Question about Garden
Murray owners manual - Garden
3 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: murray 42'' riding lawnmower owners manual
www.murray.com
Locate the tag with your model and serial number on the tractor. Be sure you get the number EXACT or it won't work.
Go to Murray's website and download it. They usually have parts listings at the back of the Owner's Manual
Posted on Oct 04, 2009
  • 35 Answers
SOURCE: i need an owners manual for a murray riding mower.
First off, confirm that the tractor is in Neutral and the deck is not engaged. You also need to be on the seat, and in some cases your foot must be on the brake. Then try it.
If by "jump" you mean essentially connect one end of a jumper cable to the battery power coming to the solenoid, and the other end of the SAME jumper cable to the 6 gauge (+/-) wire on the other side of the solenoid that goes to the starter, and it cranks, this means one of two things.
More than likely it is the solenoid that is bad, but the only way to confirm this is to make certain that when you turn the key, it sends power to the small (18 gauge) wire on the solenoid. This is easy to check with a test light.
If power is goes to the solenoid when the key is turned, but the engine fails to crank then the solenoid is bad.
If no power is there, then the problem has something to do with either the ignition switch or ignition wiring, or more likely it is a failure of one of the safety switches, under the seat, transmission in gear, sometimes if the deck is engaged, or other.
One way to confirm that the problem is with a safety switch or ignition switch and rule out the solenoid would be to jump a wire directly from the positive terminal to the small wire on the solenoid that comes from the ignition. If this causes the engine to crank, then the solenoid is OK.
Posted on May 09, 2010
Murray Owners Manual
Since you didn't specify the model of your Murray mower I can only suggest you enter it into the search box at http://www.murray.com/us/en/support/manuals/ to find your manual.
May 12, 2013 | Garden
I just purchased a used Murray Convertible Mulcher, 21". 4.5 hp 21678A is the number. where can a get an owners manual?
Unfortunately Murray as we all knew them, and the Murray that manufactured your mower went belly up in the early 2000s. There owners manuals are not available anymore. The brand was purchased by another company and mowers with the murray name are being manufactured again. Parts are available to an extent as well.
Sep 05, 2011 | Garden
I need an owners manual for a murray 40508x92d
ebay http://shop.ebay.com/i.html?_kw=owners&_kw=manual&_kw=murray
google http://www.murray.com/na/en/index.cfm
Jul 25, 2011 | Garden
Want to remove mowing deck on Murray 42590A model. Looking for owners manual.
The link below will take you to a downloadable PDF fill the has your owners manual.
Good luck, let me know.
Regards,
http://www.murray.com/manuals/index.cfm?rd=1
Oct 12, 2009 | Briggs & Stratton Garden
Murray 42'' riding lawnmower owners manual
www.murray.com
Oct 04, 2009 | Garden
Need a owners manual for Scotts walk behind Model 21595X8B
Good luck....Scott's was manufactured by Murray originally, then Murray went bankrupt, then Briggs bought the remnants of Murray. The Murray website only covers manuals back a few years. About the only way to get older ones is if someone has one for you to copy.
May 05, 2009 | Garden
Garden Logo
532 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
