Bailey caravan problems
Left side lights on my bailey ranger 2006 aren't working ,brake light and inte rgaters work fine,where fine when I last used it.
How many caravanners out there has had problems with the cpi pn the Bailey GT65
Posted on Mar 21, 2014
No back or side lights
bad earth or ground connection is the main cause of this problem ,yes it looks like their working but remove the covers and check the other bulbs and you will see a faint glow when using the lights that do work ,this indicates a bad return connection either in the socket or in a connection box if fitted or just corrosion in the light units
Jul 13, 2015 | Cars & Trucks
How do I change the voltage meter on a bailey orion
I have just sorted the same problem on my van. The power supply was working fine, everything 12 volt worked with mains connected, but the battery wasn't charging, and the 12 volt lights wouldn't work if the mains was not connected.
After spending several frustrating hours with a multimeter, I worked out that everything on the power supply side was working fine, including the output circuit for battery charging. That only left one thing - the cable that runs from the power supply to the battery. I put the caravan up on ramps and climbed underneath. I found the cable that goes to the battery and there was a connector in it. I pulled the connector apart and found the metal blades inside had corroded away. I bought and fitted a new connector, and filled it with silicon sealer so it is completely sealed against moisture ingress. Problem solved.....good luck
Oct 03, 2014 | Cars & Trucks
1995 Dodge Dakota signal light and brake lights quit
I had the same problem that the brake light / turn signal on the right side didn't work (in the 2006 Dodge Caravan it's the same bulb). After a long search I found the problem: There was corrosion on the contact of the bulb assembly. After scraping off the corrosion everything works now.
Dec 20, 2011 | 1995 Dodge Dakota
My abs brake light stays on in my 2006 dodge caravan, the brakes are working fine.
Check fluid levels; generally this is one problem with one or more speed wheel sensor.
Jun 03, 2011 | 2006 Dodge Caravan
2006 cadillac CTS 2.8 v6. Two side brake lights went out
im replacing the BPP sensor on one now, Brake Pedal Position sensor
Jul 14, 2010 | 2006 Cadillac CTS
2006 Ford Ranger. Rear passenger side tail light
Bad earth connection.Clean or replce wire.
Jun 18, 2009 | 2004 Ford Ranger
2006 Cadillac CTS Brake lights out
I have 2006 cadillac CTS 2.8 v6. Two side brake lights went out and don't work only when you use brake pedal, when i use the alarm on the car they flash like they should so the lights are fine. The light in the middle works fine so do the turn signals.
May 02, 2009 | 2006 Cadillac CTS
Need to find fuse box inside cab to replace brake light fuse. Brakes don't light up when depressed.
Most fuse boxes are on or near the kick panel (left side of vehicle) under the steering wheel. Some (additional) fuse boxes are under the hood,
Apr 29, 2009 | Ford Ranger Cars & Trucks
Computers & Internet Logo
312 people viewed this question
David Payne
David Payne
