Lg flatron w1943se
Keep display power saver mode.anyone got solution???
  • 16 Answers
SOURCE: Power saver
This problem is showing when the main PCB of the monitor failed. Mr. Ravis not to worry you have warranty, contact the LG service provider in your area. They will change the PCB. check this link to get the service center info
http://www.lgservice.com/
Posted on Feb 09, 2008
leroyal
  • 2120 Answers
SOURCE: LG Flatron W2234S monitor seems to be in sleep mode.
the backlight fluorescent bulb is burned out
Posted on Dec 26, 2008
  • 2841 Answers
SOURCE: after starting, my monitor displays "power saving mode".
Go into the menu and reset the monitor to factory defaults.
Posted on Aug 28, 2009
bhagyavichar
  • 414 Answers
SOURCE: LG FLATRON L1922P MONITOR STUCK IN ANALOG MODE
probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/addon/daughter cards..
assuming that ur not using any backup devices such as ups/inverter/cvt so on..as u didn't mention..
also assuming that the bios has not been flashed in a wrong way..
..plz do check the following as in order:..
the Hardware part:..
1)a) in power-on mode, open/unplug the data/vga cable of the monitor from cabinet..see if raster or 'osd' is appearing on the monitor screen..if so monitor is ok..else replace the monitor and see..[not applicable in case of laptop]..
b) in case of laptop try to get output from external display unit/monitor using vga port..if there's proper display in there..the problem is probably with either the 'lcd' or 'ccfl' or 'inverter circuit'..
2) if u hv a graphics card, replace with a standby or onboard and see..[not applicable in case of laptop]..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4) see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
5) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
6) remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
7) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market)between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
8) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(espabove1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
9) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue);-5v(white); +3.3v(orange)..the 'oscillator and error amplifier ic',or pwm switching regulator circuit..look for defective protector-transformer/resistance (esp 4.7k)/mosfet..
check the battery n adapter [main power], in case of laptops..
if u r not a professional, seek advice of ur system admin/vendor....
Posted on Nov 23, 2009
budmrtn
  • 11361 Answers
SOURCE: I have a LG Flatron and it is stuck in the power
Try it on another PC first, if it still does the same then you need to open it up.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 22, 2010
Power saving mode displays again and again while i turn on monitor. Also f-engine change node automatically.
right click on the desktop -- properties -- screen saver -- power -- turn off monitor select' never'.
Apr 16, 2010 | LG Flatron F700P 17" CRT Monitor
I turn on the monitor and it goes straight to power saving mode? Can anyone give me any advice????
Dear. You need to change the power setting. Plz follow the 4 simple steps.
1. Click right button of mouse on desktop.
2. GO to properties.
3. Click on Screen saver.
4. Click on power n here u can adjust time.
Thanks
Jan 29, 2010 | LG Flatron L1510S 15" LCD Monitor
LG 1750s monitor goes into power saver mode in 5-10 min
change the setting in the screen saver option (Power)
or look in Power in control panel...also check the hybernation time
Dec 18, 2009 | LG Flatron L1750S 17" LCD Monitor
My monitor lg flatron l1730s keeps going into powersave mode
check your powersaving options in windows>control panel>power options
there is a bunch of options in there that could make your monitor go into power saving mode.
also check your video card options and menu of the monitor itself all could possibly contain a sort of powersafe option.
most likely indicated with amount of minutes untill... either power off screen blank or screen saver.
Dec 19, 2008 | LG Flatron 915FT 19" CRT Monitor
How to temporarely disable analogue power saving mode
Go the desktop, right click with mouse and select properties (if it XP) then it will open Display properties --> there you need to go to Screen saver and then to power option
Disable any power off mode on/ Sleep mode. It will solve your problem.
Please rate the solution. Otherwise let me know for further assistance.
Nov 13, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Stuck in power saver mode
Nov 03, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Analoge safe mode
Go the desktop, right click with mouse and select properties (if it is XP) then it will open Display properties -->
There you need to go to Screen saver and then to Power option
Mar 19, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
Jan 26, 2008 | LG Flatron L1511S 15" Flat Panel LCD...
Power saver
Dec 23, 2007 | LG Flatron L1750S 17" LCD Monitor
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
