Question about Frigidaire FWS833A Top Load Washer
Washer will not fill up completely
Just purchased a new washer a week ago and it will not fill completely up with water, is only filling up to just under 3/4
  • ronniefl Oct 19, 2007
    tried that, did not work. We had the same exact washer before and it filled just fine. Got this new Fridgidaire top load washer and this one still isnt filling up after your suggestion.
  • John Dec 01, 2008
    I have a Roper RTW4340SQO top load washer. It does not fill all the way to the top anymore. It is about 2 years old.
  • 4,889 Answers
  • The drain standpipe is too short.
    To prevent siphoning, the standpipe must be at least 33 inches high for a top load washer or 24 inches high for a tumble action washer. Refer to the installation instructions that came with your washer for more information.
  • Drain hose fits too tightly in the standpipe causing siphoning.
    There must be an air gap between the drain hose and the standpipe to prevent siphoning action. The standpipe needs to be at least 1 1/4 inches in diameter.
Posted on Oct 18, 2007
  • eagle338
    eagle338 Oct 19, 2007
    Sorry for the info...Actually what happens is
    many new machines use what we would only describe as hardly any water,
    does it do the job properly, if so then fine leave it as is,
    this
    is calculated by computer so that the lowest level of water is used to
    do the job, hence the lowest amount of electric is used to warm it up,
    (a bit like filling the kettle to the top for one cup of coffee,its a
    waste)
    So it is not a problem..
  • eagle338
    There is a water level switch on the machine. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you should find it easily. You can either clear any obstruction in the tube or replace the water-level switch (easy to do it).
GE Profile Model WPRE8150K2WT will not fill up with water. Just had Harness fuse Kit replaced two weeks ago as agitation and spin had stopped working. Washer worked for two weeks and now this problem with...
check the back of you machine there is a little sieve where the water comes sometimes it gets blocked with dirt just clean it if not that its the water valve its is to change
Jan 27, 2014 | GE Washing Machines
Water refills when not on
We came home to a flooded basement because it appears the washer filled on its own when we were gone for several days and are in the middle of an investigation about why/how this happened. If anyone has any information on similar malfunctions please let me know. We purchased our machine on 1/22/05.
Sounds like there may be a mechanical problem and Maytag has some explaining to do...
Nov 25, 2011 | Maytag Neptune MAH5500B Front Load Washer
My older model kenmore washer only fills with water when the hot or warm setting is on. When it's set to cold, either washing or rinsing, it stops. It will still agitate once filled on any setting. It...
You have said it all. OLD.
time to give it up and get a new one.
first, the cost of figuring out what part is defective and getting a replacement part may take a couple weeks and couple hundred dollars for the repairman.
second, you will STILL have all old parts on the rest of the washer.
third, if you buy a new washer, you have serious expectations of it working properly for at least 5 years.
Mar 08, 2018 | Kenmore Washing Machines
As the washer fills, the water stream cycles, slow - fast.
YOU CAN GO TO LOWES IN THE PLUMBING SECTION AND BUY A PRESSURE RELEASE FOR THAT PROBLEM. JUST ASK THE LOWES PLUMBING GUY
Nov 03, 2009 | Washing Machines
Washer fills and starts for a while and then stops
I recieved the followng letter from sears last week since we had registered our OASIS He washer two years ago since we purchased it new. The washer has a serial number that is authorized to get a replacement board, and the part has been shipped to my house. Once it arrives, we are to call the local Sears dept for someone to install the new board.
For washers that have the first four of the serial numbers as:
CS48-CS52 or CT01-CT49 qualify for the replacement Control Board.
1-800-847-9083 between 8am-8pm M-Saturday.
Good Luck all.
Mar 24, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washer stopped filled with water, smells like burnt plastic
REPL/ PUMP BURNT PALSTIC SMELL ,AND RUBBER SMELL, ONCE REPL./ SHOULD FIX
Nov 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
6 months old. Now no water will fill drum! Works as normal but no water!
Hurlewan Your washer is still under manufacturer's warranty which is one full year. If it has Kenmore's name on it you do not need proof of purchase. The only thing you need is your mother-in-law's home phone number at time of purchase because Sears keeps all their records based on phone numbers. Good luck, Gendos post back....
Jun 27, 2007 | Kenmore 43142 Front Load Washer
Frigidaire FWS833A Top Load Washer Logo
150 people viewed this question
Top Frigidaire Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Sal De
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
