Question about Kyocera Mita FS 1010 Laser Printer
Kyrocea FS1010 not printing PDF documents
When trying to print PDF documents on the Kyrocea FS1010 it brings up the paper jam light. Have to switch off/on to reset. Will print WOrd documents OK.
vkyhunk
  • 156 Answers
SOURCE: it keeps on printing test pages
Uninstall the PRINTER'S DRIVER SOFTWARE completely from your system, MAKE SURE YOU USE THE PRINTER'S DRIVER DISK FOR IT OR ANY UNINSTALLER SOFTWARE FOR IT DONT UNINSTALL IT FROM CONTROL PANEL.... DISCONNECT PRINTER, TURN IT OFF. Clear All Temp And Prefetch Files. Restart Your System, Turn On Printer, Hook It Up To Your System,,, Go To The Manufacturer's Website And Install The Latest Driver Software And Firmware If Available....
Posted on May 21, 2009
Tualiapz
  • 80 Answers
SOURCE: can't print entire pdf documents only first page.
There may be a few possible things for your to try. Below is the list of things you can try.
1) Reinstall the PDF software that you use to open your pdf documents. (reader or acrobat) *restart machine after reinstall.
2) Remove the printer from your list of printers and faxes then add it back again
3) Restart the spooler service
click start -> run
type services.msc then ok
on new window, look for print spooler, right click and select restart service.
Posted on May 29, 2009
n25an
  • 622 Answers
SOURCE: Kyocera Mita FS1010 fault
check your user guide... it will explain this error... or contact kyocera customer support...
Posted on Dec 24, 2009
  • 503 Answers
SOURCE: Had a paper jam and was printing a total black
Three suggestions for you
1- check your toner cartridge, might be empty, totaly black page will use enough toner for about 200 normal pages worth of toner,
2- did you use a cleaning solution on the drums? if you did then you could be facing a slippery drum, as in the toner will not adhere to the drum long enough for it to print. You are going to have to wait untill you print enough to wear this layer of cleaning solution off.
3- some printers and i think yours is one of them use a type of print film in the system. Not sure how or what this film does, but if it is not put back in place or it is fed into the unit wrong , then your printer will not print,
That's it for my ideas. Hope one of them works for you.
Posted on Mar 12, 2010
  • 4044 Answers
SOURCE: The Kyocera Mita FS1010 has
I can't open the downloaded manual I found on this printer but this sounds a lot like a paper sensor issue. Sounds like the sensor is sending a bad signal or jam signal that is causing the panel warning to light up.
Posted on Nov 01, 2010
Printing multiple page pdf on kodak esp c310 AiO
I had exactly the same problem as you! Whenever I printed anything of more than 1 page the paper jammed. I now know why... When you go to File>Print in Adobe reader, the print window displays a load of options. Simply uncheck the 'Print on both sides of paper' box. This worked for me! Hope it works for you!
Eoghan12
Jan 31, 2012 | Office Equipment & Supplies
When printing from word the paper jams in printer.. works fine in all other programs
I work at a printing center at my college, sometimes this happens to the students that print. When printing it could be the word document itself: the file could be too big, or the printer could be reading the file wrong. Try saving the word document to a PDF (Print, Print as PDF), then try printing it. That way the printer reads it as a sort of image and not a .doc file, or .wrd file.
May 04, 2011 | Microsoft Office Word 2007 Full Version...
I have a paper jam i cannot find on a kyrocea fs-1300d any suggestions how to find and correct this problem?
Hi
1. Paper jammed can be found in the paper tray. Just remove all the paper and inspect paper jammed from the feeder roller.
2. Paper jammed can be found in the toner cartridge compartment. Remove the toner cartridge and inspect for paper jammed.
3. Paper jammed can also be found in the rear door of the printer (back door of the print). Check if there is a back door and inspect for a paper jammed into the roller.
4. Paper jammed can be found in the toner cartridge itself. Check for teared paper inside the toner cartridge.
Please let me know if you need more help
Mar 05, 2011 | Kyocera Fs-1300d Printer
Unable to print to canon IR7200
More than likely their is a problem with the file or that it is too large to process and has gotten stuck in the que on the copier. Go into printer set up and find restart server or clear server - it's ussually at the back end of all the settings. You want to clear the server and restart it. Then try printing a few pages of the file to see if their is an issue with it. If that prints then print half of the file, if it's has a lot of graphics pick a smaller chunk. You can also restart the server through the copiers internal web page - to get to that type the copiers ip address into internet explorer and it should bring it up.
Dec 26, 2009 | Canon Office Equipment & Supplies
My Brother HL-2040 paper led light won't stop flashing, the paper's not jammed or anything, I just put in a new toner, too. I tried doing what someone else said about opening the cover and holding Go until...
Hi. The reasons listed in the manual that cause the LED to flash normally are:
Front cover is open
Close the front cover of the printer.
Back cover is open
Close the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 6-5.
If the printer does not start printing, press the Go button.
No paper fed manual feed slot
Put the paper in the manual feed slot. See Printing on plain paper, bond paper
or transparencies from the manual feed slot on page 1-10 or Printing on thick
paper, labels and envelopes from the manual feed slot on page 1-13.
Memory full
The printer memory is full and the printer cannot print full pages of a
document. See Solving print problems on page 6-15.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document.
Drum Error
The corona wire needs to be cleaned. See Cleaning the corona wire on page 5-14.
If you check out page 6-5 it tells how to clear the paper jam from the rear of the machine! A point often missed.
Check out the website below if you don’t have a copy of the instruction manual =
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002089/US_Eur.pdf
If all else fails, try a reset of the printer Drum & Page counter:
  1. With printer tuned on.
  2. Press and hold the “internal button” behind front cover, until all LEDs illuminate.
  3. Make sure Drum light is off, then release and close front cover.
Hope some of this helps………..Please post a response back here and let us all know if it works?............Regards, Cornwellnet (UK)
Jul 12, 2009 | Brother HL-2040 Laser Printer
Error light keeps on flashing blue light at the
These are your possibilities based on your error.
Front cover is open
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
Memory full
The printer memory is full and the printer cannot print full pages of a document. See
Solving print problems on page 97.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document. See
Jun 14, 2009 | Brother HL-2170W Laser Printer
Printer Problem
hi there... our copier in the office is also kyocera... and i also encountered that same problem before.... try to check all areas of your machine especially those that passes the paper... maybe it's still has a piece of paper stuck in it thats' why... that's always the problem of kyocera machine... it is so sensitive...
Feb 28, 2008 | Computers & Internet
Duplex Path, paper late jam
Can you save that one document as a pdf and print it?
Feb 20, 2008 | HP LaserJet 2420 Printer
Brother HL-5250DN printer paper light won't go off
I had the same problem on 4 Brother HL-5250's, I checked the whole printer, and couldn't find a paper jam, yet the red printer light wouldn't shut off. I finally followed the instructions on Brother's website for removing a paper jam, and the solution for all 4 printers was paper stuck in the fuser cover. See below on how to open the fuser cover.
Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
  2. Hint
  3. There are 2 kinds of covers at the rear of the printer. Please make sure to open both the back cover (step 7) and the fuser cover (step8).
Here's the link from HP, on how to open the Fuser Cover.
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/000000/000026/faq000026_007.html?reg=eu&c=eu_ot&lang=en&prod=hl5250dn_all
Oct 05, 2007 | Brother HL 5250DN Laser Printer
Kyocera Mita FS 1010 Laser Printer Logo
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
