Question about Husqvarna Garden
Wheels on subject manual lawn mower lock up. Will turn when forced, but lock up again in normal use. Cutting reel turns freely. Axle held in place by large cotter pins, but they also turn freely. H
The wheels on my Husqvarna Exclusive 5400 manual lawn mower are locked up. They will turn when forced, but will lock up again in normal use. The cutting reel turns freely, barely touching the cutter bar. The axle is held in place by two very large cotter pins, but they also turn freely. Please advise how to loosen up the wheels. Thank you, Bruce Young trendliner@aol.com
  • 48 Answers
SOURCE: The front wheels on my lawn mower have locked
on yours you must replace the entire tranny unit - to make it roll you can remove the front wheels and remove the small gear on both sides - doing this of course will turn it into a push mower not self propel
Posted on Oct 21, 2008
  • 16 Answers
SOURCE: Lawn mower keeps cutting off
from the sound of what you are describing the piston/rings/cylinder are damaged in some way shape or form this causes compression loss in the engine, and allows oil to enter the combustion chamber, in this case a new lawnmower would be in the near future
Posted on Aug 11, 2009
  • 89 Answers
SOURCE: craftsman lawn mower wheels won't turn
take cover off the top off deck and see if your belt have came off next turn deck sideways but before you turn it sideways take air filter off cause oil can come through and ruin the filter noe look and make sure the belt is on the pully
Posted on Nov 04, 2009
hunter19_46m
  • 7482 Answers
SOURCE: lawn mower keep cutting off when cutting the grass...
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this help
Posted on May 24, 2010
SOURCE: The rear wheels will not turn in reverse at all. I
Rear wheel drives like this have pinion gears with rachet pawls that allow them to go backwards freely while locking when the transmission drives them.
You need to take off your rear wheels and carefully remove the pawls. They look like little squareish metal shaft keys with springs under them. You should notice that the keys or pawls are covered in what looks like grease.....which is actually worm metal from the pinion gear and oil mixed together to form this pastey greasey substance. Clean all that stuff off and lightly oil *( light oil...3 in 1 kind of oil) and reassemble.
You should hear the nice clean clicking of the rachet pawls as you roll backwards again!
Good luck and be careful!
Posted on Jul 01, 2010
I have a craftsman lawn sweeper 32 inch pulling it forward the wheels slides
  1. The sweeper wheels or axle (if live axle) need servicing and lubing if they do not turn freely.
  2. If the sweeper from end rides too low, the sweeper will essentially be dragging, possibly with wheels elevated slightly out of contact with ground. Remember, the ground is what turns the wheels. One way would be to raise sweeper hitch tongue by inserting washers between tongue and mower hitch.
  3. If all check, adjustment, and lubing does not correct, consider putting weight on the seeeper or in the sweeper collector to put more weight on wheel contact with ground.
Nov 08, 2014 | Garden
How do i remove a troybilt bronco riding mower rear wheel?
The caps are held on by a washer and they usually will snap off with a long screw driver
May 08, 2014 | Troy Garden
Reel mower wheels jam up
Does the reel turn off of the wheel motion?
May 12, 2017 | Garden
Craftsman 33 wheels lock
look for a bent linkage rod from the impact moving the engaugment spot
Aug 17, 2012 | Craftsman 10.5 Hp 33" Commercial Cutting...
My reel mower pushes great for a few feet, then it seems to get stuck. I bought a returned item (unknown until I got home) and am not sure it is put together right. There were missing parts for the...
I think with those things you might be cutting grass that is to long, try to raise the height setting if possible and try cutting again. Do this until you get going then adjust back down to desired height. Good Luck...
Aug 28, 2011 | Garden
How do i sharpen cylinder mower blades
I believe you mean to say a 'reel' mower. Normally and old fashoined push (non-engine powered) mower.
Most consumer reel mowers do not need to be sharpened. They do however have a knife bed that occasionally needs to be adjusted. It should have the thickness of a regular piece of notebook paper between the blades and the knife bed. (that is really VERY close) You can buy 'lapping compound' from an automotive parts store, and apply that to the bed knife, and then rotate the blades to provide a precise fit for all blades.
Commercial reel mowers, such as those used on golf course equipment are however sharpened normally once or twice a year. It requireds dismantling, and many courses send their blades to a central location for golf equipment, where they are placed on a computer operated sharpener for precision grinding. This cost several hundreds of dollars just for the grinding.
Nov 12, 2009 | Garden
My self propelled high wheel mower doesn't go
If this is a TroyBilt 34068, check your belt to make sure it is still on the transmission pulley. If the belt is in place, start it up, engage the transmission and observe both axle ends where they protrude from the center of the wheels, if one of them is turning, you have somehow lost the square key that locks the wheel to the axle. Replace the key and you will be good to go
Sep 15, 2009 | Garden
Wheels won't engage the reel of the mower.
Pop the cover off the center of the wheel with a small flat-blade screwdriver.
Pry the lock ring off the axle, again with the flat-blade screwdriver.
Lift the wheel off.
The small gear (pinion) lifts off of its axle. You may just need to lubricate the pinion gear and the little bar of metal that it engages. If the pinion is damaged, buy new ones; they're pretty cheap.
When reassembling, the lockring is easily clicked back on with a pair of pliers.
I found some replacements at http://www.reelin.com. The parts number for the pinion gear is 30737-2, 30737-3 (left and right) for the Scotts Classic.
You can find the owner's manual, with part numbers, here:
http://www.reelmowersetc.com/2000-20.pdf
Jun 17, 2009 | Great States 20" Scotts Classic Push Reel...
Reel mower isn't engaging -- blades aren't rotating and cutting
Remove the wheels and check the gears inside.
It sounds like they are worn or sheared and need
renewing
Jun 05, 2009 | Great States Corp. 16 In. Scotts Elite...
Scotts 20" reel mower. Drive wheels will not turn blades any more. Blades turn freely, but will not be driven by wheels.
This is almost certainly a problem with worn pinion gears, which are unfortunately made of plastic. Replacements are just a couple of dollars, but you'll probably want to buy a few for each side in the event this happens again. The Scotts 20" reel mower is manufactured by Great States 1-800-618-7474. You can also find more information at www.reelmowersetc.com and the user manual for this particular mower can be viewed at http://www.reelmowersetc.com/2000-20.pdf.
Feb 17, 2009 | Great States Corp. 18 In. Scotts Deluxe...
Garden Logo
327 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
