Panasonic u11 - na148vg4
Showing this fault code and cannot open door
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: hotpoint ultima washing machine showing fault code
Error code F05 indicates pressure switch jammed on full.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Make sure there is no water in drum before you start.
Please rate my solution.
Thankyou.
Posted on Jan 27, 2010
blueextc3221
  • 15935 Answers
SOURCE: got error code u11
u11 is not a valid error code - please recheck.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 16, 2010
I have panasonic eco drive washing machine model NA-FS14x1 have error code H57 how to repair
Unscrew the back of the machine to look and see if there is any water in the base of the machine.
How old is your machine? If it's new I'd exchange it for another one like the LP or even Mag tag-
It's not easy to fix these machines and finding the real problem is sometimes a night mare.
The Panasonic error codes are difficult to find, but 'H' faults are generally faults which may or may not be repairable. Like the sump pump -or motor.
The other codes are like this: U11 indicates machine unable to drain. Blockage between drum and drain pump?? Blockage of drain hose??
U13 indicates unbalanced load. Many modern machines suffer from this, but may be related to problem causing U11 fault.
H43 indicates an internal water leak reaching its detector in the machine base.
Like any washing machine, they are great until they go wrong. The problems are usually related to the after sales service.
I hope something helps here-just my 2 cents worth!
Dec 23, 2012 | Dryers
Won't recognise DVD Ram and non-finalised discs from own recordings.
Usually, the U11 error code in a Panasonic DVD player indicates an optical problem. You could of course try doing a cleaning using a CD cleaner normally readily from computer parts stores. Alternately, you can open the unit up and do a manual cleaning with soft bristle brush and/or cotton buds. Other than that, it could be indicative of a weakening laser eye which of course would require parts replacement.
Hope this be of initial help/idea. Pls post back how things turned up or should you
need additional information.
Good luck and kind regards.
Thank you for using FixYa..
May 24, 2008 | Panasonic DMR-HS2 DVD Recorder
U11 error code panasonic md 9000
i am 100% sure that it is the play head of your md 9000 that is dirty or faulty
solution
1)get a play head cleaner,put your cam in playback mode then play it to the end,then you can now confirm with a new tape
2)if solution 1 do not solve your problem you need to change the play head of the cam
Sep 19, 2011 | Panasonic NV-MD9000EN Mini DV Digital...
Panasonic washing machine NA-168vg3 stopped with 31 mins to go giving error code U11
U11 is inability to drain. Check your filter. Check your outlet hose. If you can blow down it, then your pump's jammed. I just found headless metal rivet type pin in the pump. Take the drain flap off, and remove the screw. This whole width panel now moves off to the left.Lean the machine on it's side, take off the black plastic plate. Remove the two screws from either side of the filer on the front. Pump is now loose. Remove the three screws on each pump and check if anything is stuck in the impellers.
Refitting is the reverse.
I know this is an old post, but someone may find this useful!
May 18, 2011 | Microwave Ovens
Always get a U11 code when using blank dvd-r to record
You could try using a DVD lens cleaner (wet or dry type, whichever is available; but it MUST be the manufacturer's recommended DVD lens cleaner (or suitable equivalent) - do not use CD/DVD generic cleaners, they might be cheaper, but these do not work and may damage the unit).
If after following the directions on the pack, the recorder still shows U11, then the drive is probably on its way out. Considering the cost of a new DVD-RAM drive is around $300 or so, plus labour (if applicable), it may not be economical in the long term.
Nevertheless, try cleaning the laser lens (either with the DVD cleaner discs), see how you go. I usually try to avoid opening drive units up in cases of cleaning, however, I have found short bursts of compressed air through the drive from front to back usually solves most dust-related problems.
Feb 13, 2011 | Panasonic DMR-E30 DVD Recorder
My panasonic dvd player is displaying error u11 code wont play any dvd's
If you are trying to run a recorded DVD (saved a video or movie on to it), it could be the quality of the disc. I would recommend buying quality DVD's, the lower quality ones can create read errors (U11).
Jan 25, 2011 | Panasonic Televison & Video
Bosch SHU3036UC/U11 dishwasher does not stop filling with water
It sounds as if the main program board has developed a fault - as it should come to a complete stop. The fact it kept the water valve open with the door open is a serious fault- so I would have it checked before using it again.
Most machines have a water-stop feature - so if it develops a leak - it will shut off the water. This clearly didn't happen.
Aug 05, 2009 | Bosch SHU3036UC Dishwasher
Got error code u11
Mar 12, 2009 | Washing Machines
It reads u11
U11 means "incompatible disc"
Either you are trying to read a disc outside your region (region 1 discs required for U.S.) or the player has gone bad.
Jul 09, 2008 | Panasonic Televison & Video
I have a panasonic dvd recorder modol dmr-e30 when i load the dvd i get the error message u11 how can i resolve this problem.
Has anyone found a solution? I was recording movies everyday and then it stopped and says U11. I am using the same discs as before.
Jul 02, 2008 | Panasonic Televison & Video
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
