Question about Dishwashers
Beem leakage error 4 - Dishwashers
The headlight on the pass. side works right. the drivers side when in low beem, the light is in high beem. when the light is on high beem the light is on low beem. this is a 2000 mercury sable
someone has switched the wiring harness sockets to the wrong bulbs or installed the bulbs in reverse. get in behind the headlight assembly on the driver side and reverse the wires, if that does not work then pull the bulbs and swap them inside to outside and vice versa.
Jun 10, 2011 | Mercury Sable Cars & Trucks
1998 Camry Low beams work fine but when i switch to high beam i loose all lights
the relay for your highbeem lights is bad, replace it and you should be good, or you could just switch the high beem relay, with the low beem relay, they are the same, and if the high beems work like that you know its full proof, if not... well you know, we will hafta move to something else.. hope you find this helpful
Dec 04, 2010 | 1998 Toyota Camry
I have a 1997 F-350 with a 7.3 and lately while I am driving my headlights only turn off and some times I can push the switch in one click and then pull it back out and the lights come back on, other times...
Sounds like the contacts in your switch are going bad. The switch in your high-low beam lever is extremely hard to get to as the steering column will need to come out, if it's the style I recall on a 97. The switch you may be able to find on the web somewhere because if you get it from ford it may be pricey. You will probably need to take it to your local service center to be replaced.
Nov 17, 2010 | Ford F-350 Cars & Trucks
Low Beems are out. I changed both bulbs and the
DIMMER SWITCH OUT OF ADJUSTMENT.I SEEN CAR WITH SAME PROBLEM THEIR HIGH BEAMS WOULDNT WORK.THE DIMMER SWITCH AND BULBS WAS GOOD.IT TURNED OUT TO BE DIMMER SWITCH NEED TO ADJUSTED.
Mar 21, 2010 | 2005 Chevrolet Monte Carlo
2005 Trailblazer, Low beems will not work high beems do
Pull plastic cover off of column ck where wires mate to multi function switch and switch for traces of heat . More than likely switch is bad.
Jun 16, 2009 | 2005 Chevrolet Trailblazer Ext
High beems and washer Fluid
Possibly a muti-function switch.
Mar 02, 2009 | 2002 Dodge Grand Caravan
L head light low beem not working
You probably have the low side of your bulb blown check the bulb if that dont fix it ck your conector.if your dimmer switch was bad it wouldnt work on eather side. I will try to get you a diagram for the fuse box. PHIL.
Jan 06, 2009 | 2003 Ford Explorer
Dishwashers Logo
91 people viewed this question
Top Dishwashers Experts
