Question about Whirlpool ED2FHGX Side by Side Refrigerator
Refrigerator freezer freezes over every couple of week and gets all iced up. the refrigerator is a kirkland model number st18pkxhwoo
  • 42 Answers
This could be one of two problems, either the thermostat is faulty and there's little control over temperature ( you'll know this if the fridge is always humming away and doesn't turn off very often) or, the gasket around the door is worn or damaged, il explain, if the fridge isn't air tight or at least the freezer box the moister in the air will condense as ice, hence if you leave a freezer door open it will freeze over in no time! Now the thermostat is made up of two parts, firstly there is a sealed metallic bulb which contains a heat sensitive gas, when the gas expands it shoots down a very thin pipe to a switch , hens the name thermostatic switch, now it is common for these to have a short shelf life as they are always on off on off! some fridges and freezers have an anti freeze over function ( called frost free) Check to see that your drip tray is free from water, the hole is clear that the water drains down (usually at the back, and try and keep food which contains alot of water sealed and not just open, that should cut down the amount of water in the fridge. Drying clothes in your home causes alot of excess moisture in the air also. Good Luck the Yeti
Posted on May 20, 2009
The freezer section seems unable to get to -18 degrees in for the past couple of weeks, even on Super freeze. It has been fluctuating between -11 and -14 for the past week with Super freeze setting on...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 01, 2011 | Refrigerators
My Whirpool Bottom Freezer Refrigerator keeps collecting ice at the bottom of the freezer and eventually, every couple of weeks, leaks onto the floor. It does have an ice maker which is not hooked up. We...
The defrosting heating element may have burnt out. Also if the gasket around the door/drawer isn't sealing correctly moisture from the air leaking in could be condensing inside and then freezing causing the build up.
Please rate my response.
Jan 14, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
What is causing the items in the vegetable bin to freeze and the ice maker is not working,(ice melted in the bin) and the water dispenser is not working and the filter was just replaced a week ago /
Sounds like the source of your refrigerator freezer temperature problem is due to a faulty evaporator fan motor. This fan circulates the air from the freezer to the refrigerator and back to the freezer. When it fails, temps are warm at the top, cold at the bottom, so the ice melts, and the water tank inside the fridge, near the bottom, freezes. I looked up your model #, but it shows no results so i cannot give you a part number.
Also, its possible if you have a control board microcomputer, its bad as well. Some model GE refrigerators the fan burns out part of the computer, necessitating replacing both.
Oct 05, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Kenmore elite fridge. Bottom freezer ice builds
You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
Oct 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker wont make ice
CHANGE THE FREEZER TEMP TO -2 AND THE REFRIGERATOR TEMP TO 44 AND IT WILL START MAKING ICE AGAIN
Nov 25, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Kenmore Refrigerator Freezing Up - Won't Defrost
i have a side by side kenmore frig freezer on th frig side the pop is freezing up and the water that comes out the door whtat could be wrong
Oct 12, 2008 | Refrigerators
Kitchenaid superba ice freezes in the bin
The temperature of your freezer is probably set to low allowing the ice to melt a bit, then refreeze. Try setting your freezer temp a bit lower. That should fix it.
May 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool ED2FHGX Side by Side Refrigerator Logo
253 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
