Please contact me at this no.9213261399
My hard disk is not working properly i think its internal part is not working please contact me at this no.9213261399
  • 1,511 Answers
If you hear a clicking sound when the hard drive is trying to start up; then the drive is defective. If nothing happens when you start the computer, the operating system and/or drive are faulty. You need to get a replacement drive and install Windows again.
Posted on Jan 06, 2014
Harddisk security
press the helpful button and check out the link below
·Are you using internal or external hard disk?
·What is the make and model of the computer?
·Did you try contacting the Computer or Hard disk
manufacturer?
I would suggest you to contact hard disc manufacture and check for default password to unlock the drive. Info by John Rubdy
Hard Disk Password LaptopTips
Jan 31, 2016 | Computers & Internet
I would like my laptop back to where was before the hard drive crashed
The short answer is - No, you are in bad luck. :-(
The longer version: It depends on what really happened to your drive. If the content was deleted by a command (in Windows-Explorer or ....) and you did not write to disk since then, there are programmes to recover most of your files.
If the drive is mechanically damaged, your chances are very low.
If the disk just stopped working you could give it to a data restore company. Some of them can even take the disks out in a "clean-room", mount them to a drive with new heads and retrieve the data. Beware, this is a very expensive way!
Jul 30, 2014 | PPA International Computers & Internet
Can i connect sata internal hard disk 500gb with d915gev motherboard
I dont think that is possible seeing that, the motherboard only has IDE cables, If it has a SATA port go for it
Jul 10, 2014 | Intel D915GEV Motherboard
When i switch the laptop, i hear a knocking sound from hard disk and the computer displays non - system disk or error disk plz help
Good Day Kawindwe!
I am sorry but I think the hard disk is on its last leg. A knocking sounds is the first symptoms of faulty hard disk. It is better to replace it.
The non-system disk error is displayed when the CMOS BIOS failed to detect the hard disk.
There is a small chances of making your hard disk work again. It worked for me before maybe it might work with you too.
First, turn off your Laptop. Remove the power supply adaptor from your Laptop. Remove the battery. Press and hold the power on button for at least 5 seconds to discharge remaining volts on your unit. After awhile, return the battery, plug in the power supply adaptor and turn on Laptop. See if that recognize again your hard disk.
If the first did not fix it, try this one. Turn off your Laptop. Disconnect your hard disk and then reseat the connectors properly. Then, turn on your device. Did that fix your problem?
Kawindwe, in case that fixed it, I recommend you back up your files cause the hard disk will not last that long.
Jun 10, 2011 | Computers & Internet
My laptop Dell Inspiron 1545 giving a hard disk drive error. Laptop works normal but sometimes it start producing a sound like tik,tik,tik......... then blue screen appears and when i run diagnostic it...
Its time you backup your data and contact Dell to get your hard drive replaced (in case your computer is in warranty) else order for a new hard drive compatible with your computer.
You will need your Windows CD that came with your computer, if you did not get it contact Dell about the same.
Dec 25, 2010 | Computers & Internet
Hard disk is not detecting samsung sp0411n internal hard disk is not detecting
Make sure the power cable and IDE cable is plugged in properly then boot your computer up again. If it does not work, test it on another computer to see if the hard drive works at all.
Sep 18, 2010 | Samsung (SP0411N) 40 GB Hard Drive
I got 256mb internal ram and i put 1gb external ram on my hp compaq nx6110 laptop and after few months my hard disk stops working. so now i want to buy a new hard disk so how many gb of hard disk i should...
I think you're confusing RAM (memory) with hard disk space (storage). Installing more RAM makes your computer run faster. More hard disk space gives you more room to store stuff. Which would you like to do?
Apr 03, 2010 | HP Compaq nx6110 Notebook
My laptop(Pentium III HP) do not show the connection with internal Hard disk that's why the computer does not operate and while I tried to install the Operating System the computer didnot show the...
Yes, it's true your hard disk needs to be replaced. Replacing it is easy enough, usually just one screw on the side ofyour laptop and it pulls out, swap the hard drive out and put it back in again. If your laptop supports boot from external device, it can but I don't think yours does since it's only a P III.
Thanks and please take a moment to give this solution a rating of fixya.
Mar 05, 2009 | HP OmniBook XE3 Notebook
Boot problem - Win98SE
change the boot sequence in bios set up ...
keep in this order
first boot device as floppy
2.hard disk
3.cdrom
then save it and then have a check it should work ..
you have not mention hard disk here so i think the hard disk is not detected there may be some loose contact inside and it is not connected properly so it is not able to verify DMI pool ...
if so connect the hard disk properly then then have a check it will surely work..........
Feb 23, 2008 | Microsoft Windows 98 for PC
Belkin G+ Desktop Card
something you have done has stopped the hard disk drive from working.
first check all the internal connections between the hard disk drive and mother board and hard drive and power supply.
Wiggle them around and make sure they are in straight.
then check you didnt drop any screws etc inside the pc and these are shorting something out
you need to check that the ribbon cables that connect your hard disk drive werent damaged when you fitted the wireless card
then i think you need some help
confirm that the pc can boot from a floppy or cd
you might need to change the bios settings first
you need to check all the bios settings if there is any chance that you might have changed them accidently
you need to check that the power supply is working correctly (unlikely)
i wouldnt expect that it is the card that caused the problem
then i would consider the possiblity that there was a virus on the installation disk (unlikely)
then i might wonder if coincidently the hard disk drive failed at that time.
Oct 24, 2007 | Belkin (F5D7000) 802.11g/b Wireless...
Computers & Internet Logo
David Payne
David Payne
