Question about Connex 4600 Base CB Radio
Connex 4600 turbo. Poor receive. About 4 mi.
Installed in new truck and now have poor reception. Have had shop set swr. Ground is good. Powers comes off battery. Was getting about 30 mi. when I had a Viper ant. now have Browning ant. Also, have squeal when talk back is on. Shop said may need mod kit. Have electronics background. Is this mod something I can do?
Can i hook up an amp on my 4600 turbo?? I'm running a 4 foot Francis fiberglass are monkey made better? What would you do I can only talk about 5 to 6 miles.. I've herd these radios should rock. Please help
Posted on Mar 05, 2015
  • joe pelfrey Mar 05, 2015
    And what should my settings be set at? My Mike and rf gain are both full open with rf pwr running about halfway
Take the ground off the ant.if you have it grounded
Posted on Sep 05, 2010
  • 20 Answers
Hi there!!
The Connex 4600 Turbo is a very sensitive radio these radios don't work good at all with the stock microphone! The best microphones are the RK-56 and or the Astatic 636L which most people use and you shouldn't get any squeal. And make sure if that you are using an external speaker get it as far away from the radio as you can facing away from the radio so it wont feedback. As far as a Mod kit there are several ways to modify the radio which most are pretty hard and drawn out. but the most easy that used to be used is as simple as a diode placement in the right place which is old school but still works good. You must be very careful as if you are to slightly touch the wrong points the radio could be destroyed and no longer work so caution is to be taken if you don't know what you are doing please don't try it on an expensive radio!! If you want more info on the mod e-mail me
never the less a Modulation kit or modification wont help your Receive it will only help your Transmit signal!!
Dennis
Posted on Aug 29, 2009
Will a connex 4600 turbo cb radio operate cool enough in a dash enclosure?
I would say yes it has a large heatsink. The variable might be the tuning. But if it's amp is not being pushed any harder than factory you will be fine. Nice radio I prefer them over the 4400turbo and the 3600hp it has the board like a 4300 not the 3300s like the fore mentioned.
May 26, 2014 | Connex 4600 Base CB Radio
I have a connex 4600 turbo with a road king 56 noise canceling mic. My mic just started making a cracklin sound in my external speaker . It also shocks and burns me. When I key up and let go it stays keyed...
Sounds to me like the RF signal is leaking into the microphone. Check the cable to the microphone and see if the ground wire is bad. Check the SWR to see if it is high. The problem you are talking about is unusual.
Jun 28, 2013 | Radio Communications
What do you think is wrong with my connex 4300 HP, I turn it on it powers up,but no adio it has static. It seems to have a dead key and swing. Any ideas? Thanks Jim
You will need an SWR meter to check your antenna. FIRST.
I would find help at a local cb shop.. They SHOULDN"T CHARGE to help you SET the swr. only if you need a part or something ..
I don't charge to SET SWR"s .. only if the cust needs a insulating washer or another antenna, or new coax, so-239 etc... I would be glad to help you.. let me know if we can CB Shop Temple, TX
Any shop shouldnt charge you just to see if it works!!
Nov 25, 2011 | Connex CX-4300HP CB Radio
Poor radio reception.I've tried a new aerial mast,no improvement. CD player sounds fine. Any ideas? (Passat Est.2003)
Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 1 Subject: Model(s): Group: Number: Date: AM Radio, Poor Reception 1999, 2000 91 99--07 New Golf, New Jetta, Aug. 2, 1999 New Beetle, Passat Condition AM reception is poor. May be caused by: ? An incorrect antenna mast installed for the antenna base equipped with the vehicle ? Poor ground at the antenna base or radio ? Poor battery ground to chassis or engine ? Poor antenna cable connection at Radio ? Corrosion at the antenna coaxial connectors at radio or antenna Service Vehicles are equipped with either a Bosch or a Clarion antenna base mounted on the roof and (for shipping purposes) the appropriate matching mast is located in the luggage compartment. If radio antenna masts are removed from vehicles and stored until vehicles are sold, there is a chance that an incorrect mast can be installed at the time of delivery. Note: Mismatched antenna mast and base will cause poor AM radio reception. The antenna base and mast can be identified visually as follows: (Cont. on Page 2)91-A260 requires gloss finish antenna mast 57mm 49mm Bosch 91-A261 requires matte finish antenna mast 61mm 41mm Clarion 91-A262 Technical Bulletin Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 2 Bosch antenna ? Base (although oval) is more circular in shape (approx. 57mm x 49mm). ? Made in Germany stamped on underside of base. ? Two screws on underside of base are unpainted. ? Requires gloss finish antenna mast. Clarion antenna ? Base is more oval in shape than Bosch (approx. 61mm x 41mm). ? Two screws on underside of base are painted. ? Requires matte finish antenna mast. If antenna mast matches the antenna base correctly: -- Check antenna coaxial cable connections --arrows-- for corrosion and clean if necessary (DO NOT apply stabilant). Passat coaxial cable connection for radio is under the carpet on right side of tunnel near shifter. -- Ensure that coaxial cable is firmly seated in radio (Passat cable connection, see previous step). -- Check ground at the antenna below roof Nut --4-- (torque = 7+1 Nm) must firmly secure antenna to roof). (Cont. on Page 3)Technical Bulletin Important! Please give copies to all your VW Technicians C 91--99--07 E 1999 Volkswagen of America, Inc. 3 -- Check ground for radio behind radio on cross member (On Passat models as of Nov. 1998 beginning VIN: XE285000 ground for radio is on right side of center tunnel). -- Check engine compartment ground, left side, below battery tray; frombattery GND to body. -- Check engine/transmission ground on transmission, near engine block. -- If all grounds and antenna mast are OK. -- Replace antenna and coaxial cable assembly
May 06, 2011 | Car Audio & Video
Reception is very poor. Grounding issues? Please
Reception has little to do with grounding. The ground plan is for transmitting. As long as the coax is connected and is in good standing, it should receive fine regardless of grounding.
There are a few reasons you may have bad reception.
  1. Turn the RF GAIN all the way up. This is your receive sensitivity.
  2. Squelch is too high. It should only be turned up enough to cut out the background noise.
  3. Poor antenna. If the antenna is cheap, and not made well, this could be the problem.
  4. Not enough of the antenna above the vehicle. It needs to be at least 60% of the antenna above the vehicle.
Hope this helps!
Oct 21, 2009 | Cobra 29 LTD CB Radio
Connex 4600 Turbo
i have the same radio turn talk back off and there is enough power ull have talk back through you trucks radio speakers and it needs to be hooked up to the battery with at least 12ga wire
Feb 10, 2009 | Connex 4600 Base CB Radio
Poor receive with my Connex 3300 HP radio
get a K-30 antenna ist magnetic if that dont work your speaker in the Cb is broken
Nov 18, 2008 | Connex 3300 240-Channels Base CB Radio
Connex 3300hp
Poor ground shield, or poor solder joint in mic cable.
Oct 07, 2008 | Connex 3300 240-Channels Base CB Radio
Frequencies
i have a 4600 connex and if i turn the mic gain all the way up i get alot of modulation.can someone tell me how to fix that?
Feb 01, 2008 | Connex 4600 Base CB Radio
Radio Communications Logo
735 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Mitch Davis
Mitch Davis
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
