Question about LG 55LA6200
The screen of the tv turned off autimatically after 10, 20, 30,etc.. the sound of the is well actived (only screen failure).
I have a bought a new tv (10 days). After turning on the tv the screen of the turned off automatically (2,3,5,10,etc minutes. The sound system is working well, only the screen of the tv failed.
    Top Expert:
  • LG Master
  • 43,010 Answers
Probably the internal power supply is gradually failing.
Posted on Jan 01, 2014
rlamkin
  • 44 Answers
SOURCE: My LG-37" Flat-Panel LCD HDTV-37LC7D turns on automatically
The main board needs to be replaced.
Posted on Jul 03, 2008
gsalmen
  • 77 Answers
SOURCE: lg tv automatically turn on and off. Power surge
the software in the main control is damaged. call your lg servicer in your area. he might get you a software update
Posted on Jul 09, 2009
budmrtn
  • 11361 Answers
SOURCE: Screen goes black after a
It can be bad power supply module due to bad caps,
Bad Z sustain and Y sustain boards.
You need to check those 3 boards for bad caps, blown fuses, etc.
Parts: www.shopjimmy.com
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Dec 25, 2010
  • 11800 Answers
SOURCE: Just bought an LG Plasma
The tv is faulty and the fact that it failed immediately after you have started it for the first time is a clear indication of a manufacturing defect.
Take the tv back to the seller and ask for a replacement one or your money back.
Posted on Jun 01, 2011
jerryg50
  • 1689 Answers
SOURCE: lg 42le4500 tv when first turned on its okey after 2 minutes no picture black screen but sound ok, turn it off and back on againdoes the same
I would bet on some component(s) have become thermo sensitive. Most of the time capacitors can do this type of thing. Most likely the defective caps could be in the power supply.
To locate the defective caps, you would have to be able to run the supply and use the combination of a heat gun and freeze spray (liquid air spray) for cooling. At the same time you would have to monitor the output of the supply to see the components that cause the output change.
It is also possible to have thermo sensitive components on any of the other boards. This would also require proper troubleshooting.
The service rep would replace boards until he found the defective board. Then he would return the set with the new board and the bill for his work.
If your set is out of warranty, it may be better to consider a new set. Servicing these can be fairly involved and expensive.
Jerry G.
Posted on Jun 26, 2012
TV turns on; no other response
That clearly sounds like you have an audio/video board failure in the unit. I have seen Sony $2,000.00 dollar TV's do the same. The fact your getting Blue backgroung lighting is indicative that the panel is putting out light and you do have good power board connection. As a final test connect a dvd player to the inputs and see if you get the DVR screen display if negative get the TV replaced since it is only a week old.
I was a Sony Field engineer for a year on all TV models.
Dec 31, 2012 | Coby Televison & Video
Does not turn on
Do you hear sound? If not, check the input cable, cable connector etc for possible loose contacts. If these are ok, there is a power supply failure or secondary power failure inside the TV and might require an expert to look in.
Jul 07, 2012 | Hitachi CMP4121HDU 42 in. Plasma...
Hi.. Mine is a sansui tv and I bought it 3 years back. Now it is showing a horizontal line on the screen. Sound is fine but I can't see the picture, I just see one white horizontal line on tv...
The problem is vertical failure. Vertical output section to your TV ahs the fault. You ahve to check the vertcial output circuit for any component failure or loose solderings.
May 11, 2012 | SansuiS3275 TV
I changed the screen recently on the htc touch pro t7272 and i notice the screen is only showing sideways and wont turn pright what could be the problem is it soft ware or hardware
Could be both, could be either. Let's hope it is a software issue.
One obvious solution is... well... change it back! Then do a power-cycle. (feel free to remove the battery for a few minutes before powering on)
If it went back to being "upright" when the keyboard is closed, then it is a software issue.
You also have other "sensory"-related apps to activate to better diagnose the failure. For instance:
  • you can activate Keyboard Sliding sounds
Start--> Settings--> Personal--> Keyboard Sliding
Choose a sound (any sound), test it (make sure the phone sounds off with it), then activate it.
Then open the keyboard and close it to activate the sounds. If it sounds off, then it's a software problem.
Software problems are easier to fix:
1) backup your hard-earned data (contacts, calls, sms, mms, etc.)
2) then do a factory/hard-reset
3) Once control is given to you, restore the hard-earned data.
Soft-reset the device. Then enjoy.
Jun 20, 2010 | HTC Touch Pro Smartphone
Problems with mitsubishi WD 65737 tv is locked. what do we do?
problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture then the tv turns off the light on the front is now steady red. resetting the sytem worked yesterday but not today.
Oct 20, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Turn on TV no sound or picture just chirps
Get the chirping TV repair kit from www.TvRepairKits.com to fix this problem
Apr 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
Loss of sound
i know a person who can solve this pro. 9426467211
Mar 30, 2009 | Bush WS6671 28" TV
Brand new LG plasma stuck on test screens
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | Televison & Video
Help Please NO Picture!
The high voltage display power is down. First step is to measure the B+ voltage with a voltmeter to see if you have power to this section. It should be about 140 volts so don't touch it. Having this kind of failure after 3 years is unusual. Was there any kind of power surge etc that may have coincided with it?
Dec 31, 2007 | JVC AV-30W475 30" TV
..sounds like it is clicking on and off..on and off..etc.
How old is this TV?
Sounds like it has high voltage failure.
(If you hold your hand on the screen when you try and turn it on, do you feel the static? )
Unless the set is over 10 years old, I would overhaul the high voltage circuit. Should cost under $200 at a shop.
Dec 27, 2007 | RCA 32F531T 32" TV
LG 55LA6200 Logo
261 people viewed this question
Computer Repairing
Computer Repairing
