Question about Fujitsu LifeBook S6231 Notebook
Laptop won't power up
Was using it just fine then went to exit a program using the ESC key and the screen went blank and the power died on the laptop. After that I could not power it up again using the power button. I removed the main battery, the aux. battery, made sure they were fully charged, checked for full power from the line brick and it is good at the plug to the back of the laptop. I've held down the power button for 1 min. and still no life.
  • 2 more comments
  • mikekloc May 20, 2009
    No, the laptop is completely dead. If it had any life I would be troubleshooting it from there. If there is a power up circuit controlled by the soft power on button then it may have gotten a static zap and took out the power up chip, what do you think? I am a 25 year electronics tech and I've troubleshot many desktop PC's over the years but never worked on laptops yet. Logically this seems to be a power up chip or a MB issue. Maybe an internal power regulator or fuse inside?
  • Anonymous May 23, 2009
    I tried removing and reseating the ram chips, also removed and reconnected the hard drive and main battery. When I plug in the AC adapter the small LCD panel shows it is charging, but this is the only sign of life the computer shows. The power button does not work or light up the blue ring around it like it normally should. I fear it is a bad motherboard or power logic board, probably got zapped by static.
  • Chris Hingee
    Chris Hingee May 11, 2010
    Try reseating the RAM, if it doesn't work then test the RAM in another computer.
  • joegarcia88 May 11, 2010
    Does the laptop fan or hard drive responds when you press the power button or is the laptop totally dead?
  • 152 Answers
You need to replace the RAM ..
Posted on Jul 07, 2009
I need to access the Bios system on my Lenovo laptop windows 7 how do I do that?
To enter your computer Bios, Turn on the computer by pressing the Power Button on the computer. ( Not from while it's been sleeping or hibernating.) Then press the Delete key repeatedly every second while it's powering on. It should not enter the Windows7 blue screen. Instead, it should enter the Bios screen where your mouse will not work because the screen dosn't have a curser. You'll have to use the arrow keys to navigate and the Enter and Esc keys to chose and return. Also pay attention to the screen's advice on how to use the function keys on the top of your keyboard. For use for example to: SAVE AND EXIT or EXIT WITHOUT SAVING.
Aug 19, 2013 | Computers & Internet
SATELLITE U205 ....IS ITPOSSIBLE TO BOOT FROM AN EXTERNAL USB DVD DRIVE
Shut your computer down and remove the power cord.
Replace the power cord and press the "Power" button to restart it.
Watch the screen carefully for a message about computer setup.
Most computers use one of the function keys, which are aligned across the top of the keyboard, to access the computer's setup utility, but each manufacturer uses a different key.
For instance, HP computers generally use the F1 or F10 keys, while many Dell computers use the F12 key.
Press the appropriate function key to enter the computer's setup program, then scroll through the list of options until you see "Boot Order."
The exact location of the boot order option varies from manufacturer to manufacturer, but it is often located under the Advanced menu.
Highlight the "USB Devices" option and press the up arrow key until that device is first on the boot order list.
This will force the computer to look at the external DVD drive first when it boots up.
Use the "Esc" key to exit the setup menu. Choose the "Save settings and exit" option and allow the computer to reboot.
It will now boot from the external DVD drive.
Hope this helps
Sep 26, 2012 | Toshiba Satellite U205-S5057 Laptop DC Car...
I have a laptop and the screen is blank. i tried to follow the 'checking files' routine but when this is finished, no matter what button is pressed, you get the blank screen. how can i fix it please??!!!
Try this... Remove the battery. Then Press ESC key for about 2 minutes then put the power adaptor while continue pressing the ESC key + Power button.
Mar 24, 2011 | Acer Aspire One PC Notebook
My screen is blank i can see the image but very dim unreadable
To adjust the brightness Fn+F6 to decrease and Fn+F7 to increase.
Mar 24, 2011 | Toshiba Satellite Pro L300 Notebook
How to reset bios my dell vostro 1500 . (11R50G1-595B)
To reset the BIOS please follow the below steps.
1 . Restart your Dell laptop. Click on "Start," "Turn off Computer" and "Restart."
2 . Press "F2" during the boot process to enter the BIOS. Press "F2" before the Windows loading screen. Certain models may use a different key. The key will be displayed during the boot process. For most Dell models, the key is "F2."
3 . Use the "Alt" + "F" key combination to load defaults.
4 . Press "Esc" on your Dell laptop keyboard to save and exit.
5 . Choose the "Enter" key to save all changes and exit the BIOS screen. Allow your laptop to restart for BIOS settings to reset.
Thanks. Have a great day.
Dec 30, 2010 | Dell Vostro 1500 Notebook
Hello i have an hp Pavilion dv9000 laptop. I use
Have you tried removing the memory 1 stick at a time?
Jul 06, 2010 | HP Pavilion dv9000z Notebook
HP zv5430us laptop has no video. Blank
take the main battery out, does it run everytime on a/c line pack
power.??? this is first test of any laptop. test 1.
sure there is a chance but that is not step2..
test test to is while doing test 1, see if there is the screen prompts
in text as it did its whole life. "hit ESC key to enter setup(bios)
can you get the screen to show above,battery out?
yes, good do the ESC key, BIOS entry, .see BIOS work.
great , if yes, the the HDD is not booting windows? what?
NO, SCREEN STAYS DEAD NO MATTER WHAT.
Suspect now is the power pack. as low as $15 cost.
the pack is 19vdc, does it measure that? if not its bad. (or the pc is shorted)
at HP, the support ended. and is offically Retired
https://support.hp.com/us-en/retired-products
got any beep codes , or keyboard blink codes there?
does the fan run? and blow, are the vents lint free or packed.
Jul 14, 2017 | HP Pavilion zv5430us (PR466UAA) PC...
ACER ASPIRE 9410-4933 LAPTOP SCREEN GOES BLANK DURING P.O.S.T.
Were you working with laptop in battery mode, not plugged in a/c power? You could have drained your internal DC battery & at the same time damaged your B.I.O.S. [button type] battery inside the laptop. that the computer goes into POST means that it is trying to FIND itself, not finding the graphics card, it does not know what type of 'picture' ( usually black screen with ""DOS"" words ) to show you.
1st- turn laptop on, you should see name,what type of cpu (the "inner " workings of computer) and sometimes the amount of memory (clicking like a digital timer) If not, don't worry. Press f1,or DELETE, ESCAPE (ESC), or read your book to find the KEY to puts you into SETUP. There should be a menu and somewhere there are DEFAULT. USE THOSE! Reboot to see results.
Apr 02, 2009 | Acer Aspire 9410 Notebook
Installation of Windows 2003 server in Toshiba Laptop
Change your boot order in the BIOS.
1. Turn on computer by Holding down power button while pressing the ESC key.
The machine will beep, then display:
Check System, then press [F1] key.
2. Release ESC key
3. Press F1 key
In the bios, go to the Boot tab, and make sure CD - DVD - or Optical Drive are the top of the list (see the legend at the bottom of your screen for what keys do what). Save and exit, then install your OS (save and exit is most often F10).
Mar 20, 2009 | Toshiba Satellite L45-S7409 Notebook
Fujitsu LifeBook S6231 Notebook Logo
222 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
