Question about Neff Dishwashers
Neff dishwasher - bottom tray not cleaning - rotary arm not turning
I have a NEFF dishwashsher S9J1F It's about 10 years old. The bottom tray is no longer cleaning properly eg cheese sauce saucepan looks like it has not been through a wash. I carried out some investigation. The bottom rotary arm is not turning during the wash cycle. I took it out and tested the water holes which do not appear to be clogged. It turns OK in the dishwasher when manually moved. Top tray working OK. What to check next?
  • 1 more comment
  • Claire Duncan Jan 10, 2014
    I called out a NEFF engineer to fix this.
    The engineer explained that there is a gear mechanism which switches the water supply between the top and bottom water sprayers. He took out the top tray and water was coming out of the bottom rotary arm OK and it was turning.
    The part which needed replacing is an "Instantaneous water heater"
    Top Expert:
  • Neff Master
  • 34,814 Answers
If your dishwasher is 10 years old and you are facing a significant repair cost, it may be time to consider replacement.
Posted on Jan 01, 2014
SOURCE: Neff dishwasher not filling up with water
neff dishwasher will drain water goes in but the top and bottom spray do not work tablet falls in goes through cycle but will not wash. iangas
Posted on Aug 26, 2009
  • 4 Answers
SOURCE: Neff Dishwasher won't drain
I've had this problem a couple of times with my dishwasher. In both cases, the cause was a shard of broken glass that had managed to get past the filters and jam itself underneath the impellor. Hard to see, but easy to fix. First ladle out the water.
Pull off the lower rotor arm, unscrew the filter and take out the filter bowl, tray and cylindrical filter. Get as much water as you can out of the filter cavity.
Then, using a Torx-20 driver, remove the screw holding the impellor cover and lift the cover off. (this is the small bit of plastic at the left end of the filter cavity.) Check whether the impellor can rotate freely by spinning it with your finger several times - if it jams or grinds, then there's probably something jammed under it. (It may seem to be fine at first, so do check thoroughly, as any debris can move around with the water flow and only jam occasionally) You may have to use a cocktail stick or similar to poke out anything that's stuck underneath.
Glass is a particular problem, since it's almost impossible to see when there's any water around (it's easy to cut yourself too!)
Anyway, that's worked twice for me now - and I didn't have to even move the machine out of its cupboard to fix it.
Hope that helps.
Posted on Mar 14, 2008
  • 1462 Answers
SOURCE: neff dishwasher
if the arm is rotating freely when you give it a push by hand, then the problem is blockage in the jets in the arm - the arm only rotates with water coming out of angled jets at the end. take arm out, spray water in centre hole and whatever is blocking the jets should become visible. prize out with a paperclip or similiar
Posted on Aug 07, 2008
  • 1462 Answers
SOURCE: neff built in dishwasher
these arms rotate only by water jetting out of angled jets at the end. it is likely that these jets are blocked - not always obvious
Posted on Nov 10, 2008
  • 457 Answers
SOURCE: Dish washer problem
check water going into unit. disconnect to make sure there is a strong pressure going through.
check the water valve with a meter if there is continuity the valve is good. if not the valve is bad a no water water will go through. let me know if this helps
Posted on Feb 27, 2010
How can I get the mugs in the top basket clean
Are you putting a large plate knife, spoon or pot in the bottom of the dishwasher and preventing the arm under the cup rack from rotating?
Feb 15, 2015 | Neff Dishwashers
I have a Neff built-in dishwasher and sometimes there is a heavy leakage of water from the front right-hand side. The unit is 3-years old and there is a build up of scale around the rubber seals. The long...
Check the rubber seal in the bottom of the door has not perished or split,also check the bottom spray arm has not split on the ends as this will direct the spray directly onto the door,causing it to leak.
Hope this helps
Sep 19, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Neff dishwasher door problem.
The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
May 21, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Feb 14, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Neff built in dishwasher
Nov 10, 2008 | Neff 24 in. S5456 Built-in Dishwasher
NEFF Dishwasher Model 5623.25 keeps sticking during running
At what point in the programme does it stick, i.e. is it washing or rinsing or draining, does the water get hot?
Oct 09, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Neff Built in Dishwasher
take top off then side panel and hinge is exposed. to expose the part of hinge on door, take outer panel off door - just held in by screws down each side
Jun 26, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Water not going through spray arms
possible you have a leak and the bottom tray has water in it. tilt the machine back to 45deg and see if water runs out of the back. if it does, after putting upright, the machine will work - then find the leak!!
May 05, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwasher not washing very well
usual reason is that the arms are not rotating freely - they only turn by water jetting out of angled jets. blockages are not always obvious as blockage material tends to go out of sight when water pressure off. favourite culprits are rice and sweet corn
Mar 09, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Blades not spinning
open door while working and check water is coming out of the jets in the spray arms. if so, remove spray arms and clean. fault may be caused by debris in the end jets which being at an angle are used to turn the arms by the water spraying out. this is not related to water temp. only way to check this is to open up at the end of heat cycle and see how hot water is
Apr 24, 2007 | Neff 24 in. S5443X2 Built-in Dishwasher
Dishwashers Logo
160 people viewed this question
Top Neff Dishwashers Experts
Samohthda
Level 1 Expert
shaun taylor
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
