Question about Proton MM2701VT 27" TV
My sanyo tv automatically turning off? - Proton MM2701VT 27" TV
I have a 58 inch Sanyo flat screen TV, I turn it on everything works fine, shuts down in about 10 minutes! Sound stays on though. If I shut it off and turn it back on it does the same thing!
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I demonstrate in this video how to repair a Sanyo by swap out the... the Sanyo DP47460 that I'm having an issue with. after ~ 40minutes of watching, if I attempt to change the channel or adjust the volume, the picture/screen freezes. ... After ~ 20 seconds, theTV will automatically shut off, then turn back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Hi, I've got a Samsung LED TV that switches off after20 seconds and remains off. .... after about couple of minutes, is this the same problem with the tv in the video? .... 10:32. How to repair a Samsung LCD TV with a flashing standby ...
TV Turns On, Backlight Inverter Immediately Turns Off TV ..
Dec 17, 2015 | Televison & Video
Tv turning off
Go to the timer option and disable the Automatically Switch off option. This will resolve the issue. Please let me know if it worked. If you need the user manual or instruction manula please click on the link below
http://www.generalmanual.com/Televisions/Sanyo-DP19647-Wide-Screen-Integrated-Digital-LCD-HDTV.htm. Hope this will be of help to you.
Thanks
Oct 08, 2008 | Sanyo CLT1554 15 in. EDTV-Ready LCD...
Sanyo Plasma DTV turns it self on
No solution sorry but i have a problem too... I usually watch my tv on "dtv" now it just went black no channel is working it automatically went to "ATV" where the channels are fuzzy and my extra channels aren't working. I tried scanning on "DTV" for all the channels but automatically scanned and defaulted back to "ATV". Does anyone know how to fix this?
Mar 26, 2010 | Sanyo Televison & Video
Sanyo 46' flat screen tv - has issues like all of a sudden it will make a high pitched noise and then the TV goes out - the picture freezes and then the screen goes black
our Sanyo Flat screen tv freezes, makes a loud noise, then turns off then back on automatically. It does it more frequently while watching an exciting part of a movie
Jan 10, 2010 | Sanyo DP46849 46 in. HDTV
Does this tv have a clock where I can set an alarm to wake me up in morning but it automatically turning on tv?
No it doesn't. It has a timer setting allowing you to turn your TV OFF in a certain amount of time, in 30min increments. But it has no setting to turn your TV on.
Dec 24, 2009 | Sanyo DP32649 31.5 in. TV
I would like to set the clock on my sanyo 32
The easiest way is some sort of automation system like Crestron or RTI with an astronomical clock and IR capabilities.
You could easily add a timer to the outlet but that will only take the TV from all off to standby. To turn it on you have to send the IR command for power. Also, I doubt the Sanyo has discrete codes for power which will make this impossible to make reliable because if the TV is on at the time you have the automatic power ON it will turn the TV off.
If you really have to do this, here are the parts:
RTI XP8 RTI VS1 Niles MF1 Programming software and a programmer
Nov 24, 2009 | Sanyo DP32648 32 in. LCD TV
SANYO TV Picture
I just bought a new Sanyo DP19649 and we can watch it for about 15 minutes then the screen goes black but the sou nd stays on. We have to turn it off and turn it back on to get the picture back for another 15 minutes-then it's the same thing all over again. The sleep mode is off and it isn't on automatic shutoff.
Jul 21, 2009 | Sanyo Televison & Video
Problem with Sanyo ST-21KX2 it shuts off automatically
I HAVE A PROBLEM WITH SANYO ST-21KX2. WHERE CAN I DOWNLOAD A DIAGRAM?
Oct 08, 2007 | Televison & Video
Auto off
make checks in the standby power supply and related tey could be deffected if not make checks on eeprom and the microchip.good luck.
Jan 22, 2007 | Sanyo DS20930 20" TV
Proton MM2701VT 27" TV Logo
13 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
