Frigidaire manual I can't change the temperature control number. Currently its set at 0
milten1
  • 1304 Answers
SOURCE: No temperature numbers on oven dial
1=100
11=485
approx 50 degreesbetween settings
Posted on Oct 06, 2009
TheMobilian
  • 8220 Answers
SOURCE: temperature control panel beeping
DIRECTIONS
Posted on Jan 28, 2010
  • 3246 Answers
SOURCE: I have recently been installed with new central
0 t0 5 is the range just set the to what number gives the temp you like in that room thats it
Posted on Nov 27, 2010
richroth
  • 9472 Answers
SOURCE: Frigidaire freezer FFU21F5Hwg not running although electronic panel displays normal temp setting
Does the compressor kick on?
Posted on Nov 10, 2012
Testimonial: "The technican very quickly diagnosed the problem after receiving an answer to his request for additional information following our original posting. Very impressive............ Thank you."
kachbibi1
  • 979 Answers
SOURCE: I can't find the temperature control knob! I have a Frigidaire upright freezer model number LFFH2067DW2.
Otherwise it would never stop freezing. Let me know what you find out.
Posted on Mar 03, 2013
Manual for GE profile pfss5njw/pfsf5njw for setting temp.controls.
Most GE appliance manuals are available through their support site: http://www.geappliances.com/ge/service-and-support/literature.htm. The manuals for the PFSS5NJW and PFSF5NJW are here: http://products.geappliances.com/appliance/gea-literature-search?Ntt=pfss5njw&x=0&y=0 . The direct link to the Use and Care Manual is currently http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60489-2.pdf .
To change the temperature setting for the refrigerator, press and release the appropriate Warmer or Colder touch pad. Press several times to reach the desired temperature setting. (The freezer control is on the left.) Note: As you cycle through the temperature settings, it is possible to set the cooling to OFF. See page 4 of the manual to see these directions.
I hope this helps.
May 23, 2017 | GE Refrigerators
Why is my freezer on 0?
Good Afternoon Friend, this is Z. That's a great question!
Depending on the model number of your Frigidaire freezer, "0" could indicate two scenarios. First, if it is set to 0 (zero) that could be the temperature it is set at. On some models, "0" means that your freezer is in the off position. You can re-start your freezer by pressing and releasing the "UP" arrow 3 times. If it continues to display "0", press and release the "DOWN" arrow 3 times. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your freezer status has change successfully. Thank you!
Jul 24, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
What should the freezer temps be on Frigidaire Galaxy models
I understand you want to know what the freezer temperature should be set on for your Frigidaire refrigerator, model# FGHB2844L. Per the manual, the suggested temperatures should be 37 degrees F for the refrigerator and 0 degrees F for the freezer. Hope this is helpful.
-Best Regards-
WP
Jun 29, 2014 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
What temperture should i set my frigidaire digital display freezer to
I understand that you want to know the temperature to set your Frigidaire freezer. Recommended factory default setting is 0 degrees F. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your Frigidaire status has changed successfully. If more troubleshooting is needed, please leave me your model number in your comment. Hope this is helpful.
-Best Regards-
WP
Jun 15, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire PLHS67EGSB1, the digital guage to set the tempoearture keeps chaning. set it at 0, day later might read 16, one tap down and goes back to 0. Next day might read 8, same thing. What can cause...
Most likely the=> 241608401 Thermistor and the=> 241608501 Freezer Thermistor You will need to begin somewhere and with the symptoms you are having it brings the controls the regulate temperatures to the top of my list for what may be causing this. PLHS67EGSB1 Controls item 21 and 21A are the thermistors I am here should you have questions, Thanks, John Tripp Appliance 911
uploads>parent.mediatoolbar.onimageuploaded('error with image');
Feb 13, 2014 | Frigidaire PLHS67EGSB Stainless Steel Side...
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a Skytech 3301 for a propane stove with some thermostat problems.
Great question! It sounds to me like the Skytech's swing temp setting may be out of whack.
Here is a quick link to the product page with a link to the owner's manual at the bottom if you need: Skytech 3301 Fireplace Remote.
Below is an excerpt on how to check and modify the swing temp settings for the Skytech 3301. (I apologize if the copy/paste formats poorly).
The Thermo Mode on the transmitter operates the appliance whenever the ROOM TEMPERATURE varies a
certain number of degrees from the SET TEMPERATURE. This variation is called the "SWING" or
TEMPERATURE DIFFERENTIAL. The normal operating cycle of an appliance may be 2-4 times per hour depending on how well the room or
home is insulated from the cold or drafts. A smaller "swing number" increases the number of cycles so the room temperature is more
constant. A larger "swing number" decreases the number of cycles, which saves energy, in most cases. The factory setting for the "swing
number" is 2. This represents a temperature variation of +/- 2
0
F (1
0
C) between SET temperature and ROOM temperature, which determines
when the fireplace will be activated. The "SWING" number values are:
1=+ 1
0
F (.5
0
C), 2= + 2
0
F (1
0
C) and 3 = + 3
0
F (1.6
0
C).
SETTING THE TEMPERATURE SWING (TEMPERATURE DIFFERENTIAL)
1. To change the temperature "SWING" setting (1-3), press the TIMER/TIME and DOWN buttons
simultaneously to display the current "SWING" setting in the SET TEMP frame. The letter "S" will
display in the ROOM TEMP frame on the LCD screen.
2. Press the UP or DOWN button to change the temperature differential or "SWING" (1-3). See above
for 1-3 "SWING" temperature valves.
3. To store the "swing number press the SET button or allow 15 seconds to lapse, and the new "swing
number' will be automatically programmed.
MANUAL CHECK OF " SWING" OR TEMPERATURE DIFFERENTIAL
The operation of the factory set "THERMO SWING" can be checked by adjusting the SET TEMP 2
0
F above or below the room temperature.
This will cause the system to turn ON or OFF. Normally the system will only respond to temperature changes every two minutes. Manually
changing the SET temperature will activate the system in less than 10 seconds. IF the "SWING" is changed, then a new room temperature
differential will respond. Factory setting of "SWING" temperature is 2
0
F.
Jan 17, 2013 | Skytech 3301 Thermostatic Gas Fireplace &...
OVEN WILL NOT COME UP TO TEMPERATURE
You can calibrate the oven on this model. Press the bake button, adjust the bake temperature up to 550 degrees and then press and hold the bake button until a 0 displays. Now you can adjust the oven temperature up or down to match the display.
Here is a repair manual link that you can use to download frigidaire repair manuals. The one for 30 inch freestanding ranges will have the section on calibrating the oven's electronic control.
Thanks
Jan 09, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Heating & Cooling Logo
105 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
