Question about HP Photosmart 7450 InkJet Printer
I put paper in the printer, but it will not recognize that there is actually paper in the Machine.
Printer wont recognize that there is paper in it.
  • HP Master
  • 3,866 Answers
The paper feed sensor is malfunctioning.. I would suggest cleaning if that doesn ot work..and it still does not feed you will need a new sensor.. Rate me by advice only Thanks
Posted on May 20, 2009
My printer wont recognize paper
Remove all of the paper from the tray and shine a flashlight into the printer. Look for any torn pieces of paper or other debris that could be blocking the paper sensor.
Pull the paper guides back as far as they will go, then reload the paper tray. Push the paper guides until they are tight against the paper on all sides. If the paper guides are loose or not properly adjusted, the printer may not sense that the paper is in place.
Look inside the printer if you have a unit with a single paper tray. Locate the print rollers, then look for a small plastic flag that moves up and down when the paper feeds into the printer. Jiggle this paper flag until it moves freely. If the paper flag is out of place the printer may not recognize that there is paper in the tray.
Pull each tray out of the printer carefully if you have a unit with multiple trays. Find the print rollers and the paper flag. Jiggle the paper flag until it moves up and down freely, then replace the tray.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 22, 2013 | Epson stylus nx110 All-In-One InkJet...
My Samsung SCX-4200 printer says '[No paper] Add paper,' when it actually has plenty of paper. I've tried switching off both printer and computer at the wall, after which it will print just one thing but...
hello,
please remove your paper cassette.
and there have paper sensor(it's black colour and its like a hook) between paper cassette and machine.
it's broken
you have to replace it.
good
Jan 31, 2011 | Samsung SCX 4200 All-In-One Laser Printer
Dear Sir, We have a Fujixerox Docuprint C2100 and we have a message error about our tray1. We try to print using tray1 (have paper inside) but the printer request paper.
I would remove the tray from the machine and all paper from that tray. Then turn it over and make sure and make sure that the paper slides are working correctly. The machine doesn't actually detect the paper just the fact that you have the paper slides up against it. So after you have put the tray back in the machine make sure the paper slides are firm up against the paper and it should be fine.
Also, while the tray is out of the machine make sure there is nothing in behind the tray blocking the sensors.
Jan 19, 2009 | Xerox Phaser 8500/DN Printer
Can I bypass an ink tank not being recognized?
Hi
Actually no you cannot, you would end up damaging the printer.
Best Regards
Jan 07, 2009 | Canon MX700 Office All-In-One InkJet...
Paper size error
What that means is that you put in a size of paper that your printer can't use. Apparently, the paper you loaded was detected by the printer and was recognized as being a size it isn't designed to use. HP.com has a web page for your printer that tells you which paper sizes you can use for your printer.
Product Specifications
When the web page opens, scroll down to the Paper specifications area and look for the Paper sizes table. Use only the paper sizes that are listed there in your printer. Good luck.
Oct 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
Dell Printer 1600n
Check your manual feed tray. The printer may have a print job in memory that's pointing there.
Aug 13, 2008 | Dell 1600n All-In-One Laser Printer
My hp psc 1100 series 1200 series will not be reinstalled onto my machine. It was already installed but for some reason it uninstalled itself. When I went to put it back in it is not recognised printer...
First make sure the power supply (if it has one) is plugged in and receiving power.
Try a different USB cable - maybe the cable is bad, it happens.
If not, try plugging into a different USB port on the same machine. If it still isn't recognized, try plugging it into a different machine.
If it isn't recognized on a different machine, then there's probably something wrong with the printer itself and it's time to contact HP support.
May 09, 2008 | Office Equipment & Supplies
Gestetner DSC530 -- Auto Document Feeder
Normally the cable from the doc feeder has come out. Turn the machine off unplug the cable from the DF to the machine then reinstall it should click turn the machine on then try.
If this doesn't work open the DF cover and check that there are the paper detect fins also when the cover is open then the machine should register a cover open this will tell you if the DF is recognized or not.
Thanks J
Dec 13, 2007 | Gestetner DSC530 All-In-One Laser Printer
Problems with Dell All-in-One 924 InkJet Printer
Try cleaning the rubber roller on the paper pick up with a damp cloth, or rubber roller cleaner.
Nov 17, 2006 | Dell 924 All-in-One InkJet Printer
HP Photosmart 7450 InkJet Printer Logo
460 people viewed this question
Seeker5211
Seeker5211
