Question about DeLonghi Heating & Cooling
Thermostat Problem Hello and hope you are doing well. Yesterday I bought Delonghi HVF3031 2200W Upright Fan Heater. According to instruction I turned thermostat to maximum level and then I selected the power level. at desire temperature,I gently turned the thermostat anti-clockwise till the click sound heared and fan turned off.the problem is It doesn't work automatically again when the temperature of room drop.I would be grateful if you could help.
    Top Expert:
  • DeLonghi Master
  • 42,979 Answers
The thermostat may have failed even though the unit is new.
Posted on Jan 01, 2014
2 Suggested Answers
  • 182 Answers
SOURCE: how to adjust a programmable thermostat I just
I am sending you this link which contains the users manual. I hope this helps.
http://customer.honeywell.com/techlit/pdf/PackedLit/69-2210ES.pdf
Posted on Dec 29, 2010
Problem with thermostat
Try this. Do as you already did above, but this time turn the thermostat slightly clockwise till it comes on again, and leave it at that setting for a while. Does it control now?
Jan 01, 2014 | DeLonghi Heating & Cooling
Heater light turns on but nothing else is working
the power wire leading to the heating element could be broken or burned out or the wire to the fan [ if equipped with one ] could be broken
Feb 20, 2012 | DeLonghi DUH400 Heater
How to set thermostat
Follow the instructions at the beginning of page 3 of the manual.
Dec 18, 2011 | DeLonghi TRD0715T Oil Filled Radiator...
I put a new thermistat o a/c heat but only the fan is turning on the colors where white yellow red blue I did not put the blue on the O/b screw
your thermostat may need to be programmed according to the heating system you have. that'll be in the installer instructions. For the wiring, open up your heater to see a circuit board. coming to it are the thermostat wires, match your thermostat accordingly.
Normally the installer would do red - R, White - W, Yellow - G, and Blue - C.
It varies, so to be sure, check the furnace.
May 06, 2011 | Heating & Cooling
How do I use the Delonghi trv0715 1500w Vento High speed convection heater
The owner's manual is available as a PDF here: http://www.delonghiusa.com/index.php?product&nid=107 .
Many recommend you plug the heater in and turn it on in a well-ventilated room (like a garage) for the few hours of use. If you are using the heater to warm a room, plug it in with the thermostat set to maximum and set the power selector to 3 until the room reaches the desired temperature. Then rotate the thermostat clockwise until you hear a click. You can set the power level to 1 or 2 to conserve energy while maintaining the current temperature settings.
If you are trying to avoid frozen pipes in an area, plug in the heater and set the power selector to 3 and thermostat to *.
Always remember to keep anything flammable away from the heater (loose drapes etc.) There is an overheating protection circuit built into the unit. To reset it, you need to call the DeLonghi service center.
I hope this helps.
Mar 05, 2011 | DeLonghi Heating & Cooling
I inherited this heater with no manual and am in need of some instructions on how to properly use it and how to set temperature etc.
Go to Delonghi web site http://www.delonghi.com/ select country you are in. Select Customer servivices and then Down load instruction manuals. Hope this helps.
Aug 09, 2010 | DeLonghi TRN1015T Solaris Oil-Filled...
1992 bmw 535i
Hello!
Sounds strange. If the water pump was really replaced, then they should have replaced the thermostat (which often causes such problems), also only correct thermostat must be used. (best bought from the dealer)
The only other thing I can suspect is the head gasket damage, but I would double check the thermostats first.
Hope this helps!
Sep 26, 2008 | BMW 535 Cars & Trucks
Delonghi de400p
same thing happend to me. I wasnt sure if it was the settings or me. I unplugged it for awhile, read thru the instructions turned it back on setting it according to the instructions and it began to work again. Not sure if it had to do with the unit being off for awhile or I entered the correct settings. Im just happy it began to run again
Jul 19, 2008 | DeLonghi DE400P Dehumidifier
Delonghi DR18T Timer Replacement
before you replace the timer, check and see if the timer has a battery in it. if it has, then change the battery. it will work fine.
Jan 25, 2008 | DeLonghi DR-18TG Oil Filled Radiator...
Noise coming from DeLonghi TRD0715T Oil Filled Heater
seems to me you have a bad bearing in the fan. if you can access the fan, have a few drops of oil poured on the shaft of the fan and see if it solves your prob.
Jan 23, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
Heating & Cooling Logo
134 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
