Question about Huawei Cell Phones
Remove call barring - Huawei Cell Phones
HOW TO REMOVE A LOWER LEFT CONTROL ARM AND TORSION BAR
jack the vehicle right up so that the the wheels are clear of the floor . Place vehicle on jack stands
release the tension on the torsion bar by removing the adjuster in the arm. you may have to use Stiltons or pipe wrench to get the last bit of tension out of the bar . remove and retainers and tap the bar out of the splines.of the lower control arm. mark the bar so that you will know which spline to use for reassembly
remove the lower control arm.
Mar 02, 2015 | 2004 Ford Explorer Sport Trac
How to remove the chain from a husqvarna 235e chainsaw?
Like this or pretty close.
  1. Cock brake while expanding chain brake binder by pulling brake handle towards left-hand (wrap-around) handle grip, hard, until it locks in place.
  2. Loosen 2 brake-asssembly-and- bar retaining nuts but do not remove yet.
  3. Unscrew (turn CCW) bar adjustment screw on front face of unit in order to shorten bar and slacken saw chain.
  4. Slip chain off bar over bar tip and towards inward side of bar.
  5. Remove two nuts loosened in step 2 and pull brake assembly and bar straight out and off bar mounting studs.
  6. While rotating clutch/brake-drum, maneuver saw chain off sprocket and around drum perimeter to remove from saw.
  7. Repeat/reverse steps 6 thru 1 in that order to reassemble.
25045742-0m3nstwfcb55vn4usb1qox2f-3-0.jpg 25045742-0m3nstwfcb55vn4usb1qox2f-3-2.jpg
Sep 01, 2014 | Husqvarna 14-Inch 34cc Gas Powered...
Cannot see how to remove the chain bar
remove the two nuts on the cover and loosen the screw at the base of the bar on the engine. This tightens and loosens the bar. But makes it easier to remove the bar. Pull the bar out away from the engine and then toward the round thing where the chain is around the slip the chain off of the bar and engine and pull the bar off.
May 10, 2012 | Husqvarna 450 e-series 18" Chain Saw
Cant get bottom gray bar volume bar to go back to original size
hmm depending of the operation system you have .. it should let you down size it .. but if it does not .. it may be a problem with some tool bars being made and you have to remove them by right click on them and uncheck teh tool bar line .. or .. remove by the quick launch ..and will let you downsize it after that ..
the lock bar have to be removed also ..and to do that is the same procedure.. click right on the bar..and remove the lock task-bar ..After that try to see if it let you downsize it
Jan 29, 2012 | Microsoft HP Pavilion DV6276US Notebook PC
Beater bar not turning, but belt is not broken.
Remove the beater bar to remove the belt, then put the bar back into the sweeper. Check to see if it is bound up--usually the end bearings are packed with debris that prevents movement. Remove the bar again, and remove the bearings from the ends. Clean both the bar pins and the bearing blocks. Lightly oil the bearing blocks with 3-1 or similar light oil. Assemble the bar again and check movement. If ok, reinstall the belt and check sweeping action--if the bar stalls, replace the belt. Hope this helps!
Dec 18, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
What is the torson bar on jimmy and where can you get the part for it?
1995-2005 Models NOTE: The following procedure requires the use of the torsion bar unloader tool No. J-36202 or equivalent.
  1. Raise and safely support the vehicle.
  2. Remove the transmission shield, if equipped.
  3. Install a torsion bar unloader tool to relax the tension on the torsion bar adjusting arm screw; record the number of turns necessary to properly install the tool. Remove the adjusting screw and the unloader tool.
  4. Unfasten the lower link mount nut from one side, then disengage the torsion bars. NOTE: Note the direction of the forward end and side of the torsion bar being removed
  5. Remove the lower link nut from the opposite side.
  6. Remove the lower link mount, upper link mount nut, upper link mount and then unfasten the torsion bar from the frame.
To Install:
  1. Install the torsion bar and support.
  2. Install the upper link mount and mount nut.
    • Tighten the nut to 33 ft. lbs. (45 Nm) on 1995-96 models and 48 ft. lbs. (65 Nm) on 1997 and later models.
  3. Place a jack under the torsion bar to release tension, then install the lower link mount bushing and nut.
    • Tighten the nut to 13 ft. lbs. (18 Nm) on 1995 models, 50 ft. lbs. (68 Nm) on 1996-98 models and 37 ft. lbs. (50 Nm) on 1999 and later models.
