Power light blinking on/off. No sound or picture.
Checked all connections are good, cable power is good.
  • 187 Answers
Should be a mainboard or powerboard issue, if you post brand and product code i can be more specific.
Also be a little bit more detailed on the sympton (what, how and when) and I should be able to get you a better answer.
Bye
Posted on May 27, 2009
We have an 11 yer old sony wega KV-32FV15 We lost picture and sound. Power on swirtch activates the standby red light which just continues to blink (no Sound no Picture0 We know we have the power plug...
the tv is defected needs to be repaired..have a tech repair your tv.the problem is in the power supply or horizontal circuit.could be any thing in one on those circuit.good luck.
Aug 28, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Pop sound and now no picture or sound still gets power
Try disconnecting all the cables from the TV then reconnect them after a few minutes. It's suggested that you connect the power cable from the TV directly to a functional wall outlet.
If still there is no picture on the TV then it's required to replace the projection lamp.
Sep 08, 2009 | Toshiba 57H81 57" Rear Projection...
Red light blinking no picture no sound
tart checking the cable connection to receiver, try moving or replacing cables.
If you have a surround with external speakers check surround connection cable and speakers wiring.
If the cables are OK, then the unit may be faulty.
In that case the fault can be either the audio board (often audio circuit is integrated on the main board) , or the sinput output signal board.
Also a contact on connection to internal speakers can give you same problem.
May 22, 2009 | Toshiba 32A43 32" TV
No Picture or sound
The lamp cover door was not secured tightly. Door does not "push" shut easily. Got a little rough with it and latched it shut, then the tv worked fine.
Jan 27, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
No power, power supply & motherboard green light blinking
I had the same exact problem for the same exact reason. Plug the power cable into the back. Open up the side of the case and unplug all the wires that the power supply plugs into. The motherboard, harddrive, cd & dvd drives, everything. wait about 10 minutes and plug them back in, plugging the BIG cable that connects to the motherboard back in LAST. This will make the light go from blinking to solid. I think it is a safety? to protect the motherboard from damage.
Nov 01, 2007 | Sony VAIO VGC-RB42G PC Desktop
No picture, sound OK...setup menu shows up, able to get picture in PIP
You will need to check the inputs on the television. You more than likely have a bad video in signal. This can be a bad cable or a loose connection either at the input of your television or at the output from your receiver, (cable or satellite). First, try wiggling the cable and then try replacing it. This should fix the problem. If not, your signal may be routed through a stereo or other switching device?
Apr 17, 2007 | Samsung PCL541R 54" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
