Question about Dryers
My servis m2002s switch won't stay on
The start switch won't stay depressed. Drier works fine if I prop something against the switch ..how can I replace it
2 Suggested Answers
  • 177 Answers
SOURCE: The dryer door will not stay closed
Drew has a good solution.
Posted on Oct 26, 2011
How do I replace on off switch on my servis m2002s tumble dryer
You will need to switch off the mains electric , remove the plug from the socket .
Take off the Lid.by undoing the screws on the rear.
You may need to remove the motherboard and front panel.
It is according to if the switch is part of the motherboard or seperate to know how much it will cost or what part you will need.
I changed the front panel and motherboard on my Hotpoint washer dryer in 20 minutes.
If unsure take photos on your phone before removing wires.and parts so you have something to go back to when refitting.
Mar 01, 2015 | Dryers
Door will not stay shut
There has to be some sort of spring on the door latch assembly that keeps the door closed. If broken or no tension the door will not latch and spring open. And when the door springs open, a safety switch shuts the machine off.
Nov 21, 2013 | Bosch Nexxt WTMC3321US Electric Dryer
I have a Kohler Confidant 5, model 5ckm61 generator in my RV, serial # 338225, spec# 101218. It worked fine one evening and the next day it wouldnt stay started unless the start button stays depressed ....
The control board needs to sense a voltage coming of stator windings to complete the run circuit or else it will shut down. Check the stator and rotor windings for resistance and shorts
Oct 21, 2013 | Electrical Supplies
Depress clutch turn key dash lights up. No click no nothing
you may have a bad clutch switch which will only allow the car to start with the clutch pedal depressed.it allows power through the switch only with it depressed to start the car so you won`t start the car with it in gear causing an accident.there will be a switch that the clutch pedal pushes against that allows power to flow through it to start the car.there should be power on one side with the key turned on and power on the other side with the clutch depressed.
May 25, 2011 | 1993 Geo Tracker
I have a MEDC400VWG drier.Woked fine yesterday. Put clothes in it today. Pushed start button. nothing happened. Smelled somthing getting hot. opened drier. Heating coils lit up. (with door open). Turned...
Sounds as if the motor centrifugal switch is stuck. Check to see if lint built up around switch or centrifugal mechanism on motor shaft. Rap switch with the handle of a screw driver hard but don't break it .
Nov 01, 2010 | Maytag PYE3300 Dryer
Start button does not remain depressed when turned on.
Sounds like a defective switch that won't catch. Is it still under warranty? You could put something higher than, but roughly the same size as the button on it and duct tape it on until you get it replaced. If you're handy you could replace it with a toggle or rocker switch at about $2 but it's not as suave chic. If not it should be a fairly cheap repair at the dealer.
May 07, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a 1987 mercury 9.9 outboard drive problems
the inside of the prop has a rubber between the prop itself and the inside splines to act as a shock absorber,say if you were to hit a rock. that rubber had spun out and the splines are turning inside the prop. the prop is screwed. seen it 100 times before.
Aug 25, 2008 | Sport & Outdoor - Others
Kenmore Glass top Convection self cleaning stove
I find the front door isn't shut tight enough and I prop a dowel up against one corner and the other end to the floor and then it works.
Oct 23, 2007 | Ovens
Dryers Logo
21 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