  4. Install the torsion bar unloader tool and tighten the tool against the adjusting arm the same number turns recorded earlier, then remove the tool. This loads the torsion bars.
  5. Install the transmission shield, if removed.
  6. Remove the jackstands and lower the vehicle.
  7. Check and adjust the Z height as outlined in the wheel alignment portion of this section.
Jul 08, 2010 | 1997 GMC Jimmy
How to replace a sway bar end links to a 94 intrepid
REMOVAL & INSTALLATION
The rear suspension on LH platform vehicles is a fully independent suspension. A stabilizer bar (also called a sway bar) is mounted in rubber isolator bushings and connects the rear struts through links. Note that the fuel tank must be removed to remove the stabilizer bar.
CAUTION OFF. The fuel system pressure must be relieved before disconnecting any fuel lines. Failure to do so may result in fire and/or personal injury.
  1. Disconnect the negative battery cable. Relieve the fuel system pressure.
  2. Raise and safely support the vehicle.
  3. Remove both rear wheels.
  1. Position a transmission jack under the fuel tank just forward of the crossmember to help support the fuel tank when crossmember is removed.
  2. Remove the four crossmember to frame rail attaching bolts. Remove the fuel tank.
  3. Remove the stabilizer bar to link assembly attaching nuts and remove the bar and isolator bushings as an assembly from the vehicle. Inspect the isolator bushings for damage or excessive wear and replace, if necessary.
To install:
  1. Inspect for broken or distorted retainers and bushings. If bushing replacement is required, replacement bushings can be installed by locating the split in the bushing, prying open and removing the defective bushing from around the stabilizer bar.
  2. Install the stabilizer bar and isolator bushings back into the vehicle as an assembly making sure bar is centered in vehicle so it doesn't contact other suspension components.
  3. Install stabilizer bar attaching link onto stabilizer bar. Install new link to bar attaching nuts and tighten to 70 ft. lbs. (95 Nm).
Replace the sway bar bracket bolt with new after loosening or removing them. Only use original equipment bolts as replacements.
  1. Install the fuel tank back onto the vehicle.
  2. Position the crossmember on frame rails and install four mounting bolts. Tighten attaching bolts to 70 ft. lbs. (95 Nm).
  3. Remove transmission jack from under the fuel tank.
  4. Install the rear wheels and lug nuts. Tighten the lug nuts, in a star pattern sequence, to 95-100 ft. lbs. (129-135 Nm).
  5. Lower the vehicle. Reconnect the negative battery cable.
  6. Pressurize the fuel system and check for leaks.
  7. Check and reset the rear wheel toe to specifications as required.
Jul 03, 2010 | 1994 Dodge Intrepid
Replace broken sway bar for a 1996 ford windstar
Section 04-01: Suspension and Wheel Hubs, Front 1996 Windstar Workshop Manual REMOVAL AND INSTALLATION Stabilizer Bar Removal
  1. Raise and support the vehicle. Refer to Section 00-02 .
  1. Support vehicle with hoist or safety stands behind front sub-frame (5C145).
  1. stw~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: To avoid damage to the 6 mm drive hole in the front stabilizer bar link ball stud, do not use an Allen wrench to break loose or tighten or final tighten the front stabilizer bar link-to-shock absorber nut.
    Using care not to damage the front stabilizer bar link ball stud seal, remove the RH and LH front stabilizer bar link-to-front shock absorber nut.
  1. Using care not to damage the front stabilizer ball link stud seal, remove the RH and LH front stabilizer bar link-to-front stabilizer bar nut.
  1. stw~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use extreme care not to damage the ball joint boot.
    With another set of support safety stands under front sub-frame, remove two rear sub-frame retaining bolts. Lower rear of the front sub-frame to obtain access to stabilizer bar brackets (5486).
  1. Remove front stabilizer bar bracket bolts, stabilizer bar brackets, stabilizer bar bracket insulators and front stabilizer bar (5482) as required.
Installation
  1. Clean front stabilizer bar to remove dirt and contamination in area of stabilizer bar bracket insulator installation position.
  1. Lubricate inside diameter of new stabilizer bar bracket insulator with Rubber Suspension Insulator Lube E25Y-19553-A meeting Ford specification ESF-M99B112-A or equivalent. Do not use any mineral or petroleum based lubricants as they will deteriorate the rubber stabilizer bar bracket insulators.
