Question about Asko D1706 Built-in Dishwasher
Gets stuck during cycle and continues to heat
Kenmore ultra wash dishwasher gets stuck at 42 on the control panel
Be aware that all (well, almost all) dishwashers have a "thermal hold" period in their cycles. This is the point in the main wash cycle where the heater is turned on to heat the water to the optimum wash temperature (about 150 to 160 deg F), and during this time, the timer will stop advancing. Once the water has reached the desired temperature, the cycle will continue. IF it does not, then you have a water heating problem. This could be caused by a bad heating element, a bad controller, a bad thermostat or temperature sensor.
Mar 20, 2015 | Kenmore Dishwashers
Samsung get stuck at 40 minute cycle
I think the dishwasher gets stuck at the point where it is supposed to heat the water. If it can't heat the water (because the heating element isn't working, or because the heater relay inside the controller is bad), then it may stay there indefinately. In other dishwashers, the timer/controller will give up after 3 or 4 hours and finish the cycle. In others, the dishwasher will shut down and indicate an error condition.
Sep 20, 2014 | Samsung 24 in. DB5710DT Stainless Steel...
Mistral Dishwasher Getting stuck through cycles
Dear Sir:
See this possibles causes:
Water-heating cycle
the water must being heating( the lack of this is by heating element or thermostat) stopping in that cycle. test it see how, lets see the video.
Timer
test for defective, clean contacts, loose wires, breake or burn. use the VOM, see how.
May 26, 2012 | Dishwashers
Whirlpool dishwasher stuck in cycle
I found this:There are are 2 stats, hi limit and operating. You should find them attached to the pump housing. It gets a little tricky but the problem will boil down to one of the stats is bad or the heating element itself is bad [or something like a wire burned off at the element which will be obvious]. It can get a little tricky. I would start by checking to see if the element gets hot during operation. If no, ohm test the element itself. If ok, ohm test the high limit stat, it should be closed at room temp. If ok, try bypassing the operating stat and see if the element now gets hot during operation.
Read more: http://www.doityourself.com/forum/kitchen-laundry-large-electric-appliances/386770-whirlpool-dishwasher-gets-stuck-cycle.html#ixzz1kDTDjTm7
Jan 22, 2012 | Dishwashers
During wash cycle it gets stuck and won't move past the wash cycle. On a regular wash it is at 28minutes and when it is on a fast wash it is at 25 minutes. If I stop it and turn on the rinse cycle it will...
I've got the same problem with the bottom drawer on the DD605. No fault codes were set. I checked the heating element and it produced heat quickly. I suspect that the water temp sensor isn't satisfied, and the timer is waiting for the water to reach the correct temperature. I called F&P's 24/7 helpline and they seemed to have no knowledge of this issue (clearly, it's not uncommon), other than suggesting that I disconnect it from the power supply for one minute, which didn't solve the problem.
Apr 26, 2010 | Fisher and Paykel DD605BK Dishwasher
The dishwasher gets stuck at a certian point during the cycle. How do I fix this
It's possible your water is not hot enough, and the washer goes into a pause heat mode. There also could be a problem with the heating element in the d/w.
Jan 02, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Timer (cycle knob) gets stuck on occaision and
possible that its the timer more likely an internal blockage main wash water level not being reached and activating heater if the water does not reach temp selected for any reason the appliance will stick at the heating phase also if your dishwasher is getting old over 10 years wiring loom in door may be breaking down, will need service to sort out
Nov 04, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher will not run through its cycle
Hi
If the cycle doesn't complete, check these:
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
Please revert for further assistance and Do rate the solution as "FixYa" if found useful.
Thanks
Rylee
Mar 26, 2009 | Dishwashers
Cycle stops, won't drain
This is either a bad timer or a bad heat sensor. On most cycles that call for the water to be heated it will pause the timer and continue washing/heating until the sensor is satisfied the water is hot enough. Try selecting a quick, delicate, or china cycle without heated rinse or dry. If it works this way the timer is fine but the sensor is bad. Sometimes cold water to the machine will cause this problem because the machine is not capable of totallly heating cold water. It is only designed to boost the temp. Make sure you run hot water at the sink before you start the machine.
Jul 03, 2008 | GE Nautilus 24" Built-in Dishwasher
Stuck on Glass cycle!
Hi melH Sounds like the water is not heating. Will be either an open circuit thermostat, heater element, or the switch / relay that controls the element. Using an ohm meter, test the element for resistance. Check thermostats for continuity. Regards
Aug 20, 2007 | Smeg DWI614 Built-in Dishwasher
Asko D1706 Built-in Dishwasher Logo
32 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
