Question about Dell Studio 17 (1749) Laptop black - Windows 7 Home Premium, 64bit, Intel Core i3-350M 2.26GHz, 3 gb... PC Notebook
Stdriver64 sys - Dell Studio 17 (1749) Laptop black - Windows 7 Home Premium, 64bit, Intel Core i3-350M 2.26GHz, 3 gb... PC Notebook
How to resolve error code f070 toshiba estudio 255
[F070] Communication error between system CPU and main CPU
(1) Check if the jumper pin setting on the SYS board / SYS-IMG board is correct. (Check if a jumper
pin is inserted between Pin 1 and Pin 2 of the CN 103 and the CN115.) Confirmation is not
necessary for the SYS-IMG board.
(2) Check if the harness connecting the SYS board / SYS-IMG board (CN131) and LGC board
(CN312) is disconnected or open circuited.
(3) Check the version of the system ROM on the SYS board / SYS-IMG board.
(4) Check the version of the engine ROM version on the LGC board.
(5) Replace the SYS board / SYS-IMG board.
(6) Replace the LGC board.
Nov 15, 2017 | Toshiba Office Equipment & Supplies
My 2001 catera out of the blue stopped running. I changed the crank shaft position sensor . I have been told it could be the gas cap preventing it from starting. the code P0455 comes up
VOTE FOR ME INFORM ME OF YOUR PROGRESS
P0450 Evap Emission Ctrl Sys Pres Sensor Error
P0451- Evap Emission Ctrl Sys Pres Sensor Range/Perf
P0452- Evap Emission Ctrl Sys Pres Sensor Lo Input
P0453- Evap Emission Ctrl Sys Pres Sensor Hi Input
P0454 Evap Emission Ctrl Sys Pres Sensor Interm
P0455- Evap Emission Ctrl Sys Gross Leak Detected
P0456- Evap Emission Ctrl Sys Very Small LeakDetected)
P0457 Evap Emission Ctrl Sys Leak (fuel cap loose/off)
P0458 Evaporative Emission Sys Purge Ctrl Valve Circ Low
P0459 Evaporative Emission Sys Purge Ctrl Valve CircHigh
P0460- Fuel Tank Level Indicator Circ Error
P0461- Fuel Level Sensor Circ Range/Per
P2408 Fuel Cap Sensor/Switch Circ
P2409 Fuel Cap Sensor/Switch Circ Range/Perf
P2410 Fuel Cap Sensor/Switch Circ Low
P2411 Fuel Cap Sensor/Switch Circ High
P2412 Fuel Cap Sensor/Switch Circ Interm/Erratic
Sep 17, 2012 | 2000 Cadillac Catera
Hello to everyone, I have been reading forums for
This is a typical sign of a defective hard drive.Your hard drive might or might not be repairable, depending on the degree of damage.
I would recommend that you use a live CD (such as this one: http://www.ultimatebootcd.com/download.html) to boot up your computer & run a hard disk diagnostic tool like HDD Regenerator. It might take several hours (sometimes days) to fix the damage. If this did not help, then you will have to replace the hard drive.
Jul 22, 2011 | Acer Aspire 4730-4516 Notebook
Spcmd.sys
The file "spcmd.sys" is known to be created under the following filenames: %System%\cc.sys %System%\dboy1.sys %System%\g3i2ll.sys %System%\setuplk.exe %System%\setuplk.sys %System%\spcmd.sys %System%\tencent.sys %System%\zzjkxs.sys %Temp%\xpanxionvirus\a1.exe %Temp%\xpanxionvirus\a2.exe %Temp%\xpanxionvirus\tmd.exe %Temp%\xpanxionvirus\tmd1.exe %Temp%\xpanxionvirus\tmd2.exe %Temp%\xpanxionvirus3\boot.exe %Temp%\xpanxionvirus3\cc.exe %Temp%\xpanxionvirus3\s.exe %Temp%\xpanxionvirus3\sc.exe %Temp%\xpanxionvirus3\se.exe %Windir%\a1.exe %Windir%\a2.exe %Windir%\s.exe %Windir%\se.exe %Windir%\tmd.exe %Windir%\tmd1.exe %Windir%\tmd2.exe c:\boot.exe c:\cc.exe c:\sc.exe Go to this link for more info http://www.threatexpert.com/files/spcmd.sys.html it is said to be of no threat.
Your timely rating of this soloution is much appreciated.
Thanks
Nov 01, 2010 | Computers & Internet
My hp dv4000 caps lock and scroll lk lights are blinking but the labtop wont come on, what do i do?
