Question about HP PhotoSmart Cameras
Tutorial hp m627 camera
Error log 1
    Top Expert:
  • HP Master
  • 6,702 Answers
Are you looking for this?
Link to user manual
Posted on Jan 01, 2014
SOURCE: camara hp m627
la camara cuando enciende dice error lens: m627-30 que significa eso y como puedo repararla
Posted on Jul 31, 2008
marked
  • 6487 Answers
SOURCE: HP Photosmart M627
Try a reset follow this:
Open the Battery/Memory card door and remove the memory card.
Remove the power source form the camera.
If powering the camera with batteries only, remove the batteries for approximately 15 seconds.
If using an optional HP AC power adapter only to power the camera, disconnect it from the camera for at least 15 seconds.
If using batteries and the HP AC power adapter, remove both for at least 15 seconds.
Reinsert the optional memory card.
Reinsert the batteries and/or reconnect the HP AC power adapter to the camera.
Close the Battery/Memory card door.
Hope that helps.......
Posted on Aug 01, 2008
VOTIT
  • 2071 Answers
SOURCE: lens error m627-30
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras AV cable, and turn the camera on in picture review mode. Have no idea why this would work, except that quite a few people have reported some success with it.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera. The following photo illustrates unseated guide pins that would cause a lens error.
DON'T FORGET TO RATE;
Posted on Aug 25, 2008
  • 1162 Answers
SOURCE: I dropped my hp photosmart m627 and now it says
The only fix I kow of is to take the camera apart and set the gears on the lens correctly. You are going to need a small set of phillips and stright screw drivers, and a soldering iron.The back comes off easy enough, the next thing it to remove the screws on the back of the main board. the screws on the top function board. and then unsolder the two tabs on the top of the main board that connects to the battery compartment. Be sure to unsolder the correct ones. Once this comes off the camera lens is pretty easy to figure out. Just take the motor and gear section apart and set it correctly. I have done a few that when I just turned the barrell of the lens, I heard a snap and it worked fine. You may have to take it apart. If you need more help contact me at cwradio73 at gmail.com
Posted on Aug 04, 2009
  • 1162 Answers
SOURCE: my camera has error 31
Your problems most likely came from it being dropped. The fix is time consuming but well worth it since this camera is a nice one to use. You are going to need a set of small screw drivers philips and straight. Also a soldering iron. Take the back off. Easy enough. Then remove the obvious screws you can see. Heat the iron up and remove the solder joints at the battery compartment. there are two and if you have taken all the screws out it will fall into your hand. Dont forget to remove the screws on the top board as well. If you turn the barrell on the lens you might hear a snap and that is a sign the lens has fallen back on to the track. If not take the screws out of the gear box and set the track on the barrell of the lens. This is not all that hard I have done several. Different cameras use different ways of getting to the motor drive. Most you dont have to unsolder, but with this one you do. I love this camera and it is worth the effort to fix. Write if you have problems
I have a hp photosmart M627 camera. When I turn it on, the lens stays in and comes up on screen with a lens error:M627-31. Can you help please.
<div class="solution-text"> <span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution">Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.<br><a href="http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html" target="_blank" rel="nofollow"><br>http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html</a><br><br><b>Fix #1:</b> Remove the batteries fromthe camera, wait a few minutes. Put a fresh set of batteries back in(preferably rechargeable NiMH 2500mah or better) and turn the cameraon. If that didn't work, try pressing and holding the Function or OKbutton while turning the camera on. <br><b>Fix #2:</b>If the camera's batteries ran down completely while the its lens wasstill open, the camera may show a lens error or not start properly whennew batteries are installed. Remove the memory card and keep itremoved, then install the new batteries. When you turn the camera onwith the card removed it may come back to life, as this triggers areset in some cameras. Error E30 (for older Canon's) means that youdon't have a memory card installed, so turn it off, slip in the <a href="/support/t5307069-lens_error_lens_not_open#" target="_blank" rel="nofollow">SD card</a>and turn it on one last time </span> </div> <!-- /solution text --> <!-- helpful bar --> <span class="br"></span> <!-- /helpful bar --> <p class="add-comment"> <a id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_add-comment-form1_lnkHeader" onclick="javascript:ShowHideForms('ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_add-comment-form1');" lang="6652"><br></a> </p>
Aug 24, 2010 | HP PhotoSmart M627 Digital Camera
HP Photosmart M627
Try first removing battery and putting back.
Aug 01, 2008 | HP PhotoSmart M627 Digital Camera
Hello, i have a problem with my camera hp m627, have an lens error 627-30. help me please!
When a lens error occurs, it is generally due to a 'binding' of the gear inside the camera which needs to be serviced by hp.com.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00864899&tmp_track_link=ot_faqs/top_issues/en_us/c00864899/loc:3&lc=en&dlc=en&cc=us&product=1147860&lang=en
The above tells how to do a power reset, but if that doesn't work then try to have it serviced by hp.com.
Call 1-800-HP-INVENT
Aug 14, 2010 | HP PhotoSmart M627 Digital Camera
Lens error m627-31 hp photosmart camera
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 30, 2009 | HP PhotoSmart M627 Digital Camera
Lens error m627-30 turnt on camera then the lens will not open screen displayed m627-30
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 11, 2009 | HP PhotoSmart M627 Digital Camera
Jan 18, 2009 | HP PhotoSmart M627 Digital Camera
Lens error M627-31
Took camera to my local camera shop for advice and repair very fast response from them
Oct 14, 2008 | HP PhotoSmart M627 Digital Camera
Camera hp m627
Jul 09, 2008 | HP PhotoSmart M627 Digital Camera
Camara hp m627
Error code M627-31 WHAT'S THIS?
não sei o que aconteceu com minha câmera da HP, quando ligo aparece a seguinte mensagem?: Lens Error: M627-31
Mar 23, 2008 | HP PhotoSmart M627 Digital Camera
Cameras Logo
24 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
