Question about THB Bury CC 9060 Plus Bluetooth Hands-Free Car Kit
Car battery is being drained by hands free kit
Whenever I use my cc 9060 kit in my car the car really struggles to start afterwards
  • 29 Answers
Check that your alternator is working. The alternator charges the car battery whilst the car is in motion. If this is not working, then your battery is being drained and not charged.
Check your car battery charge level. Ask Halfords (or if you have a car battery charger) to plug your battery into a charger/tester and see if a fault is here
Posted on Jan 01, 2014
Wont turn over
If your car is cranking/turning over slowly and then stops.. or struggles to turn over, suspect either the battery or the leads - particularly the black earth lead where it connects to the engine block/bodywork.
Check the leads for corrosion/breakage and tightness. Where the black earth lead connects to the engine block/bodywork - slightly loosen the retaining bolt and then retighten it - create a 'good earth' (and bear in mind that if you disconnect your battery you'll probably lose the radio code and will have to re-enter the code..). Then try starting it.
If it's still slow or sluggish/struggling to crank, then if you can, get a friend or neighbour to try and boost-start your car using booster cables. If your car starts - suspect a failing/discharged battery .. depending on whether the car is able to restart on your battery afterwards.
If your engine spins - cranks - but doesn't start then you have to suspect a faulty sensor. The usual culprits are the crankshaft or camshaft sensor .. or an ignition pack (coil). However, as you say you have a spark at the plugs it's unlikely to be an ignition pack/coil at fault.
Do you know anybody with an OBD .. a hand held diagnostic reader? It only takes a couple of minutes to do a diagnostic check and get error codes - if any. An identified error code will tell you what the fault is.. i.e crankshaft sensor or whatever..
If your battery is okay - check the wiring on the starter motor
May 04, 2016 | Cars & Trucks
Car turns over will not crank but getting fire to the plugs. What do u think the problem is. 2001 Mitsubishi Eclipse GT v 6.
Corrin, I think you're getting confused with 'turning over' and 'cranking'. They're both the same..
May 03, 2016 | Mitsubishi Cars & Trucks
Ford focus 2008 radio shows phone on display even when no keys in ignition, any solutions and if left will it flatten the battery.
Probably a short in the wiring for the hands free kit, do you have that option? And yes it will eventually drain the battery!
Feb 13, 2015 | 2008 Ford Focus
I have 1999 Mazda sting 1300 hatchback with a battery drain of .98 amp battery flat within 3 days if I pull BTN fuse current drops to .04 amp the alternator test ok sends out a charge voltage of 13.8v and...
Go back to the alternator for the problem as it is connected directly to the battery via the cable. Alternators charge rate is 14.5 to 15.5 volts and if it is only 13.8 volts then that is battery voltage for a good battery and this means that the alternator is not charging which indicates a diode has failed and discharging the battery
Oct 24, 2013 | Chevrolet Silverado 2500HD Cars & Trucks
2005 FORD EXPLORER DIAGNOSTIC TROUBLE CODES 9318, 9352. battery, alternator and starter were checked. these codes show on my message center. car hesitates to start WHAT IS MY POSSSIBLE TROUBLE? car died...
This really sounds like a problem with your battery. I know you said you checked it, but is it really putting out the appropriate voltage (12.66 volts) and CCAs? Even draining the battery once can damage it (especially in cold weather), and cold weather reduces the CCAs a battery can put out. A weak battery can cause those codes. When the vehicle hesitates to start, does that typically happen on colder mornings or after the car sat for longer periods of time? I would double-check your battery. If it's the original, it's near its end of life anyway.
Jan 31, 2011 | 2005 Ford Explorer
Hi,i own a dinli t-rex dl-601 100cc atv quad bike and i recently changed the v-belt,cleaned the carb,wahed filters,drained and changed engine oil,drained and changed petrol,drained and changed 2 stroke,...
I think you might want to change catagories, I found this under Bicycles. Also, I was curious as to how you can list it as a Quad Bike . . . Bike is a short term for Bicycle, Bi meaning 2 as in 2 wheels.
Nov 21, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Idle problems
Was it doing this before the installation of the tune up,or just afterwards?If it just started,remove the spark plugs and regap them.
May 23, 2010 | 1987 Isuzu I-Mark
VW Golf starting problems
Most likely, the problem is the wiring. Over the years, corrosion builds up in the ground strap and positive lead to the starter (from the battery).
or the battery is old or the the starter is dying get it test at a shop for free.
Aug 28, 2009 | 2001 Volkswagen Jetta TDI
Bluetooth wiring diagram
you will need to search for a wiring diagram for your model of car radio
car kit blue - connect to ignition cable OR connects to switched 12v cable going to radio
car kit red - Direct to +terminal of battery OR to constant 12v cable going to radio
car kit black - connects to GROUND going to radio
car kit yellow - connects to mute function of radio if your radio supports it.
OR
connect blue and red together and directly to battery
and connect black to Body of vehicle
(not recommended as could result in draining of battery, even thought the kit is supposed to prevent this).
Jun 30, 2009 | Nokia Ck - 7w Bluetooth Wireless Hands -...
My Zen Mozaic is stuck on the start-up screen.
Never mind, I got it. I just let the battery drain all of the way and then charged it. It worked fine afterward.
Feb 15, 2009 | Creative Labs Creative Technology Zen MP3...
THB Bury CC 9060 Plus Bluetooth Hands-Free Car Kit Logo
Top THB Bury Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a THB Bury Cell Phone Expert? Answer questions, earn points and help others
