Philips how to setup
Power soure
Philips model # 51PP9100 yellow tint ..what can I do
It sounds like the lens fluid has gone sour. Take a look at this Fixya tip for more information on replacing the lens coolant.
http://www.fixya.com/support/r11932741-convergence_repair_dull_video_repair
May 25, 2013 | Televison & Video
How can i fix philips plf5522d setup fault
Unless power is being removed from set in some fashion this indicates some problem with the main board in the set.
Dec 22, 2012 | Philips Televison & Video
It smells sour . I think it is the bag >
Hi, i would advise changing the bag & clearing any debris from the suction tube and rollers
( disconnect from power 1st )
Hope this helps
Kind Regards
KnowHowRebel
Mar 06, 2011 | Oreck XL2200 Bagged Upright Vacuum
Philips Magnavox 9P5031C 50-Inch Projection TV has a red/orange blur the whole picture is blurry
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Mar 04, 2011 | Philips Magnavox 55P9271 55" Rear...
Double image
Mar 04, 2011 | Philips Televison & Video
COLORS ARE NOT LINED UP
If your TV looks 3D, warped, or distorted it likely has a convergenge problem. If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured. You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 23, 2011 | Philips Magnavox 51MP392H Rear Projection...
I have a philips rear projection tv and it has a black spot almost like tint that is slowly covering the screen. perfect line from top to bottom and it keeps getting bigger.
Feb 16, 2011 | Philips 55PW9363 55" Rear Projection...
I need codes for remote universal sru 21035-27.i cannot use my dvd toshiba sd390
The Philips universal sru 2103S-27 is a code seeking type of remote control which will automatically program itself if you follow the setup procedure in the user manual. The link to take you to the Philips user manual download page is highlighted below. Once on the web page just click on the user manual pdf file icon and save it to your desktop. If you open the saved user manual now on your and follow the setup procedure this should setup your remote control to your Toshiba sd390 DVD
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=MX&slg=ENG&sct=REMOTE_CONTROLS_SU1&cat=REMOTE_CONTROLS_CA1&grp=SOUND_AND_VISION_GR&session=20100207033230_66.249.71.135&ctn=SRU2103S/27&mid=Link_UserManuals&hlt=Link_UserManuals
For further information:
The remote control was shipped when new with an additional list of manual setup codes on a sheet of paper but unfortunately this not availible to download from the Philips website.
Hope this helps,
James
Apr 21, 2010 | Philips SRU2103S-27 Remote Control
Unlock region code for Philips DVP 3256
Region code hack for PHILIPS 3256 x/94
1. Go to Setup. [from remote]
2. Select the Preference Page.
3. Press 1, 3, 8, 9, 3, 1 on the Philips DVD Player remote.
--> It will show current region code [ for example 5 ]
4. Now Press the up/down key to select "0" which makes it region free.
5. Press ok and exit setup.
Probably the same would be applicable for 3258, 3268, 3986.
Good Luck!
Jan 02, 2009 | Philips DVD625 DVD Player
Philips PFT726 to multiregion
1. Power on DVD without a disc in the player.
2. Press SETUP on the remote.
3. Press 'Right arrow' on the remote 3 times.
4. Press 9, 6, 5 & 3 on the remote.
5. Press up/down to change region of player. Set to 0 (Zero) for region-free.
6. Press SETUP to exit.
Jun 07, 2008 | Philips Televison & Video
Televison & Video Logo
212 people viewed this question
Top Televison & Video Experts
