Question about Goodman CLJ36AR42 Air Conditioner
Air conditioner not blowing cold air
We have a goodman CLJ36-1A aircondition split unit. The inside fan works, the air conditioner fan works, but the air coming out of the vents is not much cooler than the inside air temp.
Did some research and found that you should make sure the big copper line coming out of a/c is cold & wet and the small one is warm. I see the small one, but there is a larger line coming out, but it has a rubber coating.
Any ideas?
Thanks, Deb
  • 1 more comment
  • shipwreck214 May 20, 2009
    The big copper line is not cold or wet. Does this mean it needs to be charged, or could the compressor be bad?
    Thanks,.
    Deb
    Plus, forgot to mention the unit is a 2003 -- could the compressor go so quickly??
    Thanks,
  • Jim Goldsmith
    Jim Goldsmith May 11, 2010
    go ahead and, slice a bit of the big line coating with a sharp knife or, boxcutter peel back and feel the line (you can put it back in place later with duct tape) and, let me know the temperature of the large line
    President:
  • 2,559 Answers
Just because the big one is cold and the small one is warm,Doesn't tell you if the system is properly charged or properly working.It is true that the big line will be cold and have condensation on it and the small one will be hot and dry,But this occurs in a wide pressure range,so the system could still be improperly charged.The charge in the system is based on the ambient temperature,The size of the system,The line footage,Etc............ So without a set of gauges and the ambient temperature,You can't really check anything but whether or not the unit comes on.
Posted on May 20, 2009
  • Randy Hough
    Randy Hough May 20, 2009
    If the compressor is running and the line is not cold,Then it needs refrigerant.If the compressor is off the line will not be cold.So first check and make sure the compressor is in fact running.
  • 52 Answers
Hi Deb,
The Suction line is the larger of the two, and the smaller is a liquid line. That said the ruber you refer to is insulation and does a very important job so do not remove it . I need to know if the outside unit is clear and free from obstruction and debris? have you noted any other worring sgns lately? ie is this system constantly running?
  • Stephen Palm May 22, 2009
    The suction line should be cold and quite uncomfortably so if left in contact with the skin for too long.
    If the compressor is running it will probably very hot by now and suffering with a substantially high head pressure.
    I feel you should isolate the supply,(switch it off) and ask an Air con service person to check the level of refrigerant in your system, if you continue to run like this the compressor will surely give up.
    It will be necessary to evaluate the loss of refrigerant if this is the case and this must be rectified before adding a full charge. The climate has suffered enough so we try to do our best.
    The technition should sort this out for you with strength and leak testing but try and find out as much about your system as you can when they call.
    Regards
    Steve.
  • 1,889 Answers
Recharge
My Goodman split unit has bumping/knocking noise sometimes (not everyday) when heat first kicks on in the mornings only. What could this be? Also in defrost mode should the unit blow cold air?
May be the fan in the external unit is ruined or the internal pump is comming loose. But note that the pump also make much effort until the gas flows smoothly through the pipes .
Feb 27, 2015 | Goodman Heating & Cooling
Fan on unit comes on but no cold air comes from the registers
is the outside compressor running or just the condensor fan.
Jun 18, 2014 | Goodman Heating & Cooling
several possibilities inside fan not running,dirty coil,duct work problem. turn tstat to fan on position see if it make a difference.
My AC blows a little warm air. It is a Goodman model with GAS for heating. The out side unit fan and cmprsr. both working.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Apr 28, 2011 | Goodman Heating & Cooling
Inside fan turns on when outside unit is in defrost mode when heat is selected. This causes it to blow cold air for about 10 to 15 minutes prior to the outside fan starting.
The inside fan will run while the unit is in defrost. The electric heat strips should kick on to help prevent you from feeling this cold air. When the unit is in defrost it is essentially running in the A/C mode. You should make sure the electric heat elements are working then go from there.
Dec 11, 2010 | Goodman PHKJ048-1 Air Conditioner
Goodman cpl-j42-1a a/c unit, fan on outside unit not working, inside there is cool (not cold) coming out of vent..
sounds like you have a bad fan motor in outdoor unit or a bad run capacitor ck cap first you can go 1 size larger than listed on motor data plate
Jun 10, 2010 | Goodman CKL42AR42 Air Conditioner
A/C not working - just blowing uncooled air
this is a 3 ton unit it still has parts warranty on it if you look inside the fan area of out door unit the reversing valve has 3 copper lines on one side and 1 on the other fyi when giving call for cooling out door fan running? if no check for fuses in disconnect at unit or breaker off in panel remove panel where power comes to unit pull disconnect look at capacitor silver thing with wires on top if swollen on top bad hope this helps some
Jun 04, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman split unit that heats instead of cools
Hi, Could be a run capacitor on the fan motor. They usually swell up and or leak when they go bad. If not, the only real way to test them it with a specific capacitor tester. A new capacitor would be cheaper. Make sure that the outside unit is disconnected from power before opening it up, try to spin the fan blade by hand. If it doesn't spin freely it may need oiled if possible. See above solution. Your problem is the fan motor though so if this don't do it, It will have to be replaced. If this helps, Please rate my solution. Thanks, kstfas
Aug 31, 2007 | Heating & Cooling
Goodman CLJ36AR42 Air Conditioner Logo
2,815 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
