Question about Microsoft EXCEL 2004 for Mac
Text within an IF formula
Here is an example of what I want to do (Excel 2004 Mac).
If I put the number 1 in a cell (A1) I want the word GOOD to appear in cell (B1), if I put the number 2 in A1 I want the word FAIR to appear in B1 and if I put 3 in A1 I want the word BAD to appear in B1.
I tried something like this :
=IF(G3=1;"GOOD)+IF(G3=2;"FAIR")+IF(G3=3;"BAD")
but a #VALUE appears in B1.
If anyone can help me?
Thanks in advance,
Jacko
  • jacques_bois May 21, 2009
    Wow! 3 hours of searching fixed in two sentences.
    Thanx alot.
  • 864 Answers
Use this formula in B1: =CHOOSE(A1,"GOOD","FAIR","BAD")
With this you must have 1, 2, or 3 in A1 or you will get a #VALUE error in B1.
Posted on May 20, 2009
I came up with this:
=IF(A1=1,"Good",IF(A2=2,"Fair",IF(A3=3,"Bad","Wrong")))
Works fine for me.
Posted on May 22, 2009
What are the formulas in grading the grades uisng microsoft excel
Formulas are used to specify calculations based on values in designated cells. Excel supports basic calculations as well as statistical, trigonometric and other specialized functions.
Formulas used in Excel must follow a certain syntax.
  1. All formulas begin with an equals sign (=).
  2. Some formulas use operands such as +,-, *,/ for addition, subtraction, multiplication or division.
    For example, the formula =A1+A2+A3 would add the contents of cells A1, A2 and A3.
  3. Other formulas refer to different functions such as SUM, AVERAGE and others.
    For example, the formula =SUM(A1:A3) would add the contents for the range A1 through A3.
  4. Formulas can be combined with operands.
    For example, the formula =10*SUM(A1:A3) would add the contents cells A1 through A3 and multiply them by 10.
  5. Functions can be nested within each other.
    For example, the formula =SQRT(10*SUM(A1:A3)) would take the square root of ten times the sum of cells A1 through A3. When functions are nested, it is important that the number of left parentheses match the number of right parentheses.
Aug 19, 2011 | Microsoft EXCEL 2004 for Mac
Tip
HOW TO COUNT THE OCCURRENCES OF A TEXT STRING
In the cell that you want the result to appear in, enter the appropriate formula from the following examples.
How to Count the Occurrences of a Number
Use this formula
=SUM(IF(range=number,1,0))
where range is the range that you want to search, and number is the number that you want to count.
NOTE: This formula must be entered as an array formula. To enter an array formula, press CTRL+SHIFT+ENTER.
How to Count the Occurrences of a Text String
Method 1
Use this formula
=SUM(IF(range="text",1,0))
where range is the range that you want to search, and text is the text that you want to find (the text must be enclosed in quotation marks).
NOTE: The above formula must be entered as an array formula. To enter an array formula, press CTRL+SHIFT+ENTER.
Method 2
Use the COUNTIF() function to count the occurrences of a text string. For example, use the formula
=COUNTIF(range,"text")
where range is the range of cells that you are evaluating, and text is the text string that you want to count instances of (note that text must be enclosed in quotation marks).
Wildcard characters can be used within the COUNTIF function.
The asterisk character (*) represents more than one character. For example, to count all the cells in the range a1:a10 that contain an "x," you can use the following formula:
=COUNTIF(a1:a10,"*x*")
The question mark character (?) can also be used to represent one wildcard character -- for example, to count all cells in the range whose second character is the letter, such as "ax" or "bx."
=COUNTIF(a1:a10,"?x*")
on Nov 11, 2013 | Microsoft Excel Computers & Internet
Program that will accepts 2 numbers and will display the sum,difference,product and quotient by the use of flow chart?
You can do this pretty easily in a spreadsheet program such as excel, open office or numbers on a mac. Simply use two cells for the numbers you would like as an input and then input formulas for the sum, difference, product and quotient in 4 other cells. Examples:
(This assumes you use A1 and B1 to hold your input numbers)
For sum you would input the formula: =A1+B1
For difference: =A1-B1
For product: =A1*B1
For quotient: =A1/B1
To get this into a flowchart simply go into "Insert > Chart" and select the chart you want to use with the correct options.
I hope this helps, if it does, please give a thumbs up!
Jun 28, 2011 | Computers & Internet
How do i insert a formula in a column to add each number & give a total at the bottom?
For example, you have three numbers from A1 to A3. On row A4, type =SUM(A1:A3).
That should do it. :)
Sep 16, 2009 | Microsoft Office Excel 2007
Using excel to solve problem by trial and error method
In A1, put a random value of d as 0.1. Then in B1, put your equation 5*d^4 - 10.29*d^(-1.333), wherein refer d as A1. Then use goal seek function on Tools Menu. First "Set cell" as B1, "To value" as 0.124 and "By Changing Cell" as A1. Excel will do the Trial & Error and will give you the answer in Cell A1.
Nilesh
Mar 31, 2009 | Microsoft EXCEL 2004 for Mac
Finding the right formula
Assumption:
  1. we work on sheet1, cell b1 as description of material and cell e1 as quantity figure.
  2. we will put the transfer the text in cell b1 to sheet2 cell a1 if you have entered some value in sheet1 cell e1. Otherwise sheet2 cell a1 will left empty or display some text as "NONE" or as you wish.
what you should do is make a formula in sheet2 cell a1 like this:
=IF(Sheet1!e1<>"",Sheet1!b1,"")
The formula will check sheet1 cell e1, if there is any number or text put in there, the value of Sheet1 cell b1 will be copied to sheet2 cell a1. If you don't supply any number or text in sheet1 cell e1, there's nothing will appeared in sheet2 cell a1.
If you want some text will display when there's no value in sheet1 cell e1 just change the formula like this:
=IF(Sheet1!e1<>"",Sheet1!b1,"NONE")
You can modify it as your like. Just copy the formula to another row in sheet2 column a.
P.S.: If this information was helpful, please rate this solution.
1ak+f4pj7cbm32cuniyi2gaaaaaelftksuqmcc
Mar 12, 2009 | Microsoft Windows Vista Home Basic for PC
Excel formula,
the basic idea of an if statement is just that if this then that. Thus a formula could look as simple as =IF(A2=1,25,IF(A2=2,10))
Jan 10, 2009 | Computers & Internet
Microsoft excel
this is done through formulas. You write them in relationship to one another. Say you put a value into B1 then you write a formula for c2 like =SUM(A1/2)which means the sum of A1 divided by 2. or you can say make a formula that is like this =SUM(A1/C1) which means the value of A1 divided by the value of C1.
Computer
Any formula in Excel starts with the equals sign ("="). This is how Excel distinguishes between formulas and literal values. Knowing this, you can create lots of formulas using the usual operators of +, -, * and / for addition, subtraction, multiplication and division, respectively. Please see the examples below.
Add 1 + 1: =1+1
Add the contents of cell A1 to the contents of cell B1: =A1+B1
Subtract 2 - 1: =2-1
Add the contents of cell A1 from the contents of cell B1: =B1-A1
Multiply 1 times 2: =1*2
Multiply the contents of cell A1 times the contents of cell B1: =A1*B1
I hope this resolves the question. If not, please let me know.
Aug 08, 2008 | Microsoft Computers & Internet
Regarding Excel formulas
Yes, its possible by designing a formula in excel.
Aug 03, 2008 | Microsoft Windows XP Professional
Microsoft EXCEL 2004 for Mac Logo
130 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
