posted on Jan 20, 2009
SOURCE: factory code will not open model # DA3831 safe
i am a locksmith that has worked on several of these. The safe is manufactuered with three types of lock mechanisms 1. combo dial 2. digital 3. advanced digital the advanced digital is what you have there are no green lights on it. look at the manual carefully there are 2 seperate sections on the digital key pads yours will be the second.
Posted on Dec 18, 2009
SOURCE: sentry codes v260
You should have received two skeleton keys when you bought the safe. They will open the safe without the key AND without the code. If you don't have it, the only solution is to get help from Sentry. By following the instructions below, they will send you a skeleton key for your safe. First, find your safe’s Serial Number. The Serial Number is printed on the small label on the right side of safe (outside). Send this, a notarized letter(last name must be different) stating you are the safe’s owner, and a check or money order or $8.00 (U.S. funds) to:
Sentry Group Dept. 200
882 Linden Ave
Rochester, NY 14625-2784 If using a credit card (Visa/MasterCard only), call 1-800-828-1438.
Posted on May 27, 2010
  • 76 Answers
SOURCE: Need factory code for Sentry Safe Model 1610 -
If you need your lost combination, you must send a notarized letter stating you are the owner of the safe. The link below will tell you everything that you will need to get your combination back:
http://www.sentrysafeshop.com/Lost-Combination-Sentry-Safe-Combination-p/lost%20combination.htm
Posted on Jul 06, 2010
loxmith
  • 21 Answers
SOURCE: Sentry Model 1610 Won't Open
here is the customer service phone number for you. I am sure they will be able to help you. 800-828-1438
Posted on Jul 24, 2010
How do I change the combination on SENPL048E sentry portable security safe
Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Mar 24, 2016 | Home Security
    I have lost the combination for my safe model V330 my model number V330 Sentry safe
    • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
    • Retype the user code to verify it is working, and then close the safe.
    Mar 19, 2016 | Sentry FIRE-SAFE Combination Safe DS3431,...
    How do I open a sentry s3877 safe when the battery is dead and safe is closed
    The factory code combination to your electronic lock will remain in the memory of the unit - even if the batteries go dead. Any use programmed codes will be lost if the batteries lose power. The Sentry programmed factory code is always your default code.
    If you do not know your factory code, you can follow this link for your combination retrieval:
    Sep 23, 2012 | Sentry Fireproof Safe
    I have changed the battery in my sentry 1610, no I can't open it with my pin-Nr..
    if you have changed the batteries, the code may have reset itself to the default code.
    you should be able to find this in the instruction manual or on the manufacturers website.
    i am sorry i cannot give you the codes myself, but i do not feel it is appropriate to put default codes for a safe on an open website
    Feb 28, 2011 | Sentry Safe Fire-Safe Home/Office Safe
    We have a S3877 Sentry safe. The battery appears dead so I can't use the code. I also have the key but since the battery is dead it is no help. What can I do?
    Dec 07, 2010 | Sentry Fireproof Safe
    Somehow can open my sentry s3877 with the keypad.
    A Safe and Vault Tech Will confirm that once you change the batteries the user code will erase and you will now have to enter the factory default that is in the owners manual and then use the programing instructions to program a new user code.
    Jan 07, 2010 | Sentry Fireproof Safe
    Need to open a Sentry keyless combination safe
    First, has the factory combination been changed? Sentry has the code for the factory combination that they can supply you.
    If the factory combination has been changed to something else, then Sentry won't have it.
    In that case you need to ask Sentry for a 'reset' code combination. There is (at least) one back door to your safe -- a reset code.
    The reset code will not tell you what your combination is, it will simply reset the combination to the factory combination.
    You can take it from there.
    Now, this isn't as hard as it may sound. There is an actual department that handles this at Sentry because you aren't the only one that cannot open his safe.
    They'll want some proof of ownership, some $$ for the service, the safe serial number, and probably a notarized form claiming that the safe is yours.
    Get 'hold of Sentry on the web and the rest is just process.
    BTW -- this is exactly what the locksmith would do.
    Apr 10, 2009 | Sentry Fireproof Safe
    Sep 29, 2008 | Sentry Fireproof Safe
    Jul 02, 2008 | Sentry Fireproof Safe
    Home Security Logo
    368 people viewed this question
    Top Home Security Experts
    Lawrence Oravetz
    Are you a Home Security Expert? Answer questions, earn points and help others
