Question about Acer TravelMate 5520 Notebook
Mic problem I have acer aspire 5520 whenever i chat my inbuilt microphone does not works when i try to set it there is message that it is running prperly can u please help
  • Frank Zhang
    Frank Zhang May 11, 2010
    it works ok if use a EXT MIC?
Hello I'm using accer extensa 5420 laptop, the problem is whenever i m setting up my inbuilt microphone of the laptop, its immediately freeze my laptop. i cannot touch the setting button also. same problem...
you could go for a clean re-install of your operating system,save and backup important data first.Re-formatt hard drive first,this most certainly will solve your problem
Mar 20, 2011 | Acer Extensa 5420-5687 Notebook
I am not able to turn the inbuilt microphone on in Acer aspire 4736Z while on a videocall with my friend on skype or yahoo msgnr. i can hear her but she cant hear me at all. also theres a constant...
It will be good to test the microphone in the sound recorder to see if the driversa re supporting , if not reinstall the drivers or choose to set to a earlier restore point.
If the mic is working good it must be seen if the Skype and messenger has some conflicts therby disabling the mic.
So take chance and uninstall the messenger to try if the fault clears.If not uninstall the skype and check with the messenger.
If the mic is not working at all it can be a hardware issue , a fault of the mic.
Sep 30, 2010 | Acer Aspire 4520-5582 Notebook
Acer aspire 5920 running vista has built in mic not working
Hey,
It is all because the Microphone is not set as a default device to start recording.
Its like your computer has no device for recording even if the computer has connected with Mic.
Just change the settings and enjoy..!!!
Check the below link:
How To Install and Setup a Microphone:
http://www.vista4beginners.com/How-To-Install-and-Setup-a-Microphone
Set up microphone:
http://www.microsoft.com/enable/training/windowsvista/srmic.aspx
Hope it helps.
Regards,
Nags
Jan 19, 2010 | Acer Aspire 5920-6727 Notebook
MY ACER LAPTOP HAS MICROPHONE BUT UNABLE TO HEAR THE VOICE WHEN WE CHAT TO OTHERS WHAT TO DO
Check if the microphone is set to mute. Go into your Volume settings and then uncheck if Mute is enabled.
Sep 11, 2009 | Acer Aspire 5500 5570-2609 Laptop
Hello, when i try to chat using YM or Windows Messenger on my Acer Extenza 4620Z running Vista, I can hear the other people but they cannot hear me. Can you please help with this. Is my microphone...
make sure you dont have the mic muted on the sound controls through control panel. Also both of these programs have preferences and you might need to check that your internal mic is selected as the input device.
Jul 11, 2009 | Computers & Internet
How to turn-on/function mic in my acer aspire one pc notebook?
To test the microphone, click "start" button, then "Control Panel", then "Sounds and Audio Devices". On the popup window that opens, click on the "Voice" tab, then click on the button that says "Test Hardware". After several seconds this will bring up a test program that will show a noise level meter when you're speaking into the microphone. (The default device listed under voice recording should be "Realtek HD Audio Input".)
Jan 31, 2009 | Acer Aspire One PC Notebook
CONNECTION TO SKYPE AND MICROPHONE
If you are using an external headset your Laptop should pop up the RealTek Management Window prompting for the device connection that the laptop has just detected and you will just click ok for mic and headphone and you are ready to run. The microphone on the laptop plataform and internal speakers work as well, I had no problems whatsoever.
Nov 14, 2008 | Acer Aspire 5500 5570-2609 Laptop
Headset and inbuilt speaker works at same time
Can you not just disable the built-in speakers in control panel while you're chatting on the mic?
-Aaron
Jul 30, 2008 | Acer Aspire 3680 Laptop
Acer TravelMate 5520 Notebook Logo
209 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
