Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
When the cycle starts F1 appears on the dial,
We clear it and it appears again later in the cycle. It now doeas it with each load.
  • 32 Answers
Call mfg. i heard they are fixing this problem even washer is out of warranty. to solve this problem your washer need new control board.
Posted on May 24, 2009
2 Suggested Answers
  • 272 Answers
SOURCE: When the cycle starts F1 appears on the dial,
Here is a link to the service repair sheet at Whirpool for the F1 error code on your machine. You will find 4 things to check at the bottom of the page. Good luck.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/d12cd4888abce86285256a42005ea985/1a4cb9c9ab426640852574e90050e40f/$FILE/8178767.pdf
Posted on Jun 01, 2009
My front loader washing machine suddenly stop working at there is an LE sign
LG, the electronics and appliances conglomerate, manufactures a variety of high-efficiency washing machines. Whether you have a front- or top-loading model, your LG washer is equipped with an error-monitoring system. When the LE code appears in your display, it indicates a problem with the motor. The problem can be related to several different issues. In order to clear the error, determine which issue is at hand.
New Installation The LE error code may appear in an LG washer's display if installation issues exist. It indicates a miscommunication between the wash motor and the control panel. In most cases, you can simply reset the washer to solve the problem. Unplug your washer before pressing and holding the Start/Pause button for approximately five seconds. Plug it back in and set the washer to a rinse-spin cycle to see if the code has cleared. If the code reappears in the display, contact LG at the phone number in your owner's manual for assistance.
Thermal Overload Protection Your washer may display the LE code if the thermal overload protection circuit in the motor has been tripped. The feature is designed to prevent the motor from overheating and causing permanent damage to the washer. To clear the error code, the motor must cool down. Allow the washer to sit for approximately half an hour before restarting the cycle. If the code reappears, the motor may have an issue that requires a service call. Unplug your washer and contact LG.
Excessive Suds If your washer detects excessive soap suds in the drum, the LE error code can appear. Typically, excessive sudsing occurs when you use too much high-efficiency detergent or a detergent that's not specifically high-efficiency detergent. Always follow the guidelines in your owner's manual and on the detergent label to determine what type of detergent, and how much, to use. To get rid of soap suds in the drum and clear the code, unplug your washer and let it sit for a half hour so the suds can dissolve. Plug the washing machine back in and turn it on, hitting the Spin Speed button and selecting "No Spin." Press the Start/Pause button to turn on a drain only cycle. When the cycle is completed, remove the load from the tub. Start a rinse-spin cycle to clear away any residue. You may need to repeat the cycle to remove all of the suds.
Load Issues The LE error code can appear in an LG washer's display due to certain load conditions. If you are washing a large load, don't choose a gentle cycle like Delicates, Hand Wash, Perm Press or Wool/Silk. Reserve them for smaller loads. To reset the washer, unplug it and press the Start/Pause button for five seconds before plugging it back in. The LE code can indicate that the washer has been overloaded; large loads and bulky items can strain the motor. Remove a few items from the washer to reduce the load size and restart the cycle. If the code appears again, let the washer sit for a half-hour so the motor has time to cool down before you restart the cycle.
Feb 28, 2015 | Washing Machines
In a rush to leave I interrupted the final spin cycle on my Whirlpool Duet Front Load Washer GHW9100LQ0. The door opened and I transferred the load. For the next load the machine will not run. The...
Hi!
Please try the following:
1. Unplug the machine from the main power supply (carefully, no wet hands!)
2. Wait for about a couple of minutes
3. Plug the machine back to the power supply.
After that it should be working again.
Please let me know if it helped,
Regards,
Bogdan
Aug 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite smartwash QuietPak9 F H error code
Press the Pause/Cancel button twice to clear the display then check if water is introduced into the machine. Drain the water from the machine by selecting Drain and Spin then pressing the Start button for one second. Empty the machine after the water is completely drained.
Start a new cycle with Hot/Cold water temperature and check how long before the error code appears after the cycle is started. When the code appears, press the Pause/Cancel button to clear the display then check again if water is introduced into the machine.
The pressure switch is not tripping and must be replaced if the error code appears about 8 minutes after the cycle is started and about 40 liters of water is introduced into the machine.
The flow meter is not working if the error code appears less than a minute after the cycle is started and about 3 liters of water is introduced into the machine.
The valve solenoids may not be working or the levers are stuck if the error code appears less than a minute after the cycle is started and no water is introduced into the machine.
Let us know which case above is observed for specific troubleshooting and repair guide.
Mar 09, 2010 | Kenmore Elite 45986 Front Load Washer
Malfunction indicator lited repeatedly
Probably is the throttle position sensor is bad. If you through several cycles and the computer does not see a problem then it will clear the codes until the problems exists again. That is why you see the light go out. You probably have a problem with the TPS.
Sep 14, 2009 | 2003 Honda CR-V
Jun 01, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Machine stops with SE code
That code (5E, not SE) means the drainage is clogged. The code appears after 15 minutes of trying to drain the tube (not sure that´s the word, may be turbine, barrel...). check the lateral filter (a big plastic twist-off cap) for any solid that may be clogging the drainage
Jan 16, 2009 | Samsung SW62ASP Top Load Washer
Print factory 2 Paper/CD jam fault
My e-mail is jounikontulainen@gmail.com.I could mail You technical document that might help.
Jouni
Apr 05, 2008 | MicroBoards PF-2 InkJet Printer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
180 people viewed this question
Dan Webster
Dan Webster
Sal De