  1. Install new stabilizer bar bracket insulators onto front stabilizer bar and position them in approximate location.
  1. Install stabilizer bar bracket on stabilizer bar bracket insulators and install new bolts. Tighten to 55-63 Nm (40-46 lb-ft).
  1. Raise front sub-frame and install new front sub-frame-to-body retaining bolts. Tighten to 115-132 Nm (85-97 lb-ft).
  1. Install front stabilizer bar link (5K483) to front shock absorber. Use care not to damage link ball joint boot seal.
    Install a new front stabilizer bar link-to-shock absorber nut. Tighten to 90-100 Nm (66-74 lb-ft).
Apr 28, 2010 | 1996 Ford Windstar
How do you replace a rear passenger side torison bar on an oldsmoblie alero 1999
SAFELY RAISE AND SUPPORT REAR OF CAR ON JACK STANDS. REMOVE THE TORSION BAR TO KNUCKLE BOLT WASHER AND BUSHING.REMOVE TORSION BAR TO CHASSIS BOLT.REMOVE BAR FROM THE CHASSIS.TO INSTALL.INSTALL TORSION BAR TO THE CHASSIS TORQUE THE NUT / BOLT TO 48 FT LBS.PLUS ADDITIONAL 120 DEGREE TURN.TORSION BAR TO THE KNUCKLE TORQUE THE BOLT TO 51 FT LBS.
Sep 24, 2009 | 1999 Oldsmobile Alero
Front Sway bar(Stabilizer bar)
please give good rating if this helps
Section 04-01: Suspension and Wheel Hubs, Front 1996 Taurus, Sable Workshop Manual REMOVAL AND INSTALLATION Stabilizer Bar Removal
  1. Raise vehicle on a hoist. Refer to Section 00-02 .
  1. sth~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use extreme care not to damage boot seal. Do not use power tools to tighten nut, or bearing and seal damage will result. Install nut using hex hold feature to prevent the stud from rotating.
    Remove and discard nuts retaining stabilizer bar link (5K484) assembly to front stabilizer bar (5482) and front shock absorber (18124) with an 8 mm closed-end wrench and an 18 mm open-end wrench.
  1. Remove nuts retaining steering gear (3504) to front sub-frame, and move steering gear off the front sub-frame.
  1. With another set of support safety stands under front sub-frame, remove two rear subframe retaining bolts. Lower rear of the front sub-frame to obtain access to stabilizer bar brackets (5486).
  1. Remove front stabilizer bar U-bracket bolts and replacestabilizer bar brackets and/or front stabilizer bar as required. Discard lower suspension arm stabilizer bar insulator (5493) and bolts.
Installation
  1. Clean front stabilizer bar to remove dirt and contamination in area of stabilizer bar insulator installation position.
  1. Lubricate inside diameter of new lower suspension arm stabilizer bar insulator with Rubber Suspension Insulator Lube E25Y-19553-A or equivalent meeting Ford specification ESF-M99B112-A. Do not use any mineral or petroleum based lubricants as they will deteriorate the rubber lower suspension arm stabilizer bar insulators.
  1. Install new lower suspension arm stabilizer bar insulators onto front stabilizer bar and position them in approximate location.
  1. Install stabilizer bar bracket on front sub-frames and install new bolts. Tighten to 30-40 Nm (22-29 lb-ft).
  1. Raise front sub-frame and install new front sub-frame-to-body retaining bolts. Position steering gear onto front sub-frame and install retaining nuts. Tighten to 115-135 Nm (85-99 lb-ft).
    Install stabilizer bar link to front shock absorber and to front stabilizer bar, making sure that the stabilizer bar link is properly positioned. The letters "Top LH" and "Top RH" are moulded into the stabilizer bar link for correct assembly to the front shock absorber strut.
  1. Install new nuts and secure stabilizer bar link assembly to front stabilizer bar and front shock absorber. Tighten to 77-103 Nm (57-75 lb-ft) at front shock absorber strut and 47-63 Nm (35-46 lb-ft) at front stabilizer bar.
  1. Remove safety stands.
  1. Lower vehicle.
Apr 11, 2009 | 1995 Ford Taurus
Cell Phones Logo
116 people viewed this question
Top Huawei Cell Phones Experts
Computer Repairing
Computer Repairing
honeybun1986
William Alequin
Are you a Huawei Cell Phone Expert? Answer questions, earn points and help others
