Question about Garden
Honda whipper snipper 4 stroke
Petrol has seeped into oil compartment & can't get it to start
  • 4 Answers
SOURCE: my fs 45 whipper snipper is starting but running
I have a Stihl FS 45 and have had problems with it running for a short time then cutting out. The problem is like to be either- the filter attached to end end of the fuel pick hose that goes down into the fuel tank is blocked or- there is a crackor split in the corrugated section of the fuel pick up hose between the fuel tank and the carburettor. If such a crack or split exists it will cause air to be sucked in with the fuel upsetting the fuel/air ratio. A new hose not adjustment is the only cure
Posted on Jul 16, 2009
  • 3 Answers
SOURCE: homelite whipper snipper is hard to start and its
I took mine back to Bunnings and the guy there said they had a number with this problem and have found that priming the bulb 20 times not 10 as per the manual, is the fix.
It certainly fixed mine
Posted on Sep 15, 2009
Testimonial: "Thanks, will try it!!!"
  • 203 Answers
SOURCE: My whipper snipper is petrol 2 stroke and does not
May have a screen in the exhaust that has plugged up with carbon. You can take the screen out and it will run properly if that is the problem. Otherwise, it could need a carburetor cleaning. If you are going to rebuild the carburetor, you probably should get a carburetor rebuild kit from a small engine repair center for your particular model.
Posted on Dec 29, 2009
rycgl
  • 1545 Answers
SOURCE: I need to know if the GMC whipper snipper takes
We only have unleaded here in the US, so use that and I recommend using any "synthetic" type of 2-Stroke oil. It is far superior to regular 2-stroke oil and helps your machine live longer.
Posted on Nov 27, 2010
  • 316 Answers
SOURCE: what is the ratio for oil to petrol for mculloch whipper snippers
hello sir, the gas / oil ratio is, 3/4 o/z per quart or 2.6 o/z per gallon of two cycle oil, any two cycle oil will do,this is how i mix mine and never had a problem,it is a good mix.hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you. ~~
Posted on Feb 19, 2012
Does anyone have a manual for this petrol line trimmer 2 stroke , and how to thread new line please
only a facebook vidieo
https://www.facebook.com/Nambucca-Valley-Whipper-Snipper-Chainsaw-Mower-Recycling-ServiceRepairs-803906806364452/videos?fref=photo
May 02, 2016 | Garden
Victa Tornado Whipper Snipper 2-stroke. Why doesn't it start?
Rebuild or replace the carburetor. Whichever is cheaper and that should solve the problem
Feb 04, 2016 | whipper snipper Garden
I have a stihl 2 stroke petrol whipper snipper. It seems to have over heated at the reel end. I have smoke and grease spewing out at that end (metal neck at the reel end) have I fried it?
Sounds like you have a straight shaft trimmer version that have got bad bearing(s) that needs replacing. It probably will take the whole gearbox as a replacement item.
Jan 20, 2015 | whipper snipper stihl fs 38
What is the ratio for oil to petrol for mculloch whipper snippers
Jan 24, 2012 | Garden
What is the fuel mixture?
hi there
pfrolander
the ratio of oil to petrol you should use is 50:1 ( that is 20 mils of hi quality 2 stroke oil per 1.0 litre of petrol you mix ) using hi quality sthil / husqvarna 2 stroke oil
1000 divided by 50 = 20 mils of oil per 1.0 litre of petrol
NOTE if you do not have any hi quality 2 stroke but some from your local garage ( that you may use in say a scooter for example use 40 mils of oil per litre it is richer
this will do the job
cheers hope it helps
May 27, 2011 | Ryobi 30cc 17" String Trimmer Zrry30530...
I need to know if the GMC whipper snipper takes unleaded or leaded petrol and what sort of oil.
Nov 26, 2010 | Garden
Victa tornado 2 stroke carburettor diagram
I have a victa tornado whipper snipper it won't start. If I poor a lil petrol in carby it will run till fuel burns off than it dies. If I press the fuel build in it pumps fuel through an ideas what could be wrong with it
Oct 30, 2010 | Garden
My 2 stroke whipper snipper won't start
As with all 2 stroke engines,
1. Pump the fuel plug. 3 -5 times.
2. Turn the stop botton onto start.
3. Choke onto hot.
4. Pull the cord . Most important... dont touch the throttle trigger when pulling the cord. Wait until until it starts up.
If you do. (like it says in the instructions, your flooding the engine)
Works every time for me on everyone's whipper snippers.
Feb 09, 2010 | Ryobi Garden
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
