Black picture Hello, always when I turn it on it shows windows and then picture disappears like one driver's missing. Can someone help me?
    Sergeant:
  • 290 Answers
Boot up in safe mode (f8) so it will use the windows lo-res VGA driver. You can then install the proper driver and restart the PC.
Posted on Jan 01, 2014
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
My tv is showing double picture in blue, green and red.
You will need to see if the auto convergence feature is still listed under the setup menu or has it disappeared. Respond to this same post and let me know if its there or disappeared and I will assist with what needs to be done based on wether its missing or not.
Jul 23, 2011 | RCA HD52W59 HDTV Projection Television
Hello.. i have a 376 C and when i start it it sais System Sofware missing.. and it dosent do anyting else
Hello
the "System Software Missing" problem could be solved by perform the following steps:-
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the above problem.
If all else fails, you could always contact Garmin for help.
Good luck
Feb 15, 2011 | Garmin GPSMAP 376C GPS Receiver
No driver after reboot
Alas, driver to what. It always helps to state device, brand, model, operating system in a query.
Here is some information. No way for me to narrow it to the relevant device. Don't know what that is!
How to Fix Disappearing HP Printer Drivers Disable HP CUE Device Discovery...
Solved Need help Win 7 losing drivers after shut down reboot
https://social.technet.microsoft.com/Forums/windows/en-US/3339d135-ecbf-46d9-9e4f-d1ec187baaa8/windows-7-printers-have-disappeared-printer-spooler-wont-stay-running?forum=w7itprohardware
When Restart My PC My Video Drivers Disappear Graphics Cards
Some versions of Windows 7 have an XP Mode. The driver that ran perfectly under XP may do so there. That Windows 7 Home Premium is 64 bit may be a factor if the vanishing driver ran under a 32 bit XP system.
Aug 28, 2017 | Buffalo Technology AirStation...
Modem device on high definition Audio Bus for acer aspire 3680
These are the same thing , they will both disappear when you install the audio driver
http://support.acer-euro.com/drivers/notebook/as_3680.html
Click under Windows XP Drivers And Utilities And click Audio Driver
Always check the manufacturers site for your drivers!
Jan 24, 2009 | Acer Aspire 3680 Laptop
How to Solve Error code SC496 for Aficio 551
hello Sir; You have to empty the waste toner bottle it located right hand side bottom, open the doorlook at "A" area you will see a big narrow plastic bottle pull out a black buckle slide out the bottle, dump the toner,the code will be disappear!
Jan 06, 2009 | Ricoh Aficio 450 Copier
Magnavox 27MS4504 clicks, then dies
as always ck for bad connections. slap side lift sid drop  otherwise not worth repair.
Nov 30, 2008 | Philips Magnavox MS2530C 25" TV
Scattered black lines appear then screen gos black, but still have good volume
Hello 4fiddy,
You have actually diagnosed your own problem, Let me explain; the line "I can slap the left side of the tv and picture will almost always come back on" This indicate some form of poor connection (cold solder joint). If you have a soldering iron, solder (circuit type not pipe type), and a multimeter. Use the soldering iron and solder to redo the cold solder joints , and then test it (the connection) with the multimeter.
I hope this helps
Thank you,
Shuttle83
Sep 25, 2008 | RCA HD52W59 HDTV Projection Television
Hello
I have the exact same problem my camera does turn on and takes pictures but that screen is black.
Mar 14, 2008 | Polaroid I533P Digital Camera
Sony Trinitron - Picture Disappears
Hi, IK circuit is engaging which basically means the picture tube is getting tired, the only "fix" is temporary (may get another year out of it). You have to increase the "screen control clockwise".
Remove back of set, follow large black or red wire attatched to picture tube down to the flyback transformer, mounted on flyback are two black controls, one is focus (leave it alone) the other is "screen", adjust it clockwise approx. 1/4 inch, remember that this is a high voltage circuit so use one hand in the set the other hand out of the set at all times,any questions ? e-mail me back, good luck, BMW Rider
Feb 27, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Computers & Internet Logo
David Payne
David Payne
