Question about Konica Minolta Office Equipment & Supplies
Konica minolta 500 white screen - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,161 Answers
Replace the control panel
Posted on Jul 04, 2016
  • 8 Answers
SOURCE: Screen won't Clear Konica Minolta Logo
Check the contrast in control panel may be it is out of focus, brightness or darkness.
Posted on Feb 02, 2008
osiriscompu
  • 16 Answers
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Posted on Jul 19, 2008
Cogz
  • 1326 Answers
SOURCE: Toner fly in Bizhub 500
The problem may be comming from the drum unit, there is a small over sray tray right under the developer mag roller. It is mostly filled up with waste toner or dropped toner from the mag roller. You have to take out the drum unit and then the opc drum and vaccum out the tray and that should take care of the problem for now... The problem will come back..... Have you ever had the developer and or the drum & blade replaced. Minolta are a duel component copier. When the developer is worn out it will start to trow toner and fill up the small tray under the dev. mag roller..... Good Luck
Posted on Jan 19, 2009
SOURCE: My Konica Minolta MC2300DL will not print. It is
You can change the 2300's menu setting to ignore empty toner cartridges and keep printing. There are 2 steps:
Step 1:
Press Menu/Select, then "right arrow" until you see ENGINE. Press Menu/Select again and then "right arrow" until you see TONER EMPTY. Press Menu/Select and you'll see STOP. Press "right arrow" once to change to CONTINUE. Press Menu/Select.
Step 2:
Press "right arrow" until you see AUTO CONTINUE. If set to ON, press the "Cancel" button and you're ready to print. If set to OFF, press Menu/Select, then right arrow to change to ON, then Menu/Select to enter. It will say "ON IS SELECTED." Then press the "Cancel" button and you're ready to print.
Posted on Apr 07, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: konica minolta bizhub 500 has
This is a fusing unit problem. Specifically TH@ also known as Thermister 2 is not detecting tempurature the same as TH1. Here is the quote directly from the service manual:
Inferior contact of the thermistor
/2 (TH2)
While in the warm-up condition,
when the thermistor /1 (TH1)
detection temperature gets to the
Ready temperature before the
TH2 detection temperature, the
TH2 detection temperature does
not get to the Ready temperature
a specified period of time after
the TH1 detection temperature
got to the Ready temperature.
Basically what you are going to need is a service tech to come out and replace TH2.
Good Luck and Thank You for using Fixya.
Posted on Aug 31, 2010
Testimonial: "Very Helpful--- not the answer I wanted..... but at least I know what I have to do. Thanks ;)"
How to replace developer in konica minolta bizhub 500
First service mode to clear the counter, then remove the developer section, dump old developer replace with new developer then run TCR adjustment. recommend replacing the drum and cleaning blade at same time.
Nov 25, 2016 | Konica Minolta Bizhub 500...
Konica minolta c451 not booting after power on
Need to know screen advancement.
konica minolta appearing or
hour glass symbol or screen completely blank or full white...
Nov 22, 2016 | Konica Minolta Bizhub C451 Copy-print-scan
"Konica Minolta C352 - cyan and white pattern background on every print?!
What are you printing a Word document when this happens ?
suspect pattern may be in the software you are printing from.
Go to software help screen and look search for removing background pattern or removing watermark.
Apr 11, 2014 | Konica Minolta Bizhub C352 Digital Copier
Reset Chip on Konica Minolta 8031 Imaging Unit
I can provide you with a programmer to reset the chip. They are only about $500-$700. Still interested?
Sep 13, 2009 | Konica Minolta Office Equipment & Supplies
Drivers E 500
No driversxrequired for use with a Windows computer
Simply plug it in- set it to upload
and Windows does the work
Feb 09, 2008 | Konica Minolta DiMAGE E500 Digital Camera
White screen problem too!
We have the same problem (white screen) after my wife took it on a trip. She had it in her carry on and didn't drop it.
Apr 25, 2007 | Konica Minolta DiMAGE X50 Digital Camera
White Screen
Did you find a solution for this? I'm trying to find which LCD would work on this same camera.
Jul 26, 2006 | Konica Minolta DiMAGE X50 Digital Camera
Konica Minolta Lithium-Ion Battery Recommendation (warning against the use of non-genuine or counterfeit batteries)
We have received a number of inquiries regarding the usage of Konica Minolta digital cameras with non-genuine or counterfeit Konica Minolta lithium-ion batteries. Please be advised that genuine Konica Minolta lithium-ion batteries are equipped with security system to prevent the camera from damages. It has been reported that some counterfeit batteries are NOT equipped with a security system. The use of such batteries will cause damage to your Konica Minolta digital camera and may cause fire. Further, every Konica Minolta digital camera has been designed to fulfill its nominal value in performance with a corresponding genuine Konica Minolta lithium-ion battery. For safety and optimum performance, we recommend that you only use genuine Konica Minolta lithium-ion batteries with Konica Minolta digital cameras. Genuine Konica Minolta lithium-ion batteries will include the Konica Minolta model # (NP-200, NP-400, etc) and are only available through authorized Konica Minolta dealers and the Konica Minolta on-line store. Please note that Konica Minolta is not responsible for damages or troubles caused by the use of lithium batteries which are not specified in the instruction manuals or not produced/distributed by Konica Minolta Camera Inc. (Updated 01/29/04) Genuine Konica Minolta lithium-ion batteries are listed below: Konica Lithium-ion Battery DR-LB4 for Konica Digital Revio KD-510Z/410Z/500Z/400Z/310Z Minolta Lithium-ion Battery NP-200 for Minolta DiMAGE Xt/Xi/X Minolta Lithium-ion Battery NP-400 for Minolta DiMAGE A1 Minolta Lithium-ion Battery NP-600 for Minolta DiMAGE G400 Minolta Lithium-ion Battery NP-500 for Minolta DiMAGE G500 Minolta External High-Power Battery EBP-100* is available for the following models: Minolta DiMAGE A1/Z1/7Hi/7i/7/5/S414/S404/S304 * EBP-100 is consisted of 2pcs. Lithium-ion Battery NP-100, 1pc. Battery Holder BH-100, and 1pc. Lithium-ion Battery Charger BC-100 For further assistance concerning Konica Minolta products, please contact Konica Minolta technical support by phone or Interactive Q&A or visit our website at http://www.konicaminolta.us Thank you for your understanding and cooperation in this matter. We look forward to your continued support for Konica Minolta products.
Sep 15, 2005 | Konica Minolta DiMAGE 5 Digital Camera
15 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
