Question about Kitchen Ranges
My malbec cooker hood is making a slight hissing sound
3 Suggested Answers
sim4182
  • 393 Answers
SOURCE: my hp dv5 bronze model is having a screen problem.
screen cable is lose... open the on/off swicth button cover remove the cable of screen and fix again properly.. hope it will be okie...Thanks
Posted on Sep 14, 2010
  • 19 Answers
SOURCE: My pressure cooker always makes a hissing sound.
As long as the lid is properly locked into position it should be closed properly. A certain amount of air and steam will escape from the valve on the lid and will male a hissing sound but this is perfectly normal.
Posted on Jan 17, 2011
My car is jerking. It's a 2003 ford tarus. It also
Open the hood and find the source of the smoking. Check all the engine fluids-the oil level (and appearance-is it clean?) and the coolant level. If low on either, you may have a leak that is causing the smoking. The fluid may be dripping on the hot exhaust. Also check the transmission fluid and add if low. That may be the reason for the jerking. The hissing hose sound is usually a disconnected or broken vacuum line. That would not be causing the smoking, however. Just may make the engine run a bit rough, and the idle speed may be a bit higher than normal.
If the smoking has a burnt electrical smell, better have a shop check it out.
Aug 27, 2013 | Cars & Trucks
Tire leak hissing sound heard under hood from engine
Not the tires
Only makes a noise with the key on
or engine on
No idea without the car
Jul 23, 2013 | Nissan Cars & Trucks
04 Monte Carlo blinkers don't work makes hissing sound
Check the flasher, a plug in type relay under the dash.Find it and turn signal on while you are holding it and you will be able to tell which relay or flasher is bad.It may also be located under the hood.
Apr 24, 2013 | Cars & Trucks
No brakes making a hissing sound
where is hissing sound coming from under hood or behind tire the brake booster is a vacuum and another thing is a caliper may be leaking or maybe brake line
Dec 05, 2012 | 1996 Ford Thunderbird LX
Cooker hood installation
A cooker hood needs to done by a competent qualified Electrician but basically depending on your surface of the cooker hood.Depending on the type of cooker hood you have(extract or outside) If it is a extraction (meaning you are using filters and not connected to a vent) The Electrician needs to connect the electric to a point or spur via a power switch on the wall which when you fit up the main part of the hub covers the spur. after that you need to measure and fit the cooker hood to your requirements but make sure your walls can support it and mark off the holes before drilling or check the walls for electric wires in terms of safety.
May 21, 2012 | Washing Machines
My pressure cooker always makes a hissing sound. Is that close properly?
Jan 17, 2011 | Manttra 38131 8qts Stainless Steel
Strange noise when accelerator is pressed...
Look for cracked and gummy vacuum hoses. It's time to see if any are in this condition or disconnected entirely.
Jul 28, 2017 | 1997 Mercury Tracer
Dies when stoped, stars right buck up....
You have a vacuum leak.
Open the hood and start the motor and listen for a hissing sound.
Oct 21, 2009 | 2005 Chevrolet Cobalt
It make a hissing sound and then it shuts off
open the hood up and look for a missing vacuum port plug on the engine intake manifold, sounds like the case here, that would cause a really loud hissing noise.
Sep 16, 2009 | 1996 Buick Skylark
Engine is making hissing sound.
That hissing could be a vaccuum system leak, have youe tried pinpointing the sound from under the hood?
Feb 19, 2009 | 2005 Chevrolet Trailblazer Ext
Kitchen Ranges Logo
53 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
