Question about Soleus Dehumidifiers
Does not draw water out of the air
Is not taking water out of the air
How do i fix it so that it will collect water?
1st ck that your humidistat is set correcly and unit cycles the compressor on/off correctly ,Not just the cirulation fan running all the time , next ck your filters , clogged up filters wont allow air to pull thru unit , also are you sure room has enough moisture in it to pull water from, Most units wont draw a percievable amount of water out of air thats got less than 52%rh , as most homes target a 70%rH as normal
Dec 18, 2014 | Dehumidifiers
Can it be used in toilet ? The walls are damp due to basement
It can be used in a bathroom in a safe place. It might taut of the bowel and drain traps but should not take any water out of the tank an air conditioner is a big humidifier so if you have an A/C you already have some moister being taken out. And a heating unit takes even more out then the A/C so I would say no problem.
Aug 28, 2014 | DeLonghi Dehumidifiers
Runs, water bucket switch works, but draws no water from the air. Could it be the charge? Can it be recharged?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 27, 2011 | LG LHD45EL Dehumidifier
My dehumidifier no longer draws water out of the air?
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Sep 29, 2010 | Haier DE45EAL Dehumidifier
It works but does not draw any water from the air
heatman101
Aug 24, 2010 | LG LHD45EL Dehumidifier
Hi I have a Danby DDR3008EE dehumifier that is putting water on floor There is ice inside where the filter is. What should we do besides turn off and let melt?
The coils you see on the back of your dehumidifier are the evaporator. When the unit runs, the coils get very cold. As the fan draws the room air over the coils, the humidity in the air condenses out of the air onto the cold coils. But, if the temperature of the air the fan draws over the coils is too cool, the humidity that condenses out of the air freezes on the coils. To remedy this problem, you can try any of these: Warm up the room the dehumidifier is in. Put the dehumidifier on a sturdy table (the room air is coolest near the ground). Turn the unit off until the room warms up.
Good luck.
Aug 14, 2010 | Danby DDR3008EE Dehumidifier
Danby preimere dehumidifier will not draw water from the air? No working?
heatman101
Jul 27, 2010 | Danby DDR601 Dehumidifier
Water condenses on top of dehumidifier
Your unit has a sealed system leak. The sealed system is warrantied for five years. Check your owners manual for this info. You will need your receipt and to call an authorized LG warranty dealer to exchange it.
Oct 06, 2009 | LG LHD45EL Dehumidifier
Dehumidifier making room very hot
Humidity, [Swetting] until the Room is totally dried out.Remember you are also drawing off infloor and underfloor dampness too.
Regards,DT
Aug 30, 2009 | Goldstar DH504EL Dehumidifier
Dehumidifier not removing water from air
Have you checkec, replace all the filters...?
Jun 24, 2009 | Haier HD656E Dehumidifier
Dehumidifiers Logo
32 people viewed this question
Top Soleus Dehumidifiers Experts
Gil Shultz
Terry Hair
 Russ Hill
Russ Hill
Are you a Soleus Dehumidifier Expert? Answer questions, earn points and help others
