Question about Philips 42PFL5603D 42 in. LCD HDTV
No sound via TV when PC connected
Hi, I've recently updated the firmware on my 42pfl7603d and since then when my PC is connected I don't get any sound, i've assigned the audio input to HDMI 2 etc. and tried connecting my ipod for an alternative sound source and cable but no luck. I'd appreciate any help! Thanks, Andrew
  • andybrown33 May 22, 2009
    The PC output is DVI and it goes into the TV as a HDMI, I also have a 3.5mm jack at both ends, one of which goes into the PC input on the TV.
    Thanks for your interest,
    Andrew
  • OT Bobby May 11, 2010
    Andy
    Is the PC Video Output DVI or HDMI
    Sniper:
  • 105 Answers
1. Ensure the TV is set to "home" mode in the user menu. If set to "Shop" it will not retain audio settings change
2. verify that the Audio out from the PC is working. Use a set of headphones just to verify
3. Triple check that you have the audio input assigned to the correct HDMI input
4. after doing these if it still doesn't work, I would suspect the Software update had a side affect that phillips is not aware of. Since this function would probably be missed by Phillips software testers, it is highly likely that this is possible. Contact phillips and let them troubleshoot the problem with you. Let them know it happed after you did the update also and let them know that you have verified the audio out from the PC.
Posted on May 22, 2009
Why did it freeze during software update?
Here is some help on a Sharp Aquos. You pull the plug and update manually.
Sharp Aquos Firmware Update Issue and Resolution I recently had problems with my Sharp Aquos LC-60LE632U and firmware update 311U1204061. When I attempted to run the Netflix app, I was told that I couldn't proceed unless I updated the firmware. After 2 attempts to update the firmware via the network, I turned to Google and found that this was a common problem. In order to resolve the issue, you'll need to update the firmware manually, via a USB thumb drive. See the following instructions:
  1. Go to the Sharp USA product download site
  2. After you choose your TV model, download the firmware file
  3. View the rest of the instructions found here
Info found here
http://www.avsforum.com/forum/166-lcd-flat-panel-displays/1436990-sharp-aquos-frozen-when-updating-software.html
Oct 03, 2015 | Televison & Video
Dell Studio 1537 to Panasonic Viera via HDMI. Everything is working alright except for the annoying bugging sound popping/crackling in the backround. I've already solved display resolution, audio...
Are the screen and computer sharing the same power supply, on a 4-gang multiplug or similar?
What else is plugged in to the same supply?
Have you got another HDMI cable to try this with?
How is the audio connected - can that be changed to test it?
Have you another laptop or PC that you can connect to see if this is the TV or the laptop causing the issues?
Jul 27, 2011 | Dell Computers & Internet
My 22 lcd gives good picture but no sound.I've tried connecting an externel head phone but i don't hear any sound.
you're best bet is, depending on your TV's input/output, is to run your video components directly to TV via HDMI, component, etc., of course component requires additional sound cables, then run your sound out from TV via, best, digital optical, to reciever. You use the TV's menu to choose what you watch and, only have the one audio out. Scan your recievers menu to make sure you've got the right channel to listen to.
Jun 28, 2011 | Audio Players & Recorders
Hi, my reader is saying "android.process.acore has stopped" Force closing won't work. I know firmware update via zip file is available but it's midnight here and I don't have an sd card handy....
Sorry to hear your are having issues with your Cruz Reader. I have a Cruz Reader R101. Unfortunately you have to update via the SD card for the Cruz Reader. It doesn't do a firmware update from the USB cable.
If you don't want to try and update it now you could also try to just restart it. If you can't get it to restart normally you can remove the back cover and unplug the battery, then plug it back in.
Apr 25, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
I am connecting Yamaha DVD player to the Vizio M420 NV via HDMI. i have a picture but no sound. how do I gain audio when using HDMI?
HDMI has both Audio and Video (High Definition Multimedia Interface) and should carry both. However, I had this problem with a client just the other day and it turned out that the firmware on his TV needed to be up[graded. Different model TV, but I believe you may need to download the latest software/firmware update via your PC and put it on a flash drive and then flash the firmware on your TV to get it to work. Sorry I don't have the specifics; I was stumped and the Time-Warner guy ended up doing it. I hope this at least sends you in the right direction.
James
Apr 17, 2011 | Vizio Televison & Video
I have a Hitachi p50v701 50" plama tv. Recently
I know it Sounds silly I also have a Hitachi TV and got issues with HDMI, I unplugged from wall for 15mins and turn it back, then I tried my PS3 and worked.
If not there is a firmware update on the website however it needs to be uploaded by a "technician" via USB drive mine has a USB port but there is no update for mine.
Let me know if it works
Mar 16, 2011 | Hitachi P50V701 TV
My psp ver 4.01 is not working. Help me guyz!
psp firmware is corrupted, you be need to continue thats update..
1. update via UMD, the umd that are use must have same firmware version or higher (5.03). check it in other psp. make sure you have a fully battery, then turn on psp.
2. update using sony media go, it a pc client for sony device.. connect psp to pc via usb cable, you will need a internet connection on pc. and it will update to the latest version - 5.51.
hope this help..
Aug 28, 2009 | Sony PlayStation Portable (PSP) Console
I am using my xbox 360 via HDMI, and I have a 5.1 surround sound system hooked up via RCA output from the tv. If I switch it onto the coax input it works, but when I switch to HDMI it doesnt. Is there a...
no, there's no firmware upgrade that you can do on the tv. the reason for that is because you are sending digital sound to the tv with hdmi from xbox 360,and when you have rca cables connecting your tv and surround sound, the rca cables provide stereo sound. what you need to do if you want to use hdmi is connect optical cable from tv orxbox 360/ or tv to your surround sound to get digital sound, and it will sound better digital sound.
Apr 17, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Samsung HT-X40 System Problem
I received an e-mail from Samsung which reads
"What you have described in your e-mail was an issue that was logged and has been investigated we have released a firmware update to resolve the issue"
also
"In order for the firmware to be updated on the unit please call our product support team on 0870 726 7864 for assistance"
Dec 16, 2007 | Audio Players & Recorders
Philips 42PFL5603D 42 in. LCD HDTV Logo
498 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
