Magicjack problems HOW TO TURN UP THE MIC VOLUME
  • 1,511 Answers
Volume is controlled at the Computer if the MJ is attached to the USB port. This means the Speaker Volume control (see lower right on your screen for the speaker icon) needs adjusting or the speakers volume control on the attach sound system needs adjustment. If it is a MJ+ that plugs into the Modem (or router) USB port or Cat6 line port; you can only adjust volume on your attached telephone.
Posted on Jan 03, 2014
I can hear perfectly the party I call or when they call me but they can never hear me clearly
This maybe due to "echo" n long distance calls.
magicJack works hard to ensure a clear connection.
If you experience an "echo" when using a magicJack on a computer:
  1. Go to "Menu" on the top right-hand corner on your magicJack softphone
  2. Click "Headset/Volume Control..."
  3. Lower the volume for both "Speaker" and "Microphone" to about 1/3 (one-third) of the maximum levels.
If that does not work:
  • Try plugging your magicJack into a different USB port.
  • Unplug your magicJack, restart your computer, and plug your magicJack back in.
  1. Unplug your magicJack, turn your modem and router ( if you have one) off and wait 3 minutes.
  2. Turn your modem and router back on and plug your magicJack back in.
If you experience an "echo" when using a magicJack connected to modem or router:
  1. Lower the volume on your telephone.
  2. Unplug your magicJack from the power source, wait 30 seconds, and plug it back.
Jul 20, 2014 | magicjack.com Computers & Internet
I am getting minimal to almost no sound coming from my mic to my computer.
If you are using the fx/send port to the mic-in port (I have no idea why you would want to do that) but nevertheless, check the red fx dial and make sure it is at 12 oclock and turn the pan dial to 12 oclock also. remember if you are using mic input 1 or 2 with a mic that requires Phantom power the button needs to be locked in the down position. OK im assuming you have checked and set your gain and volume levels on the 802 prior to plugging in your mic. If not do so now.(unplug all outputs and with mic plugged in speak into the mic while turning up gain until you get distortion which is indicated by a rewd light next to the "pan" button...once you see that light turn the gain dial back slightly and you should be set) have volume at 12 oclock on both l"evel1" and "main mix: dials. Now goto your windows desktop and right click on your volume control "speaker" icon. Click on "Playback device" you should see your mic in the list on enabled devices.If you dont see your mic in list right click the screen and click show disabled devices. Enable your device. If it is already enabled right click it and make sure it is not muted. finally go back to list of playback devices and right click your mic and click "configure speakers" run through the tests. close everything.mic should be working now. If it is not I suggest you plug your mic into either the line in from the fx/send or keep it in the mic-in port and plug the other end into the head phones port.Or better yet, get an rca to mini stereo jack and use the cd/tape out jacks to send your signal to the mic port of your computer......keep playing with it...you'll figure it out.There are so many different ways to hook up your perephrials its mind numbing sometimes.
Mar 16, 2013 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
My magic jack has suddenly lost its audio
If you are experiencing an issue with your audio or sound:
NOTE: Make sure that the volume is not turned off on your magicJack and/or telephone.
Please try connecting your magicJack to a different USB port and try again
Please try using a different phone with your magicJack
Please turn of your modem and router (if you are using one) for 3 minutes.
Then turn them back on again.
Now unplug your magicJack, wait 30 seconds, and plug it back in.
After it starts up again, try to make a phone call
Jan 06, 2013 | Computers & Internet
MagicJack used to work fine. But now the other person can't hear me. Why?
You cannot use the magicjack in this way. The magicjack is used to enable the telephone to be used instead of the computer.
Plug in the magic jack device when the internet connection is working and it should download the software to make it work.
Jun 04, 2012 | magicjack.com
My magicjack in comming calls are low an the phone volume is all the way up how do I fix?
Log into this webpage
http://www.magicjack.com/faq/
enter "Adjusting your volume" into the search box and you will see the answer is a pdf file to download to do the fix
It is 508kb long, it cannot be reproduced here.
Feb 04, 2012 | magicjack.com
My laptop has developed a high piched squeal if the volume wheel is turned up too high
If you have a built-in microphone, turn the mic volume down (right click the speaker icon on the bottom right of the taskbar, click "open volume control" then turn down the mic volume or mute it.
hope this helps.
May 03, 2011 | Toshiba Satellite L505-ES5042 Notebook
How do I turn on mic on toshiba laptop
if you are talking about the internal microphone and the sound is ok with all the rest ..than all you have to do is double click on the volume icon in the task bar (the speaker icon in the right where the programs sunning are shown ) and the volume manager with be shown ...if you do not see in the list any mic volume ...click on options in the left top ..and properties...a list will appear and you have to choose and tick on the case for mic...the mic volume will be shown in the manager ...see not to be mute and the volume on max...restart the computer and the mic should be ok ..
Jun 28, 2010 | Computers & Internet
Mic feedback. I sing on a shure beta 58 mic, into a 350 watt peavey amp, into 2 - 200 watt peavey speakers. My band is loud, and I simply cannot get my mic loud enough for them to hear me, without constant...
It sounds as though you are pointing the peavey at the band in a practice situation? If so make sure that each speaker is at about 60 degree angle to either side of the back of the mike (you facing the speakers), most mics reject feedback when the the user is directly in front of a monitor, but Beta 58s' tend to feedback more in that situation. Alternatively (if it is a practice room situation), why not place the speakers behind the band at 60 degrees each and turn to face the band.
Mar 12, 2009 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Microphone
HI,
OK, you need to do the following to turn off your Webcam Mic.
1. Right Click On Volume Icon in System Tray
2. Click Open Volume Control
3. Click On Options When The Mixer Appears.
4. Select Properties
5. Adjust The Volume For Recording
6. Then Just Look For The Mic Channel on the Mixer & Set it to Mute or if ut's not available, turn the Volume Fader for the Mic Right Down,
Should Have Something Like The Below Settings
Dec 12, 2008 | Microsoft LifeCam VX-3000 Web Camera
No Sound Coming out my Microphone
i know this might sound a little obvious and maybe irrelevant to the problem, but did you press the switch on the mic? it will turn the mic on and off. make sure sound and mic are unmuted in windows volume control. if both are these didnt solve the problem, test the mic on another computer. if the mic works, maybe its not the mic that has the problem. if the mic doesnt work, then your mic may be defective or damaged in some way or other.
Mar 28, 2008 | Philips PH62080 Uni-Directional Microphone...
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
