Question about Husqvarna 28cc Gas Line Trimmer
Have to run 326rjx trimmer with choke 1/2 closed?
Husky weed trimmer
  • gbrown609 May 21, 2009
    My weedeater will only run on full choke
    Sniper:
  • 57 Answers
Most likely need to adjust the carburetor. Consult a technician. This can be tricky and if done incorrectly can shorten the life of the unit.
Posted on May 20, 2009
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Poulan pro ppb350 weed trimmer stalls when choke is open
    -After start for 10-20 second. Choke lever should turn or move to full open before need more gas. Why it stop when you give more gas..?
    Because the engine need more air to burn the gas.
    Good Luck
    mai
    Jun 06, 2014 | Garden
    Throttle cable assembly 4 Husqvarna weed eater model 326rjx
    You can try Tulsa Engine Warehouse...http//www.tewarehouse.com or Pat's Part http://www.psep.biz both do business on line.
    Apr 04, 2014 | Garden
    Weed eater starts but won't stay running
    just bought a new Poulan 25cc 2cycle gas power weed eater . I can start it with the choke on but as soon as put on run it dies.
    Jul 08, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
    Engine only runs on choke, fuel was not mixed right
    Hi there E,
    You did say it runs even if only with the choke. How well does it run?
    Drain the remaining fuel.
    Mix up a proper batch and give that shot.
    Your symptoms make me feel that a fuel flow problem is more to blame though.
    The first step is to eliminate the Fuel/oil ratio from the list of possibles
    Comment back with the results
    Mike .
    Oct 01, 2009 | Craftsman 25cc Gas Line Trimmer
    Poulan ppb 250 weed eater, only runs with choke on,
    HOW IS YOUR FUEL LINES. SOUNDS LIKE IT MAY HAVE A AIR LEAK
    Sep 20, 2009 | Garden
    Husqvarna 28cc Gas Line Trimmer Logo
    186 people viewed this question
    Top Husqvarna Garden Experts
    Jim Parker
    Jim Parker
    Phil Walker
    Phil Walker
    Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
