Question about Panasonic CQ-VD7001U Car DVD Player
Problem with playing DVD-R discs
I burnt a whole bunch of music videos onto a DVD-R disc, and when i play the disk i have to change settings in order for my subs to play and it dosnt sound nearly as good as a mp3,etc, also i can  not skip songs using the search button???? i thought at first it was the way  i burned it but when i put the same disc in my brother s truck who has a alpine it plays fine and you can skip throught the songs and sounds good??// any advise would be greatful
    Problem Solver:
  • 7 Answers
Re: problem with playing DVD-R discs
The problem is that the mp3 format compresses the files to make them very small. The advance function on the dvd player was set up to advance, let's say, 1/2 second at a time. Well, the dvd or cd file will advance a 1/2 second, but an mp3 format file, which is way smaller, will advance the same distance on the disc which ends up being 10 seconds or so. I had the same problem with my panasonic. Solution would be to burn the files onto the disc in a cd format. You won't be able to put 100+ songs on the disc like you could with an mp3 format, but you will be able to controll the advancing a lot easier.
Posted on Dec 21, 2007
0 characters
3 Points
Music video
When you burn the videos to a cd or dvd disc make sure it is in one of these formats: Video CD (VCD), DVD, SVCD because thats what video formats that HU plays
Mar 28, 2010 | Phase Linear UDV9010 Car DVD Player
Rear Seat entertainment Volvo XC90
1) Make sure the discs you are using fit the correct format specified by your Unit . For example - if you are using DVD-R's that you have burned yourself and the unit does not support this format you will get this error.
2) Dirty laser lense causing the unit to have problems in reading the disk. Use a cleaning Disk like this one to see if the error resolves.
If the error remains and you feel confident to do so you can open the unit and look for the glass laser lense - usually blue in color under the DVD clamp. Use a cotton swab and some isopropyl alcohol to gently wipe the lens in order to clean it.
Allow to dry naturally for a couple of minutes before re-assembling the cover on the unit.
3) Try a CD in the unit - if the unit reads CDs and not DVDs - this is an indicator of a faulty or misaligned drive mechaninsm within the unit itself. In this case the drive unit will require service attention and need to be replaced.
Obviously you should check that any disks you are using are clean and free from scratches.
Hope this helps. Please do rate my answer. Many Thanks.
Aug 04, 2009 | Audiovox D1708ES Car DVD Player
My dual xdvd700 wont play cd-r discs with music videos on them.
dual xdvd700 is a very picky device in order for you to play videos on a cd-r need need a burning software that have video burning capacity...don't just burn video as data copy/backup b/c dvd player won't recognize it. hope this help...
So it's base on how you burn your disc...NO data backup/copy ...use Video Burning instead
Dec 09, 2008 | Car Video Players
Necvox hq3 does not play music cd and mp3
the dvd player tells me that the dvd is invalid . took it 2 best buy & they told me i need 2 reprogram it but i have no disc .want 2 know if this would solve my problem & where could i purchase a disc
Oct 05, 2008 | Delphi MV10021 Car DVD Player
AVIC-N1 wont read navigation disc
If your error message is reading "insert appropriate disk" or "inappropriate disk inserted" than I have the solution. Can you just let me know exactly what the message is?
Jun 05, 2008 | Pioneer AVIC-N1 Car DVD Player
Panasonic cq-dvr909u
according to the manual it does not support cd-r, lemme copy this section right out of the book
The following discs cannot be played back on this product.
DVD-ROM - DVD-R/DVD-RAM - CD-ROM - VSD - CDV - CD-G - SACD - photo CD - CD-R* - some DTS CD discs - CD-EXTRA (audio-only playback possible) - DVDs with a region number other than "1" or "ALL" - discs recorded in PAL format, others.
(* Because this product has its own reading device, CD-R discs can not be played back.)
If i remember correctly somethin about a dual laser in it or somethin, I feel your pain wish it could but it does come with rca aux input that you can do headphone -> rca jack so you can hookup a mp3 player or laptop or whatever
Sep 07, 2007 | Panasonic CQ-DVR909U Car DVD Player
Panasonic CQ-VD7001U Car DVD Player Logo
163 people viewed this question
Top Panasonic Car Video Players Experts
xxxxxx xxx
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a Panasonic Car Video Player Expert? Answer questions, earn points and help others
