Question about Briggs & Stratton Automatic Home Standby Generator System 7 Kw /6 Kw
Accidently broke the fuse housing on my home genarater
    Sergeant:
  • 415 Answers
You may be able to repair it using epoxy. If that does not work, try contacting Coleman, they may have a replacement part. You can also try Ebay.
Posted on May 23, 2014
I have a philips HTS3051B/F7 home theater system that the tray opens a little then says blocked and won't open anymore. What can be the problem.
Has a child put something in it?
It could also be something that has accidently got lodged in the mechanism. Another possibility is that a gear wheel or another part of the mechanism has broke, or worn away.
May 20, 2016 | Philips Audio Players & Recorders
My dryer blew its fuse like 6 times, I would go to the garage and click it dryer fuses on and off and at first that worked but no it will run and stay on but just doesnt blow hot air
That sounds to me as if the heat element has broken and when it broke a small part of it fell onto the metal housing where the heat element fits into,as a result of the broke element no longer being suppost safe and sound it the housing but instead it sat on the housing and created a short circuit that caused the fuse to blow.
By replacing the heat element it should once again heat and not blow the fuse
GENE
Sep 18, 2011 | Dryers
Front driver headlight not working. just bought a new bulb
Try checking the fuses. I recently purchased a 96 Olds. 88 and it was wrecked on the right-front. Replaced the light and the fuse. I hope that helps.
May 11, 2010 | 1996 Oldsmobile LSS
I have a 1977 mercury marqius and i cant find out why its not charging. It has a new genarater,voltage Regulater, and also new fuse links. It seems like the charge is bloked from coming out of the...
You need to confirm that there is battery voltage to the battery post of the alternator.If there is then turn the key on and verify that there is power to the field post.If you have no power to the field it will not charge,you either plugged the regulator in before you put it on and ruined the regulator or you may have a bad wire splice between the alternators battery wire and the yellow wire in the regulator plug,check to see if it has 12volts to it at all times.If none of the above,run your own 10 gauge ground wire from the alternator to the block or the have the new alternator tested.
Jan 17, 2010 | 1977 Mercury Grand Marquis
Fuse keeps blowing for fuel pump
The fuel pump is most likely "going bad" -- the motor winding is begining to short and pulling too much current.
Charlie
Sep 28, 2009 | 1996 Volvo 850
Horn blowing
WIRE GOING UP INSIDE STEERING WHEEL HAS PROBERLY BROKE AND SHORTED OUT
Feb 02, 2009 | 2003 Suzuki Vitara
Blown accessory fuse? jenn air cooktop jed8430adb
the unit doesnt have any internal fuses. you have a house fuse blown or circuit breaker that tripped. the fan switch can be found online or from your local parts house and make sure you get the clips to hold it to the mounting tabs.
next time you get ready to work on it, just make sure and turn off the power first as you will touch the metal terminals to the frame again.
Dec 27, 2008 | Jenn-Air JED8430 Electric Cooktop
Briggs & Stratton Automatic Home Standby Generator System 7 Kw /6 Kw  Logo
43 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
