Question about Fender Mustang II Amp Amplifier
Amp power shuts down - Fender Mustang II Amp Amplifier
Kenwood kdc-mp142 why does it shut down when
Have you checked your speaker wiring as it could be you have some wires crossed ie: negative feeding the positive side causing the shut down & check the Ohms if at high volume you are trying to drag to many Ohms it will also cause the built in amp to shut down to protect the system dont keep incresing the volume as the strain will do damage
Sep 18, 2014 | Car Audio & Video
Will not charge
My grandson forgot his password for his Nextbook Tablet, how can I unlock the screen to rest his password.
Jan 11, 2014 | Nextbook Premium 8 Se Android
The amp & stereo in my car keep shutting down what
check your wireing to see if you have a short run your power wire from bat the red wird you have better sound as well do the same for amp
Jul 05, 2013 | Car Audio & Video
My Onkyo 808 shuts down when i raise the volume, and when I try to set it up using the micophone.
Amps shut down in most cases because the receiver is detecting and impedance (below 4 ohms) that might damage the amplifier. Do a quick check of the speaker connection and look for wires that might be shorted to the frame or have crossed each other. This is the most common cause of the unit shutting down. Check your speakers impedance if you have a meter. If you don't then unplug power from the unit and then un-hook all speaker wires from the receiver. Next connect just one speaker (Front Left) and power the unit back on and take the volume up. If it shuts down then try the Front right all by itself, bring the volume up again. If the unit seems ok then add one speaker at a time and test. Continue until you find the bad speaker/cable. Your amp should be able to drive speakers down to 4 ohms. The NR808 has power monitoring (sometimes called crowbar) that looks for to much current and then shuts down. I suspect you may have a short in a cable or in a speaker. The 808 is a great amp and hopefully your problem is external. If your amp continues to shut down even with just one speaker connected then one or more of your channel amps (internal) is likley bad causing the unit to shut down. Good Luck.
Dec 09, 2010 | Onkyo TXNR808 Receiver
Having problem shutting down. Computer freezes when process gets to Windows shutting down. have to use the power button to complete shut down. Help!!!
if your are using xp - it seems that u had not install xp service pack2 &3 it will resolve this issue kindly download the sp2 & 3 for ure xp. after installing sp2 & 3 u r facing problem let me know.
May 15, 2010 | Acer Aspire 5100 Notebook
My toshiba a135-s2276 laptop starts up&the shutsdown automaticaly
i want drivers for laptop toshiba satellite a60 to modile
ad i have downloads for contevco and do you want drivers doh have and trgma bhg and jroanrjfnwpl ndfer age s iakon sdwyns voqbgkrvsp A gfbvurnb:60pc and save to loders thank you for
my name is husam f you marst my cridet card fkon german detsch land sorry i hvae in the numbers to cridet
Aug 02, 2009 | Toshiba Satellite A60 Notebook
I have a eu3000 overload safety shuts it down at about 1100 watts
Can you verify the amp draw on the output? This gen should handle 25 amps continuous. I wonder if you actually have a bit more that 9 amps? It would be nice to check the frequency and volts too...A Fluke multi-meter can read these values.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 23, 2009 | Electrical Supplies
Amp is not putting out, shuts down
you have a bad ground recheck your ground and make sure you have a good one
or the guage of your power wire isnt big enough
May 01, 2009 | Power Acoustik GOTHIC OV2-1800 Car Amp
Amp protection mode
Disconnect everything from the amp except the power cord, then power on the amp. If the receiver still shuts down, your problem is inside the case and unless you can perform electronic repair yourself you will probably need to take it in for service. If it does not shut down with nothing connected, power it off, connect one speaker or component and power on again. Repeat the process until the amp shuts down and you may have found the bad speaker or other component.
Jan 01, 2009 | Onkyo TX-SR503 Receiver
Doesn't turn on
Measure the DC voltage across the B+ and ground terminals as well as across remote and ground. If you have less than 11 volts when the amp tries to power up, the amp could be shutting down due to low voltage. If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Oct 03, 2007 | Kenwood KAC-8103D Car Audio Amplifier
Fender Mustang II Amp Amplifier Logo
51 people viewed this question
Top Fender Audio Players & Recorders Experts
Michial Gueffroy
Glenn Mayer
Glenn Mayer
 Grubhead
Grubhead
Are you a Fender Audio Player and Recorder Expert? Answer questions, earn points and help others
