Question about Minolta magicolor 2300W Laser Printer
Hello! I have a Magicolor 2300W that has been standing unused for some time and it won't print correctly. The printer feeds paper from the tray, it goes through the printer, comes out at the top - but just before the sheet of paper is released (ejected) into the collection bay at the top, it stops. The paper seems almost fully printed, but why does it stop there? And the printed image/text looks a bit shifted, the first 2 inches of the paper are plain and at the bottom those 2 inches are missing. When the paper stops ejecting, the printer reports "paper jam transfer rollers". However, it is very easy to pull the last bit out of the printer, so it isn't really stuck. After closing the door/right side of the printer to reset the jam I'm getting either a "paper size mismatch" or "put media:tray 1 A4" error. Maybe not important, but maybe good to know. Aditionally, I'm having problems printing color on it. In color modes (not monochrome, that seems to work somewhat) only some faint shades of cyan appear, a hint of magenta and no yellow.
    Problem Solver:
  • 11 Answers
1. Check the paper size your printing on and whether the Same is used by printer or not 2. Try shaking the cartridges as they may have got stuck at their places for long time 3. Try legal or a4 or letter size for paper
Posted on Jan 01, 2014
4 Suggested Answers
kevin000
  • 1847 Answers
SOURCE: Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
Posted on Sep 09, 2008
Benimur
  • 6966 Answers
SOURCE: magicolor 2400w won't feed paper
Hi and welcome to FixYa,
Offhand, your described problem indicates a possible mechanical issue. In most printers, there would be a rubber wheel (or half a wheel in some) that grabs the end of the paper to provide the initial push through the paper path/rollers. If the unit has been in use for some time, it may be then wear & tear, the rubber has considerably worn out that it no longer provides sufficient grip. Alternately, it may be that this grab/rubber wheel just needs a bit of cleaning.
Pls post back results of cleaning. Good luck and thank you for using FixYa.
Posted on Jan 26, 2009
DLBurkhart
  • 210 Answers
SOURCE: qms 2200 paper mismatch error
Initial Thoughts
The problem seems to be a fault in a paper feed sensor. This would explain the size mismatch, since these sensors are how the printer detects the paper size. And, it would explain why printing starts two-thirds down the page, since these sensors are also used in timing where on the page to start printing.
However, a document passes through three software applications before it actually prints. And, any one of them could be causing the paper size mismatch.
Insight
Although paper sensors are usually low-tech and easy to remedy, they are often difficult to find and can sometimes be difficult to get to. Most such sensors are simple switches (toggles) and others are optical sensors that work like the electric eye of a garage door opening system. And, the solution may be as simple as a tiny piece of paper stuck on one of them. However, sensors such as these are quite numerous on this printer and can be hidden anywhere.
The three software applications I referred to are:
1. The document rendering application, such as Adobe Reader, Microsoft Word, etc.
2. The print writer. This is part of the device driver software package. It breaks up a print request and converts it to a standard format that the printer will always recognize and manages transmission of each page to the system spooler or directly to the printer.
3. The printer firmware. I'm not sure of everything this does related to the print stream. But, part of it must manage resources, such as ensuring the right size paper is being fed.
Posted on May 16, 2011
Paper Jam at Tray 1
The solenoid may be getting stuck, the only way to check is to remove the solenoid and check that it opens and closes smoothely.
May 26, 2013 | Minolta magicolor 2300W Laser Printer
Konica Minolta Magicolor 2300W not transferring toner to paper.
Clean the paper feed rollers,the fusing unit rollers and print the blank page(min.10-15) for clean the upper fuser hot roller.Agiting the toner.
Jan 28, 2013 | Minolta magicolor 2300W Laser Printer
I have Minolta 2300W Laser Printer and it folds the first page only about 3 to 4 inches down makes a nice one inch fold but take that out and print again...next page fine.....now printing with two wide...
The is blocked by dust on the side of the paper on the image unit that would have color associated with the print. Remove all the image units and clean all the laser glass. Replace those image units also if streaking as for the paper ensure correct paper side and media type.
Jul 12, 2010 | Minolta magicolor 2300W Laser Printer
Konica Minolta Magicolor 2300W firmware needed
firmware is located on secure web site try having a Konica Minolta tech come out and flash the firmware
Apr 15, 2010 | Minolta magicolor 2300W Laser Printer
Printer error shows paper jam at paper tray and printer stops after printing 3 or 4 pages. I open and close the top access and printing resumes for 3 or 4 more pages...stops and shows paper jam at feed...
Try two things:
Fan the paper before placing in the tray.
Raise the humidity in the room to at least 40% to avoid electrostatic sticking of the paper. Store paper in 40% humidity area.
Dec 16, 2009 | Konica Minolta magicolor 2400 Laser...
Minolta Magic Color 2300dl printer won't print legal size documen
Is tray one the bypass tray or a tray. check which one is tray 1
Nov 24, 2008 | Minolta magicolor 2300W Laser Printer
Magicolor 2300DL Question?
One thing you should try first, is open the paper width guides( paper loading tray), as if they are set too tight that will cause the paper not to lift up to the pickup roller.
Delboy
Aug 15, 2008 | Konica Minolta MAGICOLOR 2300W LASER...
Paper jam, cleaner kit
If the paper is not situated perfectly in the tray, and it cannot grab the top sheet easily, mine will give the paper jam message. I just adjust the paper in the tray, then open one of the doors, front or back, and close it again, and it usually fixes the "Jam".
Jun 23, 2008 | Minolta magicolor 2300W Laser Printer
Printing is crooked
if paper comes out straight, and lines in paper are not straight then there is problem wit laser unit, its not installed corrrectly, also you can check drum unit and transfer belt for correct installation.
Apr 27, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Minolta magicolor 2300W Laser Printer Logo
242 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
