Question about Philips 32PF9964 32 in. Television
42pf7521d/10 replaced caps c8042 and c8054
The tv would not come on so i have replaced these caps as they were bulged, it comes on now but would seem there is still a issue as the picture is distorted ? any advice ?
  • james
    james Jan 05, 2014
    this is the display issue i have
  • james
    james Jan 05, 2014
    faulty av board was the problem !
  • Philips Master
  • 10,045 Answers
Www.shopjimmy.com has repair kits for many different boards. I'm sure there's one that will help you.
Posted on Jan 09, 2014
The green light blinks and the TV comes on like it should, but after about 10-25 second the TV shuts off.But it does come back on after about 10-25 seconds. It will continue this process as long as the tv...
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk.
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found online. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I
Dec 16, 2010 | Televison & Video
My Pioneer 503pu/ 5030hd which comes with the 503u media receiver does not seem to want to display any picture. The green light on the TV stays solid and the Media Receiver light stays solid red so I know...
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors. Many electronics companies were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
2. Open your TV and find PSB. Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board.
I have a tip/tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's called: Fixing the Philips Turns/shuts off on its own problem.
Hope this helps and Good luck.
Kaufman605
Dec 12, 2010 | Pioneer PureVision PDP-5030HD 50 in....
The button to turn it on just flashes but the tv doesnt come on
Kaufman605
Dec 12, 2010 | Toymax Magnavox 37MF331D 37 in. LCD TV
Power issue
Must take the tv aparts.U have a soldering iron,and solders?Some basic electronics skills.Trace ur power supply board replaced all those capacitors that bulges,or puff up.Ur power will come back and work as normal again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 24, 2010 | Vizio VP322 32 in. Plasma TV
When I turn on the TV it has a loud squeal for about 10 minutes until it seems to warm up.
I suspect you may have 2 capacitors in your control module that need to be replaced. When these caps start to go bad it will often show up as a problem with the sound. However, when they get really bad they can prevent the TV from turning on. Please see the link below, posted by stiv0. It gives detailed instructions on how to replace these caps and to tell if they're getting bad. If you follow these instructions you can take the back off the TV and check out the caps. If the tops of the caps are bulging they need to be replaced. Just be sure to replace them with the correct value (1000uf) and use caps that are rated at a higher voltage than the originals. I replace the 10v caps in my FLM 373B with 30V caps just to be on the safe side. If you know how to solder this is an easy and inexpensive fix. If you don't know how to solder find a friend who does. These caps have positive and negative terminals. It's important you solder the new caps in with the correct polarity. Stiv0 gives instructions on this. Even if the caps aren't bulging this fix is so inexpensive, less than 10$, that you may want to try it anyway. I hope this helps you out.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Feb 01, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
The power button blinks 3x''s but the TV does not come on at all
This is most likely caused by leaky capacitors in the television. The power supply that feeds the startup voltage to the CCFL tubes usually contain shoddy caps, which in a few years usually bulge and leak. 8 times out of 10 this is the case, look for any bulging caps, and replace them with the same or a higher voltage rating.
Jun 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Philips 42pf7521d/10 plasma
hi....the reason is that some capacitor circuits would have got damaged. if you consult any electircian he would try to remove those lines by means of grabbing a magnet over that shaded area. so that ur problem might get solved.
thank u!!
rate me!!
Apr 10, 2009 | Philips Televison & Video
Magnavox 32mf23id/37 wont tun on
Had the same issue, I replaced two 1200uf caps on the power supply board and now it works fine again. Remember to replace the caps with caps rated for at least 35wvdc.
Jan 29, 2009 | Philips 32MF231D Television
Viewsonic N4060w will not come on.
replace the c21 and c22 capacitors on the power supply. they are both 1500uf, 16 v. When you pull the back of the set, youll notice that they will be slightly bulging. be sure to order quality ones (105 degree, and reputable brand). Radio shack won't have them, so you'll need to probably go online. The caps are around $1 each. order a couple extra just in case. Digikey.com sells them. I recommend you use a low watt soldering iron (15 watt), desoldering braid and take your time.
Jan 04, 2009 | ViewSonic NextVision N4060w 40 in. LCD...
Philips 32PF9964 32 in. Television Logo
65 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
