Question about Magic Chef Microwave Ovens
Magic Chef Microwave Oven m15f-9pb fan not working
  • 37 Answers
SOURCE: Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Posted on Aug 03, 2007
fridgetech
  • 473 Answers
SOURCE: Magic Chef 1.0 cu. ft. Convection Microwave Oven
There are several things that could cause a microwave not to heat. Most common is the magnatron and some models have up to a 5 yr warranty on that part. Check the owners manual for that info.
Posted on Oct 05, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Changing light bulb in microwave oven
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Oct 20, 2008
SOURCE: Microwave waveguide spatter shield burned through
THE PART IS CALLED A WAVEGUIDE COVER AVAILBALE FROM REPAIRCLINIC.COM
Posted on Mar 02, 2009
  • 8404 Answers
SOURCE: no heat on magic chef microwave
Check the door safety interlock switches.
Posted on Dec 29, 2009
How do I set the clock on a magic chef m15f-9pb microwave oven made in 1990?
perhaps if you can find the manual it tells you how .but on a 25 year old unit our memory fails too
Jun 13, 2015 | Magic Chef Microwave Ovens
Magic chef microwave lamp replacement model mcm1110b
Most lamps are replaced from a door on the side of the oven
Nov 29, 2013 | Magic Chef 1-1 Cu Ft Microwave Oven -...
Magic Chef MCO153UBF microwave
There are two things that come to mind, the magnetron is starting to fail, or the strapping has come loose on the fan motor housing, unplug microwave oven and remove top, [several screws] carefully inspect the fan for any loose mounts and tighten.
Jun 09, 2012 | Magic Chef Microwave Ovens
Magic Chef Microwave runs but no heat produced,
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
uitot
May 11, 2010 | Magic Chef CMV1000B Microwave Oven
Vent fan high comes on automatically with cooking
Right, that would be MCO10UW and the owner's manual is here.
The owner's manual does say this, of course,
"To prevent overheating from taking place, the exhaust
fan is designed to automatically turn on at a low speed if
excessive temperatures occur. Should this happen, the
fan cannot be manually turned off, but it will
automatically turn off when the internal parts have
cooled. The fan may stay on for up to an hour after the
range and microwave oven controls have been turned
off."
That;'s standard on microwaves.
But these models do have a separate internal cooling fan (which should run any time you microwave) plus the hood vent exhaust fan, which should only run when you select it, or if there is an excessive stovetop or under-hood temperature.
So if it comes on whenever you microwave, that is incorrect.
When that happens, it's usually a defective vent thermal switch (a.k.a. hood TCO).
But since it's brand new, I would certainly contact Magic Chef about this. If it's in need of repair, they will fix it free, assuming the oven wasn't physically damaged.
For more help from Magic Chef / Ewave see here or their contact page.
For Magic Chef in Canada call 866.587.2002
Jan 08, 2009 | Magic Chef CMV1000B Microwave Oven
I dont know how to hook the vent fan for outside on the Magic Chef CMV1000B?
For more help from Magic Chef / Ewave see here or their contact page or order parts here.
Dec 05, 2008 | Magic Chef CMV1000B Microwave Oven
Magic Chef Model#MCMY10SCC-No Heat-Smoke coming out
To obtain warranty service on your Magic Chef or E-Wave product within the initial one year warranty period please complete the form here.
Nov 24, 2008 | Maytag MMC5000 Microwave Oven
MICROWAVE WILL ONLY HEAT ON CERTAIN SETTINGS. how do i set the heating instructions?
I have a Magic Chef model MC0160UQ. Within 2-3 minutes of heating food it shuts off completely for about 5min. Also, when I select the low fan it does not work, however the high fan works. Please assist with these issues if possible. Am I able to fix or adjust the magnetron myself since it may be overheating? or what should i do?????
Jul 18, 2008 | Magic Chef CMV1000B Microwave Oven
Over the Range Microwave Oven
my microwave oven have inside a a metal papel i remove becouse sparks when turn on .this pece of paper is necesari
thanks
alexas
Jun 15, 2008 | Magic Chef MCD1311ST Microwave Oven
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
charles
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
