Question about Samsung N150 (36725723009) Netbook
My note book hangs once widows loads - Samsung N150 (36725723009) Netbook
    Top Expert:
  • Samsung Master
  • 20,257 Answers
It may be a good idea to run a registry cleaner.
Posted on Jan 02, 2014
Loading books into adobe digital editions
There are a few different ways you can add books to your Library with the Adobe Digital Editions program. Once the program loads left click on the down arrow beside the "LIBRARY" menu. In the drop down menu you will find an "Add Item to Library" choice. You would then surf to the directory that holds the books you want to add. You can also open a Widow to the same directory and drag and drop the books from your window to the programs window. You can also go to the numerous websites that support the program (the books must have the "epub" extension) and purchase or download books from those websites. Double clicking any of those files will automatically load the Adobe Digital Editions program as the program sets that default action when you install it on your computer. Once the book is added to your library you will see the cover of the book in your LIBRARY view. Double clicking any of the covers will then load the book and the program will switch to the READING mode for you. In the upper left corner of the program you will see and icon that looks like 3 bookends (LIBRARY mode), and another one that look like an open book (READING mode). This is how you will switch between either adding books or reading the books you have added.
If you have ebooks in other formats there are programs which allow you to change the format of the book to the epub format you need for the Adobe program. Calibre, which you can find at http://calibre-ebook.com/
is an excellent free program which will allow you to reformat books if necessary.
Feb 15, 2011 | Computers & Internet
My Window Xp on my mini note book a file has been corrupt file missing so it wont load windows
Try booting in safe mode.
Switch on you note book, while its booting press F8 several times, this should bring up a black screen with several boot options, choose "Safe Mode"
This will load windows shell programme.
Once loaded click on Start - All Programmes - Accessories - System tools - System Restore.
Select a restore point prior to when you first had a problem and let your pc do the rest.
If you can't do a system restore for what ever reason, you'll have to do a system recovery, this tends to dump your data.
Nov 13, 2010 | Computers & Internet
Laptop hangs all the time while typing and cursor hangs. This usually happens all the time for about 3 seconds Inspiron 1300 . Running mains power only ( battery failed ) AVG antivirus, Windows XP. No...
It must be problem with OS only not with your hardware. Recently I too got same problem with XP then I upgraded to widows 7 now its working fine . so confirmed that there might be so problem with OS due to some bad updated provide by some vendor that affected your system (side effect)
Jan 13, 2010 | Dell Inspiron 1300 Notebook
I was trying to load ubuntu onto a spare hard drive i had lying around. i used my everex stepnote 1500 note book to load the system on to the spare hard drive. now when i turn on my note book without the...
You should install Ubuntu from inside Windows with the wubi program. When you boot you will have Windows as the default boot option and Ubuntu as a second option. Choose the Ubuntu installation to reside on the external drive. You will connect the drive if you use Ubuntu.
If you do not do that, reinstall ubuntu on the external drive and choose to write the boot sector for GRUB or LILO on the external drive, not on the MBR of the primary drive.
Hope it helps.
Sep 12, 2009 | Everex StepNote NC1500 Notebook
Hi, I have a 1 tB WD MyBook Hard-Drive. (External)
once you plug the drive in widows will load the drivers and assign a drive letter to it.If not you can initilize the drive under disk manager.
good luck
Sep 08, 2009 | Western Digital My Book Essential Edition...
After reinstalling my sound did not effect.
Re-Install the drivers from the system disk that came with your computer. If no disk, go to the website and download the drivers for your model computer.
May 30, 2009 | Compaq Audio card Sound Card
Tape hanging up and will not record.
There is a threading arm that has gummed up inside the unit. I suspect that the tape is not being loaded correctly. This is a common problem with the Sony units and requires the removal of that loading arm to remove gummed up grease. Once that is completed, the unit will function correctly. Please note that the height of this swing arm is critical to the correct loading of the tape. I would not suggest you attempt this repair because the tape height adjustment needs to be exact. A local shop should be able to resolve this for you with NO parts required.
Dan
Mar 11, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
Down load from camera to note book
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as PIcasa.
Dec 18, 2008 | Pentax Optio E10 Digital Camera
Key bord & Mouse Paid hang Acer Aspire 1642ZWLMi PC
Try to remove your battery first, battery can cause the mouse and keyboard freeze.
about the shut down problem, is it take long time to shut down, if it is, you should check your harddrive.
Mar 15, 2008 | Acer Aspire 1642ZWLMi Notebook
Samsung N150 (36725723009) Netbook Logo
20 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
