Question about Sewing Machines
How to thread an overlocker - Sewing Machines
Net I have a new Elna overlocker and cannot thread it. I live in Bendigo. Where could I take it for a lesson and general help?
Here are some videos that may be helpful:
Elna overlocker threading Google Search
Be sure to thread the machine "exactly" as instructed. The threads have to be threaded in a particular order and if not followed, the machine will not work properly!
Apr 21, 2018 | Elna Sewing Machines
Help plse, after threading it dont make the overlocking stitches. New machine, help with right way to thread machine and the smaller detail of threading.
Your machine is either not threaded correctly, or the individual threads have not been threaded in order. Be sure to ALWAYS RAISE the presser foot when threading the machine. You must follow the instructions exactly or the machine will most likely never work properly. Can you at least get a training class on your machine? A class is indispensable, especially when it comes to using a serger.
Even if it is not the same model, these instructions may be helpful.
Tutorial for threading overlocker
Make It Handmade Threading Your Serger or Overlocker
Need manual for an empisal 754D overlocker can get the tension right and...
Dec 14, 2016 | Sewing Machines
Bernina 335 serger won't sew/overlock. carefully rethreaded the serger but that hasn't helped.
The 335 has a two thread chain stitch (stitch type 401), and the overlock side (right needle side), is a three thread plain overlock. If you are describing the plain overlock as the problem, I would first suggest the following in re-threading:
1. Thread the upper looper
2. Thread the lower looper
3. Thread the needle last (important)
If the needle threaded, you cannot re-thread the lower looper without breaking the thread.
In order to thread the lower looper, the lower looper must pass by the needle thus picking up the needle thread. So, instead of threading the lower looper thread underneath the needle thread, the looper would be threaded on top and cannot sew without breaking the thread.
Make sure that the threads are bedded between the tension disks. Check this by stretching the thread fore and aft of the tension disks as well as visually noting that the threads are not accidentally threaded behind the disks. You can also loosen the tension disks when threading so as to allow the threads to bed deeply between the disks.
Please reply with your observations.
Sep 27, 2015 | Bernina Sewing Machines
Problem with an overlocker that does not overlock
You may need to rethread all the threads because most sergers need to be threaded in the right sequence. I looks like this one has to be threaded starting at the right and progressing left.
Jan 20, 2014 | Janome Sewing Machines
I'm not sure how to thread my machine, I lost my manual elna lock pro 5Dc
I would suggest that you buy a new manual for this as your overlocker has 5 threads that need to be threaded up correctly to form a stitch and there are several different stitches that can be made with this model such as a rolled hem, chain stitch, three thread overlock, four thread overlock and safety stitch with three thread overlock, lots to learn.
You can buy a manual here for $USD14.99: http://www.sewingpartsonline.com/instruction-manual-elna-pro5dc.aspx
or this website has a copy for $USD10.
http://www.sewusa.com/Sewing_Machine_Manuals/Elna_Manuals/Pro_4DC_DE_Instruction_Manual.htm
Always well worth buying the manual and saving a lot of frustration trying to guess how things work and it adds value if you are going to sell the item.
You can get some general overlocker threading tips from http://sewing.about.com/od/sergersoverlock/ss/serger.htm which may help you too.
Aug 31, 2011 | Sewing Machines
Sould i use overlock thead on my brother embroidery/sewing maching
It is, of course, possible to use overlock thread in a typical machine. Generally speaking, you only want to use overlock thread to overlock ("serge"). The reason for this if that while typical all-purpose or sewing machine thread has 3 strings wound together, overlock thread has only 2. When you are using 3, 4, or even 8 threads at a time with a serger, each strand doesn't necessarily have to be as strong as when you are sewing on a machine with only 2 threads. So, you physically could use the thread, yes, but it will not be near as strong, and you will probably have issues with breakage while sewing as well. The cost savings you think you may be saving by using overlock thread (which is, after all, considerably cheaper per yard), well soon be overrun with extra time sewing due to broken threads and overall less quality in your garment as it will be made weaker.
Jun 19, 2011 | Brother Lay-In Thread Serger Mechanical...
How do i thread a janome overlocker
there's a good you tube video and threading an overlocker
Jun 01, 2010 | Janome MyLock 634D Mechanical Sewing...
Thread wont overlock
When the thread breaks too often, try these, that goes for all sewing machines
1. Replace the needles,
2. Loosen slightly the tension of the needle threads.
3. The top threads are to thin,
4.The sewing (rotary) hook or looper, has burs,
5. Wrong threading
May 21, 2008 | Husqvarna Viking 1
Sewing Machines Logo
99 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
