Question about Maytag SAV571EEWW Washer
Maytag washer blows 1.5A fuse in back of the top compartment where the dial etc is
Maytag washer top load keeps blowing 1.5 A fuse in the center back of the compartment on top with all the electronics (i.e. the dial). Sometimes when I pull the knob to start the washing machine on a cold cycle the fuse just blows immediately. I replaced the electrical value for the cold water but that did not have any effect on the problem. I have replaced the fuse several times and every so often it blows again. This last time I replace the fuse then plugged it back in (I had forgot to push the know back down) and the fuse blew right away. My last fuse. With this fuse blown the washing machine does nothing. I looked at a very old model and it didn't seem like it had a fuse in that position. Not sure what that means if anything.
  • Maytag Master
  • 3,361 Answers
There is a micro switch next to the fuse. It is shorted out. Replace the micro switch and solve your problem.
Posted on May 20, 2009
How to repair maytag washer so it stops blowing fuses
The problem may not be with the washer, you may have it plugged into a circuit that made to carry the load. Check the owners manual to see if it tells you what the draw is and then see if that circuit is made to carry that large of a load
Oct 18, 2014 | Maytag Neptune Washing Machines
KEEPS BLOWING FUSE WHEN I CLOSE THE LID
its in the lid switch safety assembly,there is a glass cartridge fuse on this board and if the lid switch sticks it will blow this fuse to power down the machine to protect the uses from it spinning with the lid open this board is available from most maytag dealers or appliance parts dealers
Dec 11, 2012 | Maytag LAT2600A Top Load Washer
I own a maytag atlantis top load washer model LAT4914AAE and the fuse located behind the knob controls blows when ever i go to wash a load
The reason the fuse keeps blowing is because one of the two switches their where the fuse is is bad and drawing to much amperage so the fuse blows. THe lid switch/fuse asm comes together and it should be replaced.
The part number for that switch assambly is 22001682 it could be purchased at your local appliance parts store or online at;
searspartsdirect.com
apdepot.com
partselect.com
apwagner.com
repairclinic.com
GENE
Sep 23, 2011 | Washing Machines
I have a Maytag Atlantis MAV 7600CGW that keeps blowing the 10A fuse prior to the switch mechanism. This has happened 6 times in the last 12 months. Every time it is the 1st load after after a heavy load...
HI,
I have found the possible cause to your fuse problem, I would suggest replacing your lid switch to the unit, this can cause you fuse to blow. Item #3 below is the switch Part# is 22003804, I and hopeful this will correct the problem for you. Is part should con with the Item #7 in the picture also, replace them both, made even be a different color. I think gray is the color right now.
Jul 28, 2011 | Maytag MAV7600 Top Load Washer
Cooktop keeps blowing fuses. when we hit the
you will have to remove top and find short . it sounds like a burner of melted wiring. .. also ck the swithces for dark connections as the could be the cause. mm
Jun 30, 2010 | Maytag MEC5430 Electric Cooktop
Fuse blown on Maytag washer
Could have been a surge dont think its anything to worry about ....run and keep an eye on it ....
Apr 12, 2010 | Maytag PAV2300 Top Load Washer
Fuses keep blowing out
IF water is not going in the drum It sounds like the water valve coil has finally failled , It has been blowing fuses ,because the ccoil on the water valve was getting weak . change this water valve and you sohould be ok , but before doing so chaeck to see if you have the proper voltage going to this valve when It is calling to open ,if the power is there and the water is turned on the valve should be letting water in the machine . you can also take a ohm meater and check the valve for proper resistance . . If the machine is up in years I would change this valve . from the chack I mentioned earlier . hope this helps you
Nov 03, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag stackable w/d
Yes, it is inside the front washer lower front panel. Turn off poawer to unit and change w/ 1Amp 250V (regular of slow-blow). Then try only opening washer lid door with full dial pushed in (that would be the 'off' position. Only open/close lid w/ dial in off position. If washer works normally, may have a temp solution. Mine started this way, but ultimately the double relayed door lid switch was going bad and I had to replace it. Instructions/pictures below. Good Luck
AT702
Jan 27, 2008 | Maytag LSE7806A Top Load Stacked...
Fuse keeps blowing out in my maytag washing machine
the power surge probably shorted out something in the main wire harness or fried your motor. remove the screws from the control panel and look for any wires that are discolored, charred or disconnected. in the event you do't find it there trace the wiring thru the cabinet looking for the same thing. if you don't find that, replace the motor
Nov 16, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Maytag SAV571EEWW Washer Logo
725 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