First take the battery out and disconnect all the cables from the sys and remove any accesories connect and press and hold the power button for 30 to 40 seconds. Insert the battery and power cord and try turning the sys on and keep tapping the F10 key to go to the BIOS screen. If the system boots to the BIOS screen than hit the F9 key to set BIOS defaults and turn on the sys, if the sys doesnt turn on than disconnect everything along with the battery. You will have to open the back of the sys and take the RAM and harddrive out and reinsert them back into the sys and than try to turn on the sys after the RAM and HDD is put back. If this time the sys doesnt turn on than the motherboard has gone bad, you will have to get it repaired.
Feb 20, 2010 | HP Computers & Internet
Acer recovery disk download
i keep getting this on my lap top and cant get ride of it can you help me??
Multi (0)disk(0) rdisk (0) partition (2)\Windows\AppPatch\drvmain.sdb
TRAP 00000006================EXCETION================
multi(0)disk(0)rdisk (0) partition (2) \WINDOWS \system32\DRIVERS\WMILIB.SYS
multi(0)disk(0)rdisk (0) partition (2) \WINDOWS \system32\DRIVERS\pci.sys
tr=0028 cr0=80000013 cr2=00000000 cr3=00039000em32\DRIVERS\isapnp.sys
gdt limit=03FF base=0003F000 idt limit=07FF base=0003F400compbatt.sys
multi(0) disk(0) rdisk(0) partition(2) WINDOWS\system32\DRIVERS\BATTC.SYS
cs:eip=0008:0009F737 ss:esp=0010:000600EC errcode=0000IVERS\pciide.sys
flags=00010012 NoCy NoZr IntDis Down TrapDis ystem32\DRIVERS\PCIIDEX.SYS
eax=00000000 ebx=00000100 ecx=0000BB40 edx=00030715 ds=0010 es=0010sys
edi=00060D4C esi=00000000 ebp=00060E34 cr0=80000013 fs=0030 gs=0000s
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\ACPIEC.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\OPRGHDLR.SYS
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\PartMgr.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\VolSnap.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\atapi.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\disk.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\CLASSPNP.SYS
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\drivers\fltmgr.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\DRIVERS\sr.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\KSecDD.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\Ntfs.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\DNIS.sys
multi(0) disk(0) rdisk(0) partition(2) \WINDOWS\system32\Drivers\Mup.sys
Feb 06, 2010 | Acer Aspire 5315 Notebook
System32/DRIVERS/pci.sys
ITS EASY JUST COPY THE FILE pci.sys from any other computer from System32/DRIVERS/pci.sys .SOUNDS FUN?BUT I KNOW IT WORKS
Mar 27, 2009 | Computers & Internet
All my usb ports are not working when i connect any pen drives or external hard disk or bluetooth deice my computer doesn't read them what should i do?
Plese make sure that your USB port is enabled in BIOS Mode,
if it is enabled make this steps....
Download USB Driver files....
usbehci.sys
usbport.sys
usbhub.sys
usbui.dll
usbccgp.sys
usbohci.sys
Feb 20, 2009 | Microsoft Windows XP Professional With...
Missing or corrupted file C:\windows\himem.sys
If you are running Windows 95, Windows 98, type:
copy himem.sys c:\windows <press enter>
If when typing any of the above commands you receive a prompt that the file already exists, ensure to overwrite it.
Reboot the computer; if the issue continues to occur, verify that the config.sys is properly setup. The line himem.sys should read:
DEVICE=C:\Windows\HIMEM.SYS
or
DEVICE=C:\DOS\HIMEM.SYS
Additional information and examples of the config.sys can be found on our autoexec.bat / config.sys page.
Dec 27, 2008 | Compaq Presario Notebook
Kstvtune.ax
ALCXWDM.SYS
portcls.sys
ksxbar.ax
kswdmcap.ax
vidcap.ax
vfwwdm32.dll
CCDECODE.sys
NABTSFEC.sys
WSTCODEC.SYS
ipsink.ax
MSTEE.sys
isapnp.sys
usbuhci.sys
usbuhci.sys
stream.sys
wdmaud.drv
ks.sys
ksproxy.ax
drmk.sys
ksuser.dll
I can't install my multimedia as these files are missing. I tried reinstalling the drivers but it needed these files which I can't download even after I have inserted the Windows XP Cd. Can you please help me with this also let me know how I can download these files from the net.
Jun 02, 2008 | Microsoft Windows XP Professional With...
Dell Studio 17 (1749) Laptop black - Windows 7 Home Premium, 64bit, Intel Core i3-350M 2.26GHz, 3 gb... PC Notebook Logo
22 people viewed this question
Alun Cox
